Urgent Coil-Pack Question
Hey guys,
So, I have a coil-pack issue with cylinder 1.
The last time I changed my plugs (a month ago), I noticed the cylinder 1 coil-pack was jacked up. And also throwing a CEL for cylinder 1. Basically, the shaft that connects down onto the top of the plug was "disconnected" from the actual coil-pack top part. I don't know if it's a loose boot (that it slides into / turns into) or a bad shaft thing, or if the whole thing is messed up?
Any ideas or suggestions?
Can you buy just the boot separately? Or try a new shaft? Or do I need a whole new coil-pack altogether? If so, can I buy a used one, or do I need to buy new? I don't like replacing just one of something.. And how much if I do need to?
Thanks!
Thanks!
not thread jack intended
Im having the same issue, im having cylinder one misfire, haven't checked the boot out specifically but i have ruled out everything thing else that could be causing a cylinder one misfire. I went to the local autozone and the boot for my 2.4 is like 20 bucks. im taking it the dealer tomorrow seeing as how it's still under warranty, and i will be sure to post up a fix if it gets resolved tomorrow.
So you actually can buy this said boot at a general parts store, and you don't just have to go to the dealer? Could you post a picture of said boot? I can tell you if it's the right thing.. Mine's loose it seems like, and the "shaft" slips out of it.
Nope thats my stock one. Correction it's our ignition coil and it's actually 100 bucks
http://www.autozone.com/autozone/par...er=201825_0_0_
But you can get it at any local autozone.
