is there a HOW TO on the B&M install??
Old Jan 20, 2006 | 02:20 AM
06black's Avatar
Is there any tricks or real hard parts about installing a B&M short shifter???
is there a HOW TO on the forum? i cant find it
thanks i'm doing it in the AM and i dont wanna get stuck
Old Jan 20, 2006 | 06:13 AM
max_boost's Avatar
I don't know of a HOW TO, but if you have any questions I could probably answer. I'm at work until 6 pm so I'll be by a computer so I'll keep an eye on this thread. If you get stuck post up the problem.
Oh, and make sure to MARK the stock location of the shifter cables. It will make installing the B&M easier becuase you won't have to keep readjusting the cables.
Old Jan 20, 2006 | 07:38 AM
05OrangeSS's Avatar
If you can't get the stock shift knob off in the car don't mess with it too long. It's easier to just remove the base a stick a screwdriver under it and pry it off....this is what took me the longest. Also make sure you look at how the shifter is actually assembeled before you take it all apart, because if you don't it's kind of like a puzzle.
Old Jan 20, 2006 | 10:30 AM
GSoccer24's Avatar
the B&M comes with decent instructions, the only pain is getting the stock shift knob off. heat it up from underneath with a hair dryer a bit then shove a small flathead up under it and give it a couple whacks with a hammer
Old Jan 20, 2006 | 10:39 AM
06black's Avatar
yea i guess every body got held up were i am....cant get the stock knob off
also
what is the OE shift retainer?
Old Jan 20, 2006 | 10:44 AM
max_boost's Avatar
also
Luckly for me I couldn't get my shift knob to stay on. I'm pretty sure the OE shift retainer is the part that you unbolt to remove the stock shifter. Kind of like a cap with a hole in the middle. I'm not explaining it very well becuase I can't think of what to call it.
Old Jan 20, 2006 | 10:48 AM
GSoccer24's Avatar
i got caught up in following the directions, then i just looked around and did it on my own and the install started to go smoother to be honest
Old Jan 20, 2006 | 10:54 AM
06black's Avatar
i still cant get the shift knob off
WHAT DO I DO!!!!!!!!!!!!!!!!
Old Jan 20, 2006 | 10:56 AM
max_boost's Avatar
Did you pop the top part (with the shift pattern) off the knob? you should do that and make sure there is no screw holding the knob on. That was the fix for the stock knob poping off and I think that they started doing it from the factory on the 06's
Old Jan 20, 2006 | 10:58 AM
06black's Avatar
alrite i'll take a look but i dont remeber there being one
KEEP THE IDEAS COMEING GUYS!
Old Jan 20, 2006 | 11:01 AM
max_boost's Avatar
Get a big flathead screw driver, get it under the edge of the knob and get a hammer and give it a whack.
Old Jan 20, 2006 | 11:46 AM
GSoccer24's Avatar
^^^yup
pop off the silver top with the shift pattern and make sure there's no allen bolt under there, then cram the flathead under the knob and whack with a hammer
Old Jan 20, 2006 | 11:56 AM
06black's Avatar
alrite guys 1 more thing
THE SHIFT KNOB IS OFF BUT!!!!!!!
the OE shift pivot thing....how the hell do you get that off the stock shifter????? I lost BUT SO CLOSE TO BEING DONE
HELP!
Old Jan 20, 2006 | 11:59 AM
max_boost's Avatar
HELP!
You have to slide down over that plastic hump. It doesn't seem like the plastic will fit throught the hole but it will with some force. I was nervious I was going to break it, but it comes off.
Old Jan 20, 2006 | 12:01 PM
06black's Avatar
it will fit over that oval-ish shaped plastic pics below it???
for real?
Old Jan 20, 2006 | 12:09 PM
max_boost's Avatar
for real?
Yes it will. That's how I got mine off.
Old Jan 20, 2006 | 12:34 PM
3fo893013L's Avatar
for real?
newbie. :P
Old Jan 21, 2006 | 04:13 AM
06black's Avatar
Originally Posted by sneaky
newbie. :P
god i hate you sneak!!!!!!
btw guys i got it in and DAM its sooo nice....so GO GET ONE!
thanks for the help!
Old Jan 21, 2006 | 08:03 AM
3fo893013L's Avatar
pictures? I'm getting my hurst shifter this spring anyways. meh
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
