Vibrations in the wheel
ok so i took the tires off to paint my rims and put them back on tight and everything but i now have slight wheel vibrations once i hit 55.
had the problems after i lowered the balt and took it to a tire shop and got aligned and balanced but the problem is still there idont kno wat to do
Any suggestions??
Any suggestions??
Does the steering wheel shake or just the whole car.
First recheck the torque on the lugs.
If the steering wheel is shaking its most likely one of the front tires or alignment.
If the whole car is shaking it could be a bad wheel on the back.
i got an alignment and balance and it didnt do nething
the car is fine untill i hit 55 then when i accelerate its fine its coasting that gets the slight shake
http://www.gsp9700.com/ You can get a list of shops that have this balancer.
