valve float
Old Dec 24, 2007 | 04:09 AM
red2006SS's Avatar
valve float
*-wasnt sure of the best place to put this at so figured id try it in the lounge. if a mod would move it to correct location, thanks in advance.-*
alright discuss valve float, looking for all information on it as i can get because i do believe it happened to my car. i haven't driven it since the other day. there is a story behind it illpost a link for that as well. how can it be fixed after it occurs? how can it be prevented? just good old discussion.
valve float links
http://en.wikipedia.org/wiki/Valve_float
http://www.circletrack.com/techartic...oat/index.html
http://www.automotiveforums.com/t152566.html
my story link
https://www.cobaltss.net/forums/problems-service-maintenance-69/need-help-cobalt-down-89733/
Old Dec 24, 2007 | 04:26 AM
HackAbuse's Avatar
Valve float is only damaging if your valve hits a piston.
Then you have problems.
Old Dec 24, 2007 | 04:33 AM
red2006SS's Avatar
but what if its making some goofy noise that i really cant explain lol, and has little loss of power, will it hurt to drive it to dealership or should it be towed over?
Old Dec 24, 2007 | 04:41 AM
HackAbuse's Avatar
Your car comes with free towing to the dealer no matter what within 3 years or 36,000 miles
Old Dec 24, 2007 | 10:54 AM
Blown 4-banger's Avatar
You sir are incorrect. While the LSJ is an interference motor, since the valves are at such a high angle, if you get valve float the piston simply pushes the valve closed, rather than break off the head. My pistons showed indication that the piston and valve made contact on more than 1 occasion. However on a push rod motor with low angle valves, piston vs valve = fuct motor
Old Dec 24, 2007 | 11:05 AM
REIGN SS's Avatar
Original Hayden Fanatic
hmmm... General cobalt sounds good to me
Old Dec 24, 2007 | 12:05 PM
Sharkey's Avatar
actualy weather its a pushrod or ohc engine makes no difference if its an interference motor. look at a dsm, when you break a timing belt it bends half the valves. the piston doent simply close the valve, it cant.
in the case of valve float, it may just push the valves shut. however, if its running bad id say its got a bent valve
Old Dec 24, 2007 | 02:59 PM
red2006SS's Avatar
is there some where i can get replacement valves or even aftermarket ones for the 2.4 and i guess springs and all if dealership wont do anything with warranty for me
Old Dec 24, 2007 | 03:42 PM
Ferrea is doing my valvetrain, custom length +1 mm titanium valves, dual valve springs good to 9000+ rpm, and titanium retainers
Old Dec 24, 2007 | 03:58 PM
steddy2112's Avatar
Jbody Performance...I was drooling all over the heads they have for sale there...I read your story...
Stop and think before you go to the dealer.
Ok.
You over-revved your car, it broke. How is that mechanical failure? Instead of getting your warranty completely denied, just file a insurance claim...seriously...you will get your whole warranty denied because you are trying to get a freebie...not wise...
Old Dec 24, 2007 | 10:20 PM
red2006SS's Avatar
Ok.
note taken. what about police report though. i dont know if anyone called it in or not because no one ever stopped i mean the others who were almost involved did like i did try to slow down and avoid it but no one ever actually stopped. will that matter for insurance claim? by the way i appreciate all the help guys
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
yellow dragon
Sep 28, 2015 09:49 PM
Trav3480
Sep 28, 2015 02:46 PM
dennis69
Sep 28, 2015 02:16 PM
