What Octane Gas Do You???
Old Apr 24, 2011 | 08:17 PM
  #51
Achilles's Avatar
Originally Posted by alleycat58
If you want to get technical, he's actually correct. It's Premium Recommended, not Premium Required. That being said, it's pretty damn stupid NOT to run premium in the 2.4 or 2.0 motors, because like you said that's what it's designed to run. That and if you can't afford the extra $3.60 per tank that it costs to put premium in, then you probably bought the wrong car. The knock sensor will adjust for a lower octane gas, so you CAN put regular or mid-grade in and run it............it'll just run like absolute ****. Now, as soon as you flash a tune on the car, that goes out the window, then premium is required.
I disagree, if something is making the vehicle perform badly.. then it is required. He could put water in the car if he wanted, nobody is making him put a certain Octane blend in the vehicle. That being said in the manual it says "USE" 91+ and then it says "May also" it is just being vague. If you are saying "The cobalt will move on 90< octane" well you are correct, but is it worth risking your engine to save a few bucks? If so.. sell your car and get an economy car.
The knock sensor should not adjust actually, the amount of air compression will eventually cause the engine to spark prematurely. It wouldn't make sense if this dude ran 87-89 and the knock sensor adjusted to higher heptane reading and lower compression, it doesn't work that way unless your sensor needs replacing or GM rushed that part of the car, the KS should always stay linear to a certain air compression ratio.
Old Apr 24, 2011 | 10:24 PM
  #52
CordiaDOHC's Avatar
Originally Posted by Achilles
Can you elaborate please? I Know some places like MacEWEN usually throw in Ethanol in their blend of 89 which is really not good for our high performance engines (unless it is tuned for it), the general concept of Ethanol is that it is more economically friendly.. works good in Economy Cars.
Wish I could remember the thread. Pretty much the 2.4 can run on 87 or 91+ but a few members had issues on 89. From how they described what happens it sounds like the computer cant quite figure out 89. And that causes issues. So I tell 2.4 guys to run premium or if they dont have access to it then just to run 87. The car can run 87 but doesnt run nearly as well and on my car at least I do notice a 2-3mpg drop during the same loop of driving. (compared 4 tanks of 87 during similar weather)
Old Apr 24, 2011 | 10:44 PM
  #53
SherlockHolmeSS's Avatar
So can I just switch to premium or what?
Old Apr 24, 2011 | 11:08 PM
  #54
Achilles's Avatar
You should be on Premium, period.
Unless you aren't in an SS.
Old Apr 24, 2011 | 11:26 PM
  #55
CordiaDOHC's Avatar
2.0/2.4 Recommended premium by the owners manual.
2.2 run 87
So just switch to premium
Old Apr 24, 2011 | 11:31 PM
  #56
G5GT2007's Avatar
93 in my 2.4.
Old Apr 24, 2011 | 11:51 PM
  #57
Yeah I'm a 2.4 SS, I'm just asking if I can just start using premium...like is **** going to get messed up if there is other gas in the tank?
Old Apr 24, 2011 | 11:53 PM
  #58
2.2 run 87
^^thanks for the info man
Old Apr 25, 2011 | 12:03 AM
  #59
CordiaDOHC's Avatar
No problem. Ive switched a few times (during a short road trip the station only had 87 and 89). And once when I switched back to see what the con was of running 87. Im currently back on 93.
Old Apr 25, 2011 | 08:56 AM
  #60
alleycat58's Avatar
Give it a tank or two to really notice a difference, it's not going to be like a night and day difference right away, but you'll definitely be happier with the car running premium.
  #61
emiller's Avatar
No it won't hurt anything. Just fill up with the correct gas and you are good to go.
Old Apr 25, 2011 | 09:00 AM
  #62
RoadconeTuning's Avatar
93... it still has midrange knock on 93 and i'd run the "95" we had if they still offered it... found out it was really 100 octane and oxygenated lol.
Old Apr 25, 2011 | 09:02 AM
  #63
cmatthewb101's Avatar
Step 1 - Read the manual
Step 2 - Do what it says and you won't have knock
Step 3 - /thread
Old Apr 25, 2011 | 12:26 PM
  #64
12andy's Avatar
Sunoco 94
Absolutely LOVE butting into "OMG it costed me X amount to fill up today" conversations, which are typically expressed by those topping up with 87 octane on engines that sip gas even when hammered.
Old Apr 25, 2011 | 12:49 PM
  #65
Staged07SS's Avatar
Administrator
Administrator
Sunoco Ultra 93 (Daily Driving)
Sunoco 260GT100/CAM2 (for fun), Yes I'm tuned for it
Old Apr 25, 2011 | 05:52 PM
  #66
fakameanrepresent's Avatar
i run 12 octane. yup, 12.
Old Apr 26, 2011 | 02:52 PM
  #67
Calibrah's Avatar
87 in my care. runs fine. sometimes ill splurge on 89
Old Apr 26, 2011 | 03:08 PM
  #68
Rissa's Avatar
100.
Old Apr 26, 2011 | 04:28 PM
  #69
CordiaDOHC's Avatar
Did you not read above? for 2.4s its recommended to be on premium and 89 isnt a good idea. Not trying to be a dick here but it is recommended and they do run a lot better on 91+.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
