Warming Up Your Car.......
o yea I hardly ever hit 5k rpm when fully warmed up so I'm good
but I'm always in a hurry to get to work so I take off at those temps... Guess ill have to wake up a lil earlier lol
Modern engines are ready to go when there is full oil pressure. Which is only after a few seconds. Im not saying hit full boost right out of your driveway, but there is no need to let the car idle for 2 minutes before moving the thing. The high rpms at startup are to warm up the cat, not the engine.
I wait til about 100 coolant then ill drive off. I shift <3000 RPM's until about 150ish and then I let her get into boost.
yea, it should be fine to drive cold as long as you're easy on it until it's warm. the manual doesn't even ask for a warm up period, it just says to be careful when it's cold. I used to wait until the coolant is 70
i wait for the cat warm up sometimes a minute after that but today for instance i was late for work so i just started it in reverse and took off right away
i just drive easy till around 140-160 temps
