Those of you with CA H/E
I have a CA H/E available to me however it is only the H/E. How much of a problem would it be getting the hardware I need to install it. Like the L brackets, and hoses. Anyone with alot of H/E knowledge please help me. I want it done right with no problems.
Just go to the hardware store and outfit yourself with all those things. Shouldn't cost you much at all. You could even make the l brackets yourself. Just bend some metal. Drill some holes.
Anyone have to do this before and know exactly what to get for hardware? Bump
Last edited by R&C_rallySS; Aug 23, 2007 at 07:35 PM. Reason: Automerged Doublepost
there has to be some places around where you can pick up some aluminum sheeting, like home depot or lowes... and you might be able to find those lines at lowes, home depot, a hardware store or somewhere else
I don't know how similar it is to the cobra heat exchanger but I just installed that on mine. I went to Lowes and bought a 2"x3'x1/8" piece of aluminum and bent it just like blown 4-bangers how-to and used zipties to hold it. It worked fine. There just isn't much room in there at all but the CA h/e has the fittings on the same side so that will make it much easier. It didn't bleed like I wanted it to though. You might want to crack the stock h/e bleeder to get some air out then close it and just keep the pump on with a jumper and let it run and keep filling up the tank.
