Water Temp
Old Apr 10, 2007 | 04:47 PM
mkulrey13's Avatar
Water Temp
Well im clueless right now, im looking for a 1/8" to M12 x 1.75 adapter for my water temp and oil temp gauges, the ATM-2278 is jsut for pressure and the adapter isnt long enough to screw in the temp sender. Anyone know where i can get one? if not if someone could get a pic of the upper raidar hose and how to properly install a water temp gauge would be awesome. sorry about my english a bit tired now
Old Apr 10, 2007 | 04:59 PM
06_SS_S/C's Avatar
According to Autometer's website, it can be used for either pressure or temperature. You should screw the 2278 adapter into the head and then the sending unit into the adapter.
http://www.autometer.com/cat_accesso...st.aspx?pid=11
Old Apr 10, 2007 | 05:58 PM
mkulrey13's Avatar
does not work, ill take a pic as well, my c2 sender is just too long and wont even reach the threads of the adapter when inserted. see pic below ......after i upload it
^^ Thats as far as the sender goes into the adapter. The sender is from the autometer shortsweep c2 water temp series. i may just drill the hole out bigger for the sender to go father down in the adapter if there is no other solution
wow..........
http://www.autometer.com/cat_accesso...il.aspx?vid=33
if i read the fine print says i need a different sender.. GFG haha thanks for the person who helped me
Old Apr 10, 2007 | 06:23 PM
06_SS_S/C's Avatar
Oh damn, that sucks. How much is the new sender?
Old Apr 10, 2007 | 07:29 PM
mkulrey13's Avatar
12$ ehh thats fine, will pay for itsself if my car ever takes a ******* and i see the problem before it breaks down
Old Aug 5, 2007 | 05:53 PM
Viper33884's Avatar
Where exactly do I hook up the water temp sender to, I have some Cobalt gauges on the way and not sure where to install at? If someone could please help or just post a simple pic of where I would greatly appriciate it.
Old Aug 5, 2007 | 06:48 PM
mkulrey13's Avatar
^ i jsut bought cobalt series, teh C2 was to bright for my eyes. I will be installing it in the upper raditior hose. once i figure out how to drain it haha
Old Aug 5, 2007 | 07:34 PM
Viper33884's Avatar
That's what I figured, but do you just cut a hole in the hose and put a nut on the back of the fitting inside the hose or are you going to get a steel fitting and cut into that to save the stock hose?
Old Aug 5, 2007 | 09:14 PM
mkulrey13's Avatar
basically, you cut the hose, attach both ends of the hose to each side of the adapter and in the middle is a screw hole to screw in the sender.
Old Aug 8, 2007 | 02:06 PM
Viper33884's Avatar
Ah ok, does the adapter come with the gauge or do I need to buy it seperate? And if so where do I get it from?
Old Jun 19, 2013 | 01:59 PM
mkulrey13's Avatar
Bump. had to search and use my OLD thread i created to answer the SAME question.. one day ill learn
nathan112i
Sep 30, 2015 07:12 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Slick_Nick
Sep 28, 2015 09:15 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
