What makes a factory freak?
Old Aug 19, 2008 | 02:41 AM
XenSS06's Avatar
Originally Posted by FastSSinNH
I was at a dyno day not to long ago and saw a stock SS/SC put down 224.
That was mine i believe at SMG?
Yeah my sig has my stock numbers, a couple people at the meet said my car was a factorty freak. lol
My dyno sheets are on here somewhere from my 1st dyno when i got the car. I just threw out my 224 dyno sheet from the meet my daughter thought it was food. lol
Old Aug 19, 2008 | 05:26 AM
HunterKiller89's Avatar
A factory freak is basically a blueprinted engine. When building engines, everything has dimentions...obviously. Lets say for an ecotec (totally made up numbers btw), bore must be 86mm. What is deemed acceptable for this engine may be an engine with a bore of anywhere between 85.997 and 86.003mm. This exact number may be different with every cylinder, leaving various cylinders SLIGHTLY larger than others. The actual piston may have the exact same setup. A factory freak usually has a majority of its blueprint numbers very close to the exact desired number, such as everything in the above example being off by only .001mm It can be even better if say, the bore is .001mm larger than blueprint and the piston is also .001mm larger, so the ratio would be the same.
A common mod for engines is for them to be blueprinted to yield more power. Blueprinted 4cyl engines can yield up to 20bhp more than what they are rated for...depending upon the engine of course. Another plus side to this is usually longer engine life, as oil slipping past O rings and other miscellaneous wear items would be less frequent or less dramatic.
I'm not 100% on this, but this is what I read in one of my engine books
Old Aug 19, 2008 | 05:52 AM
hungryhip-ccp's Avatar
^^^ if there is a definition i would say that is it...
Old Aug 19, 2008 | 06:19 AM
El_diablos_SS/TC's Avatar
I had a stock2004 A4 GTO that ran 14 flat. Thats a factory freak...well I put High flow catless pipes, catback, CAI, and a diablo tune and all I got was a 14.3....Son of a bitch
Old Aug 19, 2008 | 06:26 AM
AROON02's Avatar
i had a 93 z28 that ran a 13.1 on 7 cylinders and also whipped some ass on the street, lol until i pulled the motor and built a real freak of nature RIP 93 camaro so sad
ps. that was on street tires and the car was an automatic
Old Aug 19, 2008 | 07:00 AM
MR.Pizza's Avatar
A particularly quick used Honda purchased at a car lot got the attention of the buyer after he beat several vehicles he had no business hanging with. Posted his experience on a car forum, after a few days of bs flame war someone asked him to check his engine code. Alas a quick glance revealed he had purchased a car with a complete 220hp engine swap (k24a2 vs 160hp stock k20a3). Turns out a former member of that forum had his car repo'd a few weeks before and was to ashamed to tell anyone. Not really a factory freak but a surprise for sure.
Old Aug 19, 2008 | 07:07 AM
Zekdemos's Avatar
i have one lol. when i was stock i raced stage 2 with full exhaust, 2.9 and bunch of other mods and i would stay with him. with exhaust and intake i can beat stage 2 with intake.
Old Aug 19, 2008 | 10:43 AM
Evil C's Avatar
my buddie had an auto 2001 blazer it ran 15.88s all day long stock. Most run between 16.2 and 16.4 stock.
Old Aug 19, 2008 | 10:52 AM
ilovecars's Avatar
i wonder if i have one....hmmmm
Old Aug 19, 2008 | 02:39 PM
an0malous's Avatar
none of the examples in here have proven factory freak.
all can be explained by dozens of simple variables you are all ignoring.
Old Aug 19, 2008 | 02:41 PM
  #36
BlackSS05's Avatar
numbers and times are based on various sources. Sea level type of dyno driver etc. Factory freaks dont exist.
Old Aug 19, 2008 | 02:42 PM
  #37
spike's Avatar
my car ran down stage 2 cars.....i only had 17" redline wheels and was stock......that would be a factory freak
Old Aug 19, 2008 | 02:57 PM
  #38
AROON02's Avatar
Apparently Not Lol According To Some People Its Impossible . Ha Like I Said 7 Cylinder Camaro Was A Monster And Even Faster With All 8 And It Had 142,xxx Miles On It Before The Build So I Guess It Just Aint True Is It ?
Old Aug 19, 2008 | 03:18 PM
  #39
an0malous's Avatar
nope
Old Aug 19, 2008 | 08:30 PM
  #40
leviticus88's Avatar
Originally Posted by theneelster
That's the way to create a factory dog Gotta free the beast!
I was being sarcastic...
factory freaks dont exist, the differences in cars that came off the same assembly line are so small that it wouldnt be noticeable.
Old Aug 19, 2008 | 08:40 PM
  #41
Mr McCabe's Avatar
Zekdemos on this board has a factory freak...
His car (when bone stock... 205hp) from a rolling race is dead even with my Stage 2 with a CAI. And he gave QuiksilverSS a real good run.
Old Aug 19, 2008 | 08:46 PM
  #42
pimpnwink's Avatar
switch drivers and determine then if you have a freak o and get rid of the junk in the trunk and ******* gas tank full of gas but no one though of that one
Old Aug 19, 2008 | 08:47 PM
  #43
Area47's Avatar
Rent me! per hour
tolerances on the bearings, rings, many different things come into play with this. no two sets of cams are exactly the same either.
  #44
ecotecon18s's Avatar
mine was a factory freak when it was stock...i used to race my buddys s/c regal and slowly pull away with S2, 2.85, full exhaust...after I totaled it and bought another ss/sc stock it would pull away harder from him that my old modded one did...
Old Aug 22, 2008 | 08:57 AM
  #45
CSM Huber's Avatar
Had one back in 1965...New 283 CI Chevelle with 4 barrel Carter with mechanical secondaries, and header type dual exhaust (not buckhorn) supposed to be 220 HP built on the last day of production. Would NOT idle smooth below 1000 RPM. Would pull 5,500 RPM in high gear -130+.... dealership mechanics thought it probably had a 327 high perf cam put in during production when a standard cam was not available.
Old Aug 22, 2008 | 09:04 AM
  #46
light'bolt's Avatar
urban legends.......
Old Aug 22, 2008 | 12:17 PM
  #47
Zekdemos's Avatar
we did switch cars quicksilverss had less gas actually. either way she works good if not better than any other stock ss ive seen or raced.
Old Aug 22, 2008 | 12:21 PM
  #48
1BADSS/SC's Avatar
Mine was a BIG TIME factory freak. Its floating around somewhere if someone didnt buy it yet. Last time I knew it was in OH.
I did a 40 mph run vs my friend, who at the time had more mods than me, and I pulled 3 cars by the top of 120 mph. My MAF was wacked out though, so sometimes my car acted funny.
Old Aug 22, 2008 | 12:25 PM
  #49
Zekdemos's Avatar
how is the csrt-4 doing? it a freak?
Old Aug 22, 2008 | 12:30 PM
  #50
1BADSS/SC's Avatar
not sure. Havent had any races yet . Im trying to get my friends stage 2 to race, but he needs work done on it.
