Timing Chain Kit Recommendation
Old Jun 26, 2022 | 09:37 PM
manjotsc's Avatar
Canada Timing Chain Kit Recommendation
Hi,
I have a 2010 Chevy Cobalt 2.2L, I replaced the timing chain tensioner not long ago. I want to get the whole timing chain thing done. What kits you guys recommend?
It this good? with Water Pump
CLOYES 94201SAWP {9-4201SAWP} Includes Water Pump; Does Not Include Variable Valve Timing (VVT) Sprocket or Camshaft Sprockets
More Information for CLOYES 94201SAWP
Thanks,
Old Jul 1, 2022 | 10:08 AM
Kolt's Avatar
So yours has vvt so i recommend getting the kit that comes with the vvt actuators and solenoids. Cloyes is gm's supplier for oem so thats a good brand to get. Heres a link.
https://www.rockauto.com/en/moreinfo...929584&jsn=271
You can also get the same kit that also includes a water pump but if you do a water pump you also have to take off the converter, so you will need those exhaust gaskets, and you will also have to take off the thermostat rear housing and crossover tube, so i would highly recommend those gaskets as well and throw in a new gates oem temp thermostat. A bit more work but good maintenance while your there. Factory thermostat is known to have the inner seal come loose and hang open, causing the engine to run too cold and set a CEL.
Here is the full timing kit with water pump and the gaskets you would need
https://www.rockauto.com/en/moreinfo...t=5756&jsn=539
Two of these
https://www.rockauto.com/en/moreinfo...=15190&jsn=578
one of these
https://www.rockauto.com/en/moreinfo...885075&jsn=635
this
https://www.rockauto.com/en/moreinfo...t=2200&jsn=663
Uncertain if the cloyes water pump comes with the seal so one of these
https://www.rockauto.com/en/moreinfo...t=2148&jsn=620
Converter Gasket
https://www.rockauto.com/en/moreinfo...229912&jsn=718
Exhaust pipe gasket, your supposed to take the converter assembly out to give yourself room to get around the axle for water pump and water outlet housing replacement
https://www.rockauto.com/en/moreinfo...sn=729&jsn=729
Old Jul 11, 2022 | 10:03 AM
Kolt's Avatar
Oh and i forgot you should replace the top front guide bolt with this upgraded one that replaces the bolt and the access cap. https://zzperformance.com/products/e...ain-guide-bolt
LTBALTBMX
Jul 4, 2016 12:33 AM
Spawne32
Jan 8, 2014 04:25 AM
FMSR Performance
Oct 24, 2013 07:46 AM
YesYestotheSS
Jul 7, 2011 07:44 PM
bush17
Feb 23, 2008 01:11 AM
