View Poll Results: What type of gas do you use??
Regular
40
21.62%
Mid Grade
5.41%
Premium
135
72.97%
Voters: 185. You may not vote on this poll
What gas type do you use?
Old Jun 29, 2007 | 11:12 AM
Z Speed's Avatar
93 oct since the day I owned my car.... the only other thing i would put in it is race gas at the track
Old Jun 29, 2007 | 11:16 AM
Onyxd04Redline's Avatar
Originally Posted by PuSha050
when prices go up.. regular, mid-grade, and premium all go up.. so the difference is always the same between levels
example... regular 2.199 / midgrade 2.299 / premium 2.399
12 gallon tank = $26.38 / $27.58 / $28.78
gas rises!!!
reguar 2.599 / midgrade 2.699 / premium 2.799
12 gallon tank = $31.18 / $32.38 / $33.58
im just pointing this out.. a lotta people around me drop octane levels when prices go up when they need the higher octane for their performance vehicle.. when in reality the price difference is the same ... if ur car doesnt need the higher octane then use the lowest one necessary
When i lived in Pa.. Premium was 40 cents more then regular.
87 = 2.89
89 = 2.99
93 = 3.29
In tempe premium is fairly cheap and i love it.
Old Jun 29, 2007 | 12:35 PM
an0malous's Avatar
If your putting regular in your 2.4, or ss/sc, please go to the dealership, hand them your keys, and tell them you need a 2.2, because you cant be trusted with anything other than the 2.2 engine.
You CHOSE to pay more for your car, by going for the ss, or the ss/sc
dont you DARE cheap out $2 at the pump and treat it like dirt.
Old Jun 29, 2007 | 12:38 PM
Halfcent's Avatar
I'm old school
Regular. Ofcourse I'm still normally aspirated on 8.9-1 compression.
Old Jun 29, 2007 | 01:00 PM
css9450's Avatar
I use diesel.
Old Jun 29, 2007 | 05:02 PM
TorontoSS's Avatar
Originally Posted by Raspyn
I'll be picking up my new 2.4L SS next Wednesday - what is the recommended fuel rating for the 2.4L SS? Mid-grade or premium?
i had a thread about this, but if you read your manual gm recommends that the 2.4 be given 91 octane. You can run 89, but 87 might cause some engine knock in the 2.4. So thats just speaking from my own experience.
I always try to put 91 octane in.
Old Jun 29, 2007 | 05:03 PM
Coblt ss super's Avatar
Premium and only that, never anything less
Old Jun 29, 2007 | 05:22 PM
h0l0caust's Avatar
i use coolaid in mine, the lil lsj like the grapes one,
Old Jun 29, 2007 | 09:23 PM
PuSha050's Avatar
87 = 2.89
89 = 2.99
93 = 3.29
even still.... the difference is honestly negligible...
and it suks bein in NY.... regular is at like 3.25 right now wit premium hoverin at 3.50
Old Jun 29, 2007 | 10:38 PM
yellow_cobalt's Avatar
Originally Posted by Punkloser6
the whole point of octane is the gasolines resistance to detonation. with a boosted,high compression, performance motor, its necessary to have premium because the cars run very advanced commonly, and they need to havea fuel that can withstand the advancing. Not to mention that when working right the car will use the premium to cause a MUCH better air/fuel mixture before the plug sparks the mixture. I would put it in ANY car. from what i understand also its alot cleaner on the motor and the parts also tend to last longer seeing as how the car has to work LESS to get a perfect mix to combust.
i would never recommend this but if u were to put regular in lets say a ss/sc or something that required it. 100% proven the car WILL misfire. or predetonate. the fuel will ignite purely from the compression. not from the spark plug sparking. if it means anyhting diesels dont have spark plugs as many ppl know, they just rely solely on compress diesel fuel and having it ignite without a spark . had a big like debate/question going on at school(uti) about diesel fuel and octane ratings with teachers and students. from what i remember i was told deisels have an octane of like 54? i think either way its VERY suceptable to detonating before a "spark" is needed hense the lack of plugs.
actually if you were to use octane to rate diesel, it would be much lower. more like 20 area. but diesel is measured in cetane.
also i use 87 in my car. i have run 93 and noticed no hesitation/jerking when i first get on it but i think with a cai (smooth transition) that will fix the issue. i was thinking possibly air flow disruption at the throttle body from the resonator.
but i also use shell. works well for me
Old Jun 30, 2007 | 12:11 AM
  #36
redSSBalt's Avatar
More octane means more power. Not true!! The octane number is a measure of a fuel's resistance to detonation, or knocking. High-performance, high-compression engines are more likely to detonate, and so require higher-octane fuels. However, the higher the octane, the slower the fuel burns, and you want the fuel to burn fast. But a fuel that burns too fst will also cause detonation, so you want to use the lowest octane number you can for your motor. This is some information from VP fuels.
Old Jun 30, 2007 | 12:29 AM
  #37
RaineMan's Avatar
Always premium... every time.
Old Jun 30, 2007 | 12:56 AM
  #38
redSSBalt's Avatar
Mine has had nothing but Sunoco 94 Ultra in it since I brought it home. The manual for the 2.4 recommends premium as well. Sunoco is also a Top Tier as well.
Old Jun 30, 2007 | 12:58 PM
  #39
shortshot's Avatar
what is the compression in the 2.4L ss??
Old Jul 1, 2007 | 10:06 PM
  #40
roccobladr's Avatar
i use 94 from sunoco? is that gonna be worse since its not 93?
Old Jul 2, 2007 | 01:23 AM
  #41
Pair-o-diceSS/SC's Avatar
Try with regular 87 @ $3.56 a gallon. 91 @ $3.76 a gallon. That's what we pay here in Hawaii. GM recommends certain things. Just like anything else. It's not necessary to run Premium in a stock SS/SC. But when you do the stage upgrades, your motor becomes high compression and then the need for premium is there.
Old Jul 2, 2007 | 01:28 AM
  #42
YellowSS06's Avatar
gas rises!!!
Well, I know that. But, with it being lower priced already, the price jump will even it out with where premium was. And I only mean an extreme jump in price. Like more than a quarter...unlikely, but that tends to be the trend in IL.
Old Jul 2, 2007 | 01:46 AM
  #43
AWDstylez's Avatar
To anyone that uses mid grade, can you PLEASE explain why?
If your car is so high output that it can't run on 87 then it definately needs the highest octane it can get. Why bother with a mid grade?
Old Jul 2, 2007 | 03:29 AM
  #44
SlifoxS's Avatar
Premium all the way, shell V-power to be specific
Old Jul 2, 2007 | 04:11 PM
  #45
redSSBalt's Avatar
I am with you on this comment!!!
Old Jul 3, 2007 | 12:40 AM
  #46
PuSha050's Avatar
hahahahahahha the compression of ur motor never changes
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
OrangeCoba
Sep 25, 2015 06:06 PM
