what should i do
Old Oct 31, 2014 | 11:41 PM
bnutz's Avatar
what should i do
Ok soo what should I do my 2006 cobalt ss/sc is about to hit 60,000 miles
what kind of maintenance should I do and performance
Old Nov 1, 2014 | 01:33 AM
UnkleRaRa's Avatar
Fluids check/swap/top up. Brake check/job. Air filter check/change. Check plugs and wires. Rust check. Check bushings, control arms, tie rods/suspension components. Check belts. Inspect exhaust. Check for fuel leaks, mainly under drivers side near seat. Check/change wiper blades. Check/change bulbs. Tighten any loose bolts found back to spec. Vacuum. Armorall. Wash. Wax. lol
Basically just fine tooth comb everything and if anything odd stands out, ask for some help if you need to.
Old Nov 1, 2014 | 10:58 AM
bnutz's Avatar
Sweet thank you sir
Old Nov 1, 2014 | 11:01 AM
Yup i would say check all your suspension/brakes/steering stuff. For sure change your fluids oil/transmission/coolant/wiper fuild etc
Old Nov 7, 2014 | 09:30 AM
insylem's Avatar
Just hit 90 with mine.
Old Nov 7, 2014 | 09:33 AM
blueLNFftw's Avatar
Mod it!
Old Nov 7, 2014 | 09:46 AM
X2 mod it
Make sure your intercooler pump is working too
Old Nov 7, 2014 | 05:04 PM
Foximus's Avatar
Fluids, Plugs, check belt, also check all your radiator and heater core lines. Not so much for milage, but for age. If they are really squishy, its a good time to swap em all out for new ones.
Old Nov 12, 2014 | 12:57 PM
bnutz's Avatar
Sounds good and what kind of mods
Old Nov 12, 2014 | 12:59 PM
Haven07's Avatar
Tvs 1900
Old Nov 12, 2014 | 01:57 PM
bnutz's Avatar
Sounds good if I had the money
Old Nov 12, 2014 | 03:35 PM
oh also def replace your vacuum lines if they are looking all cracked up like most are.
tell us what your cash net allows for and we can point you in the right direction mods wise.
Old Nov 13, 2014 | 09:46 PM
Pretty sure the owners manual shows what maintenance to do on the car
Old Nov 13, 2014 | 09:52 PM
06_cobalt's Avatar
Don't forget to change your fuel filter. Most people never do it. And clean your throttle body.
Old Nov 14, 2014 | 12:09 AM
bnutz's Avatar
I have a new throttle body ordered and I'm probably at 300-400 a month for play money
Old Nov 14, 2014 | 08:17 AM
Haven07's Avatar
Best thing you can do is figure out what do you want to use the car for, how much power you want, and how much your willing to spend. Then go from there.
Personally I'd start with an option b install and look at the supporting mods first before going for power.
Old Nov 14, 2014 | 08:36 AM
Staged07SS's Avatar
Administrator
Administrator
60k is nothing to worry about....
My car is at 59800 (parked for the winter), so close enough to 60k.
While I upgraded a lot of parts on my car, the remaining factory items are still like the day I drove her home brand new.
Just check things like your air filter, fuel filter, cabin filter, suspension components, and should be set.
Old Nov 15, 2014 | 09:25 AM
yellowsupercharged06's Avatar
Im at 66k in mine, daily driven all year round. Although ive replaced everything on it that you mentioned, it has been going great.
E85 /fully bolted/2.8 pulley/full suspension and she is really fun.
You should have nothing major to worry about just little maintenance things.
Old Nov 15, 2014 | 09:41 AM
Lucky you
Old Nov 18, 2014 | 07:17 AM
Staged07SS's Avatar
Administrator
Administrator
Lucky you
Old Nov 18, 2014 | 09:02 AM
TurboTechRacing's Avatar
Wow nice low miles!!! I would get some basic mods on it too Have some fun with it, it is young yet.
