Vibrant Oxygen Sensor Defouler
Old Mar 31, 2011 | 01:28 PM
YelloEye's Avatar
Originally Posted by northvibe
lower airflow over the o2
Hmm true.
Old Mar 31, 2011 | 01:32 PM
Mnatvyc1223's Avatar
they are calling them defouler's now??? lmao, CEL eliminator is the more accurate term. OP they work good if no one has said it yet. on that note, if you are getting tuned, just have the tuner turn off the bank 2 CEL...
Old Apr 1, 2011 | 12:24 AM
ecot3c inside's Avatar
well originally they are "spark plug non-foulers". Idc wtf they are called, all I know is I'm going to pass emissions and get my god damn sticker.
Old Apr 1, 2011 | 12:29 AM
MachiBLue's Avatar
They do work. I just did this to my car last month to pass emissions. Easiest $4 spent. I drilled one out, put the 2 in series, slid in the O2 sensor and that was it. Cleared the code.
Old Apr 1, 2011 | 12:40 AM
**** man, idk how anyone put's 2 together unless I bought the biggest one there was, because there is absolutely no room for you to but 2 together with the sub frame parallel to the o2 sensor, my o2 is like crammed in there making my exhaust rattle like crazy I can't wait to get this emissions crap over with.
Old Apr 1, 2011 | 12:44 AM
MachiBLue's Avatar
It was a tight fit, but they both fit in there. I just went to autozone and bought the pack. There's 2 different kinds, one with a tapered seat and one without, but they should be about the same size in length.
Old Apr 1, 2011 | 02:32 AM
BIG SS TC's Avatar
what do u drill out????
Old Apr 1, 2011 | 10:21 AM
hard to explain, but you can see when you look at it, then you will know.
Old May 18, 2011 | 03:15 PM
BARBER_IMAZE's Avatar
If i do this, will i fail inspection? my code keeps coming on too.
Old May 18, 2011 | 03:57 PM
CrystalRedSS's Avatar
Will this work with BadMab's dp? Just want to make sure the threads are the same.
Old May 18, 2011 | 07:15 PM
  #36
YelloEye's Avatar
That'd make sense, otherwise everybody would need to buy new o2 sensors.
Old Sep 20, 2011 | 11:16 PM
  #37
Frogstofall's Avatar
Waking up an oldie... Wanted to know if anyone went the Autozone spark plug anti fouler route with the Bad Mab DP? Was there enough clearance?
Old Sep 21, 2011 | 05:03 PM
  #38
jmesl8er's Avatar
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
jmelton327
Sep 26, 2015 10:04 PM
Knightwolf
Sep 12, 2015 11:02 AM
