what is seafoaming?
Old Jan 14, 2010 | 02:26 PM
cobraceralt's Avatar
what is seafoaming?
what exactly does it do? is it actual foam? why would you wanna do i to it to your car?
Old Jan 14, 2010 | 02:35 PM
exiged's Avatar
its a liquid and it cleans the engine and makes lots of smoke!
Fonzi1289's Avatar
I am wondering the same thing
Old Jan 14, 2010 | 02:36 PM
Tazman89's Avatar
i think it is supposed to clean the carbon buildup in you intake but im not sure
Old Jan 14, 2010 | 02:38 PM
PSHHH's Avatar
https://www.cobaltss.net/forums/show...hlight=seafoam
search is your friend
Old Jan 14, 2010 | 02:45 PM
HunterKiller89's Avatar
its a strong chemical compound that is supposed to loosen up a lot of the carbon deposits that get stuck in your engine (on valves, piston surfaces, etc). Basically, its a cmehical cleaner or your engines insides
go visit seafoam.com or w/e their site is
Old Jan 14, 2010 | 02:49 PM
ls1fbody's Avatar
Haz l33t wheelz.
It tastes awesome.
Old Jan 14, 2010 | 02:50 PM
ive seen videos on youtube of seafoaming and the one i saw the smoke white. doesnt oil and build up like burn black? or is that the "seafoam" burning off?
Old Jan 14, 2010 | 03:15 PM
NCC-2000's Avatar
I've seafoamed both my Cobalt and my Sunbird. Both smoked like a bitch. The smoke looks all white but up close you can tell that it's more than just the seafoam itself burning off. It does clean a lot of **** out of the engine as the idle on my Sunbird was much better after I cleaned it out. The only trick is finding the right vacuum line to use to suck the seafoam into the engine.
Old Jan 16, 2010 | 04:45 PM
given that the smoke coming out is light grey, and that normal emmisions are clear, it should be easy to tell stuff is coming out. carbon burns black, oil burns bluish, but most of the smoke is caused by water vapor sticking to the carbon deposits coming out of the tailpipe
Old Jan 20, 2010 | 11:14 AM
xxxxsh4d0wxxxx's Avatar
It's good ****. Suck 1/3 in to the brake booster, and 2/3 into the gas tank.
Old Jan 20, 2010 | 01:37 PM
exiged's Avatar
the can says 1/3 brake booster, 1/3 oil, 1/3 gas tank.
Old Jan 20, 2010 | 01:44 PM
HatedCobalt's Avatar
http://www.youtube.com/watch?v=D11ZV...layer_embedded
Old Jan 20, 2010 | 02:52 PM
Well, I personally only put oil in my crankcase. You may use the seafoam in there, but make sure to change your oil within 100 miles.
If you change your oil every 3,000 like I have since I first got the car with 1 mile on it, that motor should be spotless, no need for seafoam in there. The fuel system gets more benefit out of it.
Old Jan 20, 2010 | 02:55 PM
G85 SS's Avatar
http://www.youtube.com/watch?v=JQYVl...om=PL&index=32
Cleans yo car out yo!!
Old Jan 28, 2010 | 12:26 AM
mofofernando's Avatar
just did it today and oil change of course. car seems a bit smoother and slightly more responsive
Gremlin85
How to Guide
65
Jan 30, 2025 01:19 PM
Chevycobaltss3
How to Guide
99
May 27, 2012 07:21 PM
Nacademus
Nov 7, 2010 10:13 PM
AROON02
Jun 18, 2009 12:41 AM
