Towing with 2.0
Old Sep 1, 2006 | 09:02 PM
phxSS's Avatar
Towing with 2.0
Anyone experienced towing, say, three quads, with a 2.0? I want to know if I could do it instead of having to sell my car to buy a truck.
Old Sep 1, 2006 | 09:05 PM
CobaltSS422's Avatar
uhhhhhhhhhh i don't think 3.. maybe 1.. i had a 2002 cavalier ls sport that it only said up to 1000lbs towing capacity and i towed my dirtbike on a trailer to all my races and it did fine.. i had to buy crossdrilled rotors so it would keep the brakes cooler.. i don't think they recomend towing with the ss though
chevyracing19's Avatar
I dont have a 2.0 but i wouldn't tow with one. If you really NEED to tow, then go for a used silverado say 95-99. It'll probly be your best bet and you get the best of both worlds
Old Sep 1, 2006 | 09:06 PM
tube's Avatar
Please God don't tow things with your cobalt SS.
It's not a truck.
Next people will be asking about lift kits and 4 wheel drive and air locking diffs.
Old Sep 1, 2006 | 09:07 PM
phxSS's Avatar
Yea, I was thinking that two full sized quads probably weigh about 300-350lbs each? And one small, 50cc quad. That only weighs less than 100lbs. So I figured those plus trailer would put me at 1000-12000 range.
Old Sep 1, 2006 | 09:08 PM
PenguinPIE's Avatar
towing is not recommend for the SS S/C (last time i checked)
the 2.2 has a capacity of 1000lb icluding passengers
Old Sep 1, 2006 | 09:10 PM
PenguinPIE's Avatar
you know what....check ur owner's manual and see what it says
Old Sep 1, 2006 | 09:13 PM
phxSS's Avatar
I would, but it's packed away because I am moving into my new house
Old Sep 1, 2006 | 09:16 PM
PenguinPIE's Avatar
ahh ic, ill check for you later on tonite then
Old Sep 1, 2006 | 09:17 PM
g5mike's Avatar
You guys remember that video,with the two french guys filming and talking about the honda civic and all of a sudden an cobalt drives by towing a quad on a trailerBtw Mason I have 300 hundred more post than you now
Old Sep 1, 2006 | 09:22 PM
phxSS's Avatar
PROOF I can tow quads
Old Sep 1, 2006 | 09:23 PM
Matty's Avatar
Manual says 1000 LBS. But weight of passengers and anything in the trunk etc must be subtracted from that.
Old Sep 2, 2006 | 04:38 AM
Adirondack_Cobalt's Avatar
forced induction engines are not recommended for towing... anyone remember the Syclone? A truck that couldn't haul anything?
Scott
Old Sep 2, 2006 | 04:40 AM
PenguinPIE's Avatar
Old Sep 2, 2006 | 04:41 AM
PenguinPIE's Avatar
i read the manual...it has a lot info and tips on towing.......and yea i do recall reading somewhere that the SC is not recommended for towing
and that vid of the civic and the cobalt tow is a cobalt 2.2
Old Sep 2, 2006 | 04:45 AM
g5mike's Avatar
I recall it being a 2.2, my vibe would tow 1900hun, weird eh?
Old Sep 2, 2006 | 04:49 AM
PenguinPIE's Avatar
so what would towing too much do to the car? unecessary wear to the engine and tranny?
Old Sep 2, 2006 | 08:13 AM
Falcon Fixer's Avatar
The manual for the 06 SS/SC says 1000 lbs.A hitch goes for around 120 bucks.Just be GENTLE with it.Do the math, three 200lb passengers,you driving and a loaded trunk would come to around a thousand lbs.So you,alone or with 1 passenger towing only ONE quad is no problem.The real issue is not the weight,its the drag.A quad on a trailer doesn't exactly make for good aerodynamics.So it would be about the same on level ground with the quad as if you were always going up hill without.
Old Sep 2, 2006 | 08:15 AM
biohazard's Avatar
Get low
towing anything with this car is going to be bad hell just a trailer will hurt the car.... but if you toe an excessive amount, it will burn up the car.... just be careful... even the vid where the guy is pulling a quad.. hes killing the car
Old Sep 2, 2006 | 08:25 AM
ItalianJoe1's Avatar
The SS/SC is not reccommended for towing, due to the high performance transmission. The regular cobalts are ok for 1000 lbs, and i remember seeing somewhere that the 2.4 SS could tow 1500 with the automatic.
Old Sep 2, 2006 | 10:11 AM
djt81185's Avatar
Scott
i guess turbo diesels and big rigs shouldnt tow anything then huh?
also this tranny was designed for towing in europe for the saab 9-3...its designed for towing behind a 2.0L turbo motor. Its listed in the tranny spec sheets and in the sport compact car article.
You;ll be fine...and u can fine hitche for under 100 online...i posted links either here or on the rl forums...just do a ssearch for my name and hitch
Dan
Old Sep 2, 2006 | 10:16 AM
EvlPeanut's Avatar
If you're really concerned about your car, I'd call different places that install tow hitches etc or even different dealers to find out if the SS/SC is ok for light towing. I'd much rather get a pro opinion from somebody that deals with the car or towing for a living.
Old Sep 2, 2006 | 10:26 AM
p7x's Avatar
p7x
Towing is not reccomended! Borrow a friend's trunk.
Old Sep 2, 2006 | 10:30 AM
06black's Avatar
trying to tow on that stock clutch is gonna be hell.
i'd say no! but the owners manual says shes good to 1000lbs
Old Sep 2, 2006 | 04:37 PM
Dan
gas engines, dickhole...
diesels are a whole other ball of ****.
everyone has the luxury of being a sarcastic **** on the internet, i suppose that's what makes it so much fun. i just know that with all the turbo cars I've had, they recommended that towing was not a good idea.
in the manual for the cobalt, it says nothing about towing with the ss. so, **** it, tow away.
Scott
