What Octane Gas Do You???
Old Apr 22, 2011 | 02:51 PM
Perfect.disguise's Avatar
112
Old Apr 22, 2011 | 06:36 PM
Achilles's Avatar
Originally Posted by Shibito
You won't make the rated 171hp without running premium.
I thought it was 173? Mine says 173.
Old Apr 22, 2011 | 06:40 PM
xodus's Avatar
93... reagardless you wont notice 2 hp lol
Old Apr 22, 2011 | 06:58 PM
BlackyK's Avatar
93, and only 93. I'd rather risk running out of gas than put $10 of 91 in to get me to the next reputable station that cares about having 93.
Old Apr 22, 2011 | 07:46 PM
alleycat58's Avatar
I was thinking about it, since Sunoco dumped 94, I guess they do have 91 at their old 4-grade pumps. But it's like 2 cents a gallon cheaper than 93. Why bother at that point?
Old Apr 22, 2011 | 08:05 PM
rukkee's Avatar
I really miss the old sunoco 94 and wish they would bring it back..... I ran a ton of it threw my old Z28.
Old Apr 22, 2011 | 11:21 PM
Whitnith's Avatar
Hope you don't travel very far from home then. 93 just isn't available some places, and it's not a matter of if the station is reputable or cares. Higher elevations don't need as much, and 91 is the highest you can get.
Old Apr 23, 2011 | 12:19 AM
87gn06gto07irl's Avatar
Originally Posted by 06SS ALL DAY
93 sunoco on weekdays 93 v-power shell on weekends
Why?
Old Apr 23, 2011 | 12:35 AM
redcobalt07's Avatar
Don't care.
Old Apr 23, 2011 | 01:34 AM
CordiaDOHC's Avatar
Originally Posted by pens2423
i have a bone-stock 2.4 and i use nothing but 93 from either bp/sunoco/shell depending on which of those is on the way to wherever i'm going at the time
93 here
Well there is no point in running 93 in a 2.4l, 91 would do just fine.
A lot of places (except shell) charge the same for 91 as 93.
waste. Maybe 89
89 actually is a horrible thing for a 2.4 to run. 87 would be better. But 91-93 is best.
It varies by year
Don't care.
Cool its your car if you dont care about it thats your business.
Though just by that statement alone I wouldnt buy anything from you. Because if you dont take care of your car then you probably wont take care of your parts or other stuff.
A 2.4 can run 87 or 91+ But theres a noticeable difference when running 91+
Old Apr 24, 2011 | 01:53 PM
  #36
BackInBlack's Avatar
94, 10% ethanol. FTW every time.
Old Apr 24, 2011 | 03:05 PM
  #37
xcross's Avatar
Korn
Old Apr 24, 2011 | 03:33 PM
  #38
TommyP's Avatar
AWD > FWD
Jiffy pop is ftw. Now I want popcorn.
Also, 93 only. Vpower ftw.
Old Apr 24, 2011 | 03:43 PM
  #39
RedStil's Avatar
87 2.2 it perfect even with a CAI
Old Apr 24, 2011 | 03:46 PM
  #40
Dart_SI's Avatar
91 is the highest where i live so i run that. i stay away from shell v-power tho. around here its garbage. i misfire a lot with it.
Old Apr 24, 2011 | 03:48 PM
  #41
Acey's Avatar
Doubtful
Then why'd they put it in the manual?
Owned. But really... why cheap out? It's such a little difference anyway.
Old Apr 24, 2011 | 04:09 PM
  #42
H3 Proto's Avatar
The highest I can get here is 91 or 92, depending on the gas station. I don't go any lower.
Old Apr 24, 2011 | 04:26 PM
  #43
N1ckateen's Avatar
93 all day everyday. i prefer v power, but i'll take a bp where it has individual pumps for each octane that way when i select 93 i get all 93 not 93 and then some leftover 87 from the last user.
Old Apr 24, 2011 | 04:27 PM
  #44
cranemaster's Avatar
Originally Posted by Martel18SS
Even stock it's premium only...
Wrong, optional when your stock.
  #45
Achilles's Avatar
Thats a little bit silly, it is more of an ego scratch then anything.. I baby my girl and I have no problem putting in 91 because after 10< heptane the amount of compressed air before it ignites is near identical. But hey, if it is close to the same price, good on ya..
Don't care.
Real quick;
The number of Octane (the best fuel to handle compression) needed for best MPG is almost ALWAYS what the manufacturer tells you in your manual. For 2.4l and 2.0l Engines it recommends 91+ because they are high performance engines, the compression stroke (where the engine compresses a cylinder-full of air and gas into a much smaller volume before igniting it with a spark plug. ) in our vehicles recommends a compression ratio to keep the vehicle running smoothly. The octane rating of the gasoline you put in your car, tells you how much the fuel can be compressed before it spontaneously ignites. When it ignites from compression instead of the spark plugs, it causes knocking in the engine. Refer to the "DON'T USE CHEAP GAS, ON A HIGH PERFORMANCE ENGINE, YOU CHEAP MOTHE.." above or how they put it (more politticaly correct) "Use premium unleaded gasoline with a posted octane rating of 91 or higher." ANYWAYS back to what I was saying.. When you hear knocking, you are playing Russian roulette with your engine and unless you want to save "dollars" which *ahem* is causing worse mileage (BTW, because the compression ratio is too low and their is too much heptane [the other fuel used with Octane-> 87 octane, 13 heptane etc..). Well you are shaving "pennies" off, getting shittier gas mileage and potentially causing 1000's of dollars of damage to your engine.. oh and you are causing your vehicle to perform shitty.
Can you elaborate please? I Know some places like MacEWEN usually throw in Ethanol in their blend of 89 which is really not good for our high performance engines (unless it is tuned for it), the general concept of Ethanol is that it is more economically friendly.. works good in Economy Cars.
Old Apr 24, 2011 | 04:39 PM
  #46
Achilles's Avatar
Wrong, if you have SS/Sport you should run 91+. There is nothing else to be said.. if you were a bodybuilder would you eat at McDonald's? This isn't a debate, it is science. 91 + Octane should go in your vehicle.
EDIT: Sorry for the double post!
  #47
ericgt79's Avatar
i only buy gas at shell and i only buy 93
Old Apr 24, 2011 | 04:49 PM
  #48
emiller's Avatar
You are talking about 1/10's of a gallon when you are putting 10-12 gallons in your car. You can probably get that much variation in octane ratings just by going to a different pump.
Old Apr 24, 2011 | 06:09 PM
  #49
Sunburst's Avatar
91 Minimum. Over the course of a year its not that much of a difference.
Old Apr 24, 2011 | 08:05 PM
  #50
alleycat58's Avatar
If you want to get technical, he's actually correct. It's Premium Recommended, not Premium Required. That being said, it's pretty damn stupid NOT to run premium in the 2.4 or 2.0 motors, because like you said that's what it's designed to run. That and if you can't afford the extra $3.60 per tank that it costs to put premium in, then you probably bought the wrong car. The knock sensor will adjust for a lower octane gas, so you CAN put regular or mid-grade in and run it............it'll just run like absolute ****. Now, as soon as you flash a tune on the car, that goes out the window, then premium is required.
