type of oil
Old Jun 1, 2006 | 04:22 PM
hoosier daddie's Avatar
type of oil
I have the 2.0l ss/sc and was curious if we should only use mobil 1, or can we use something like penzoil synthetic? thnx
Old Jun 1, 2006 | 04:24 PM
1stbluSS's Avatar
stay with mobil dude if you want to switch get mobil 1 full syntehtic extended performance. Lasts 15 thousand miles. I have had it in my car for 11k and it is working like a dream !
Old Jun 1, 2006 | 04:27 PM
Rangerondubz's Avatar
It really shouldnt matter what type of oil just as long as it is full synthetic
Old Jun 1, 2006 | 04:32 PM
Tomtwtwtw's Avatar
Any full synthetic oil should be fine, but I personally prefer Mobil 1.
Old Jun 1, 2006 | 04:33 PM
Bad06SS's Avatar
I would just stay with mobil 1. Just go by what the oil cap says.
Old Jun 1, 2006 | 04:35 PM
NightriderCobaltSS's Avatar
Since we are on the subject of oil. has anyone heard anything good or bad about that royal purple oil thats out they "claim" a 9 hp gain for using it.
Old Jun 1, 2006 | 04:36 PM
1stbluSS's Avatar
royal purple does what it claims.... too expensive and you only see the increase in the first few 100 miles
Old Jun 1, 2006 | 04:38 PM
Bad06SS's Avatar
It's too thin. I used it in my last car. I ended up having to do an engine rebuild, and when we got it apart, all of the internals looked horrible. Everything was scorched and melted from being too hot, it looked like the engine had been ran with no oil. I know people who have went through 2+ engines (luckily under warranty), and stopped going through them when they stopped using Royal Purple. While there is no proof the RP caused it, i've seen the inside of engines using Mobil One, and they looked much better.
Old Jun 1, 2006 | 04:39 PM
sscobalt06's Avatar
I use Castrol Syntec sae 5w30
Old Jun 1, 2006 | 05:24 PM
budman128's Avatar
For the 2.0 engine the oil has to meet a certain gm spec im not sure what it is right now but it is in your owners manual. Failure to use oil that meets this spec will void your engine warranty.
Old Jun 1, 2006 | 05:51 PM
Bad06SS's Avatar
Yep. There's a reason GM recommends Mobil 1. I don't know why any of you guys use anything different.....
Old Jun 1, 2006 | 06:09 PM
SoloSK71's Avatar
AMSOIL meets GM spec 6094M
- Solo
Old Jun 1, 2006 | 06:31 PM
thanx for the quick responses...
Old Jun 1, 2006 | 06:47 PM
jokieman's Avatar
You can use whatever but I had penzoil turn to goop a couple of times whenever I've used it in the smaller cylinder engines. I'd use Mobil 1, it's what all the car guys use, whether it's for hondas, fords, or chevys.
Old Jun 1, 2006 | 06:48 PM
g5mike's Avatar
Mobil 1
Old Jun 1, 2006 | 07:02 PM
GSoccer24's Avatar
i would stay with Mobil1 in case GM or the stealership wants to pull some voided warranty crap on your ass.
you might want to get a new 710 cap though
Old Jun 1, 2006 | 07:05 PM
Gory's Avatar
You must not have used the right weight oil
I am going to use royal purple in my car I have used it in my Race car and never had any problems not only that royal purple is better than most oils out there and conforms to all standards.
http://www.royalpurple.com/techrp/summary.html
Old Jun 3, 2006 | 05:05 PM
EthensCobalt's Avatar
also what in the hell were you doing to your car about it getting to hot............. my step dad is a mechanic and he said that a guy drove 1 hr and stop to get his oil changed at my step dads shop and he changed right when he pulled up pulled the plug and the oil wasnt even warm.
i use royal purple and according to the computer i get 33 mpg at 70mph
arent we supposed to get 29
Old Jun 3, 2006 | 06:16 PM
06G5GT's Avatar
A guy was driving for an hour and stopped and got the oil changed right away and it wasn't hot? Are we seriously supposed to believe that?
I've seen cars be sitting waiting for an hour to get in our shop and the oil is still quite warm to the touch. Most cars that get right into the shop have oil that is too hot to touch.
Old Jun 3, 2006 | 06:21 PM
repoman's Avatar
Royal Purple. this is isn't even a question. Just make sure you stick with the 5/30 though.
Bad06SS's Avatar
Don't insult me by saying I didn't use the right weight oil. I'm not a kid, and I used the correct oil. That's nice that you use it in a race car, but you don't drive your race car everyday on highway and in traffic. You do a race, and then probably change it. Not the same. Not everyone gets the chance to see the inside of their engine, and the same engine that used mobil one looked a heck of alot better than mine with royal purple. Use what you want, but don't come in here and argue about how good royal purple is supposed to be because it won't get anywhere with me. I think it's crap, and it still doesn't change the fact that you should only be using Mobil one in a S/C SS, unless you want to risk your warranty being voided.
Old Jun 3, 2006 | 06:23 PM
Bad06SS's Avatar
Yea, drove an hour and it wasn't warm. Yea, OK. My car always gets 32+mpg at 80mph and I use Mobil one. I've gotten as high as 36mpg on a trip. Now what?
Old Jun 3, 2006 | 06:28 PM
05BlackCobaltSS's Avatar
I use Mobil 1 and on my trip to Peoria on Wed. I averaged a speed of 68mph and MPG of 33.4 MPG it got as high as 35.9 though.
Old Jun 3, 2006 | 06:41 PM
Bad06SS's Avatar
For you royal purple guys, here's a link showing mobile one outperform royal purple:
http://www.worldsbestoil.ca/dyno-test.php
Old Jun 3, 2006 | 07:47 PM
06G5GT's Avatar
In the only truly independant oil test I've ever seen done, both Mobil 1 and Amsoil tested good for well over 10k miles. But at 10k, the Amsoil started to thicken. So Mobil 1 is the only one that goes in my car.
