Vibration while accelerating
Old Apr 8, 2010 | 10:49 AM
2.2blckbalt's Avatar
Hoping someone might be able to give me an idea what might be causing this.
I have an '05 2.2l 5 speed.
Sometimes while accelerating I feel a fairly strong vibration in my pedal. I can hear it also. It's almost like a chattering. It doesn't do it I rev up in neutral, so I dont think it's the engine.
Oh and it doesnt do it all the time.
I first thought maybe my rotore were really warped so I changed them but that didn't solve the problem.
Could the transmission or clutch cause a noise/vibration like this?
Any thoughts would be appreciated.
Old Apr 8, 2010 | 07:35 PM
Killa702's Avatar
could be your hub bearing
does it vibrate in like second or third gear?
and does it vibrate past a certain rpm?
Old Apr 8, 2010 | 07:42 PM
madmark's Avatar
cv axel
Old Apr 8, 2010 | 07:48 PM
conerboner's Avatar
When's the last time you had your tires balanced?
Old Apr 8, 2010 | 07:56 PM
shawn672's Avatar
bent wheel? - front wheels will vibrate your pedals and wheel while rear ones will vibrate your seats and cabin
Old Apr 8, 2010 | 08:20 PM
koch1ar's Avatar
I have a metal on metal chatter in 1 & 2 at hiher rpm
Old Apr 9, 2010 | 12:35 PM
insylem's Avatar
I remember reading somewhere about the use of faulty hardware in the timing chain... ?
Old Apr 9, 2010 | 06:14 PM
I've noticed it vibrate in every gear but first.
But it doesn't always do it.
It seems to start around 2-3k rpm.
Been a year or so since I've done an alignment or balanced the tires.
Old Apr 11, 2010 | 11:10 PM
conerboner's Avatar
I'd start with balance and rotate depending on how long it's been since you did that...
Old Apr 14, 2010 | 10:08 PM
insylem's Avatar
Sometimes pre-ignition / pinging / detonation can sound like metal on metal chatter....
Check your gas Octane, intake temps plug temps ect
Old Apr 15, 2010 | 01:02 AM
Phyrric's Avatar
Did you recently curb any of your rims? I've heard complaints of this before on other forums and its usually something wheel or axel ish related like most others are saying
Old Aug 4, 2010 | 02:44 PM
Hodz's Avatar
Ever come up with a fix?
Old Aug 4, 2010 | 06:46 PM
07SSS's Avatar
did you lower your car?? if not maybe your mount it hitting the steering rack...that's what I got...same thing going on by the sounds of it and I am scared that it might be the cv joint but it keeps getting better everytime i take some off the mount and put shims in .
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Tupp
Sep 30, 2015 08:18 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
