Trying to remove sealant
Old Jun 27, 2008 | 10:19 PM
blu3_v1p3r's Avatar
ok so i have my headlights apart and there is a ton of sealant on them... what is the easiest way to get it all off... i was using goo gone but it only works when there is very little sealant on there... will a paint thinner or acetone work?
Old Jun 27, 2008 | 10:32 PM
auggie_ss_phx's Avatar
i used a hair dryer just heat up one area and take off and just keep moving around it or get a second set of hand to hold the hairdryer it worked for me
Old Jun 27, 2008 | 10:47 PM
blu3_v1p3r's Avatar
i started that with the first light, but its a real pain in the ass i want a chemical that i can use my hands are sore from using a screw driver to pry the sealant out...
Old Jun 27, 2008 | 10:49 PM
i was like that too it takes time
Old Jun 27, 2008 | 10:51 PM
originaladrian's Avatar
oven and time
Old Jun 27, 2008 | 11:19 PM
eurochevy's Avatar
i got half way with my first and said screw it and just put one in the oven at a time MUCH simpler..still had to pry to take it apart but at least glue issn't spill any where and nothing cracked
Old Jun 28, 2008 | 12:40 PM
2fastSS's Avatar
when u put them in the oven its gonna make the glue all soft thats the easiest time to remove it, it sucks but thats the only option you have..Make sure you remove as much as possible and take your time on it dont rush it because then you can have a better sealed headlight
Old Jun 28, 2008 | 01:30 PM
blu3_v1p3r's Avatar
yeah i used the over the to get them apart and scrape out what i can... but there are still some spots with blobs of sealant... and for getting it off of the lens i don't want o scrape it i want some kind of remover...
Old Jun 28, 2008 | 01:34 PM
ls1fbody's Avatar
Haz l33t wheelz.
be careful if you try acetone, im not sure what the specs are but the lens might melt
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
Turbo Johnny
Feb 21, 2019 09:41 AM
Extreme Dimensions
Sep 24, 2015 05:24 PM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
