valve cover question
Old May 19, 2010 | 04:58 AM
cobalt523's Avatar
i was looking into powdercoating my valve cover and calipers, if i remove my valve cover will i messup my timming? or will i be able to unbolt, paint, and rebolt? thank you
Old May 19, 2010 | 07:15 AM
all4glh's Avatar
Unbolt, paint and re-bolt.
Old May 19, 2010 | 07:31 AM
cobalt523's Avatar
cool thanks im sure theres threads on this already but i use my phone's enternet to get on here and it limits what i can do
Old May 19, 2010 | 02:55 PM
cobalt523's Avatar
bump for more suggestions preferably gene
Old May 19, 2010 | 02:56 PM
ls1fbody's Avatar
Haz l33t wheelz.
unbolt, paint, bolt back on.
Can't get much simpler...
Old May 19, 2010 | 02:58 PM
Mclovin23's Avatar
has anyone done this themselves without powdercoating?
Old May 19, 2010 | 02:59 PM
EdCobaltSS's Avatar
valve cover easy, calipers will have to be bled, sometimes a pain in the @$$
Old May 20, 2010 | 02:27 PM
cobalt523's Avatar
ok but everyone agrees here that unbolt, paint, rebolt? i just dont wanna **** anything up
Old May 20, 2010 | 02:30 PM
heathkidder's Avatar
yep iv taking mine off and painted it black not powdercoat.... theres like ten bolts you gotta take out
Old May 20, 2010 | 02:40 PM
cobalt523's Avatar
that looks pretty sick! :
HunterKiller89's Avatar
its just a cover. obviously you dont want to drive with it off, and if its off for a long time you might want to cover the area (or at least close the hood) so leaves and debris dont fall into the head, but it wont affect anything by taking it off. I've taken mine off a couple times.
Old May 20, 2010 | 02:45 PM
^^^^ true. dont drive with it off obviously and make sure you cover it so nuthin gets into it
Old May 20, 2010 | 02:46 PM
cobalt523's Avatar
thanks, quick question, if i take out the cams, what is that tool that you use to keep the timing??
Old May 20, 2010 | 03:15 PM
EdCobaltSS's Avatar
why would you want to take the cams out?? and its almost impossible to do without having to set the timing
Old May 20, 2010 | 04:59 PM
cobalt523's Avatar
swap them out with 2.4 cams, but there is a tool to keep the timing
Old May 20, 2010 | 08:01 PM
Gene Culley's Avatar
Talking
I personally wouldn't paint it. It will flake off after a while and it will look like crap. One way or another, paint after a while is going to look like crap. A year after powder coating mine, it still looks like the day I installed it.
As far as installation, it is very simple and only would take about a 1/2 hour to do it.
Old May 20, 2010 | 08:06 PM
cobalt523's Avatar
thanks gene
Old May 20, 2010 | 08:08 PM
Talking
I painted my throttle body last year. I primed it and sprayed a couple of coats on it and was very picky about the prep, drying time, etc. It flaked off like a mother. I just got a new throttle body and powder coated it and the problem is finished.
Old May 20, 2010 | 08:23 PM
BlackJackSS's Avatar
i wanna do flat black on my valve cover and super charger. dunno if i wanna take the sunday to do it or not tho.
Old May 20, 2010 | 09:20 PM
the part to do it is a GM specialty tool (AKA a J-tool), but 2.4 cams aren't really an improvement worth doing this with. You should really get a custom grind...of course i think you have a LAP (i cant see your sig while typing responses )so no one makes cams for you yet
Old May 20, 2010 | 09:39 PM
cobalt523's Avatar
sheit!
Old May 20, 2010 | 09:43 PM
importkiller's Avatar
I am going to do a red wrinkle paint job on mine using VHT wrinkle paint.
Old May 20, 2010 | 09:56 PM
cobalt523's Avatar
nah didnt you hear gene? paint will eventially chip and scratch, powder coat is the sheit :
Old May 20, 2010 | 10:00 PM
the wrinkle paint will not because you bake it.
Old May 27, 2010 | 08:47 PM
Talking
I am done trusting paint. That much I know
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
HEATON
Oct 16, 2015 07:21 PM
Trav3480
Sep 28, 2015 02:46 PM
SlowSaturn
Sep 28, 2015 11:03 AM
