View Poll Results: What type of gas do you use??
Regular
40
21.62%
Mid Grade
5.41%
Premium
135
72.97%
Voters: 185. You may not vote on this poll
What gas type do you use?
I think most SS/SC guys are using premium because it is what the manual reccomends. Although I thought I heard the 2.4 or 2.2 recommends premium also. I put 93 octane in all my cars!
Mike
Mike
The 2.2 recommends regular gas so that's what I use.
I've read multiple times that you put in what your manual says b/c any higher grade is a waste of money and any lower is bad for your engine.
the whole point of octane is the gasolines resistance to detonation. with a boosted,high compression, performance motor, its necessary to have premium because the cars run very advanced commonly, and they need to havea fuel that can withstand the advancing. Not to mention that when working right the car will use the premium to cause a MUCH better air/fuel mixture before the plug sparks the mixture. I would put it in ANY car. from what i understand also its alot cleaner on the motor and the parts also tend to last longer seeing as how the car has to work LESS to get a perfect mix to combust.
i would never recommend this but if u were to put regular in lets say a ss/sc or something that required it. 100% proven the car WILL misfire. or predetonate. the fuel will ignite purely from the compression. not from the spark plug sparking. if it means anyhting diesels dont have spark plugs as many ppl know, they just rely solely on compress diesel fuel and having it ignite without a spark . had a big like debate/question going on at school(uti) about diesel fuel and octane ratings with teachers and students. from what i remember i was told deisels have an octane of like 54? i think either way its VERY suceptable to detonating before a "spark" is needed hense the lack of plugs.
Last edited by Punkloser6; Jun 29, 2007 at 07:39 AM. Reason: Automerged Doublepost
it doesn't burn cleaner, doesn't burn better, just harder to burn.
your right. let me amend my comment before. it doesnt work cleaner then. sorry for the misinformation on that part. lol thanks for the corrections i wasnt too sure on the cleaner part if it was true or not
these are probably all spread by the oil companies so people think they need more expensive gas. like they don't make enough money as it is!
example... regular 2.199 / midgrade 2.299 / premium 2.399
12 gallon tank = $26.38 / $27.58 / $28.78
gas rises!!!
reguar 2.599 / midgrade 2.699 / premium 2.799
12 gallon tank = $31.18 / $32.38 / $33.58
im just pointing this out.. a lotta people around me drop octane levels when prices go up when they need the higher octane for their performance vehicle.. when in reality the price difference is the same ... if ur car doesnt need the higher octane then use the lowest one necessary
