where to get tsb's
Old Feb 12, 2006 | 07:09 PM
selfinfliction's Avatar
where to get tsb's
if anyone has access to tsb's can you look up these #'s to see which one is the correct one:
it's a tsb for clunking in the steering i got off of nhtsa's website, but it doesn't give very much info.
TSB# 3687
NHTSA ITEM# 10016948
or
TSB# 050232005A
NHTSA ITEM# 10017497
i was trying to find out exactly what the issue was because i need to take it in for the issue, usually tsb's aren't important, but when there's something making a clunking noise on the suspension, it worries me a bit lol
Old Feb 12, 2006 | 07:27 PM
here's all the tsb info on the 2.0L 2005 cars for anyone needing them:
Component Description:
1. STEERING
Bulletin Number: 050232005A
Bulletin Date: NOV 2005
Vehicle: 2005 Chevrolet Cobalt
Summary:
EI05093 - CLUNK IN STEERING SYSTEM AT SLOW SPEEDS WHILE TURNING AND/OR DRIVING OVER BUMPS. ( NHTSA ITEM NUMBER - 10017497 )
2. POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Bulletin Number: 050730016
Summary:
TRANSMISSION CONTROL MODULE (TCM) SHORTED TO BATTERY VOLTAGE DURING DIAGNOSIS AND/OR SERVICE. ( NHTSA ITEM NUMBER - 10017512 )
3. EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Bulletin Number: 050138016
Summary:
WATER LEAKING ON FRONT PASSENGER SIDE FLOOR OF VEHICLE, WATER BLOWING OUT OF VENTS (SEAL HEATER CORE COVER). ( NHTSA ITEM NUMBER - 10018663 )
4. VISIBILITY
Bulletin Number: 050864035
Summary:
LEFT OR RIGHT MANUAL MIRROR CONTROL INOPERATIVE (REPLACE PLASTIC CONTROL TOWER. 2005 PONTIAC PURSUIT. ( NHTSA ITEM NUMBER - 10018697 )
5. STRUCTURE:BODYOOR
Bulletin Number: 050864030A
Summary:
INTERIOR DOOR HANDLE INOPERATIVE OR CLICKING NOISE HEARD WHEN OPENING DOOR. ( NHTSA ITEM NUMBER - 10017765 )
6. STRUCTURE:BODY
Bulletin Number: 050898002
Bulletin Date: OCT 2005
Summary:
LAMINATED STEELS - GENERAL INFORMATION AND SPECIFIC REPAIR PROCEDURES FOR HINGE PILLAR BODY REPLACEMENT-FRONT INNER, RAIL REPLACEMENT FRONT COMPARTMENT-FRONT AND WHEELHOUSE REPLACEMENT-FRONT. ( NHTSA ITEM NUMBER - 10017376 )
7. WHEELS
Bulletin Number: 050310001A
Bulletin Date: SEP 2005
Summary:
16 INCH ACCESSORY WHEELS AVAILABLE THROUGH GMSPO. *TT
8. SEATS:FRONT ASSEMBLY:SEAT HEATER/COOLER
Bulletin Number: 050850011
Summary:
REVISED FRONT HEATED SEAT CONTROL MODULE REPLACEMENT. TT
9. POWER TRAIN:AUTOMATIC TRANSMISSION:LEVER AND LINKAGE:FLOOR SHIFT
Bulletin Number: 050729006
Summary:
SHIFT CONTROL KNOB LOOSE OR DETACHED FROM SHIFT CONTROL LEVER. ( NHTSA ITEM NUMBER - 10017827 )
10. EQUIPMENT:ELECTRICAL
Bulletin Number: 050849025
Summary:
ADDITION OF SUPERCHARGER BOOST AIR PRESSURE INDICATOR REPLACEMENT PROCEDURE. *TT
11. WHEELS
Summary:
16 INCH ACCESSORY WHEELS AVAILABLE THROUGH GMSPO. ( NHTSA ITEM NUMBER - 10014979 )
12. EQUIPMENT
Bulletin Number: 050846006A
Summary:
INFORMATION ON UPGRADING CERTAIN ONSTAR GENERATION 5 ANALOG/DIGITAL-READY SYSTEMS TO ONSTAR GENERATION 6 DUAL-MODE (ANALOG/DIGITAL). ( NHTSA ITEM NUMBER - 10015018 )
13. TIRES
Bulletin Number: 709
Summary:
PERFORMANCE TIRES. GM TECH LINK. ( NHTSA ITEM NUMBER - 10018102 )
14. SEATS:FRONT ASSEMBLY:SEAT HEATER/COOLER
Summary:
REVISED FRONT HEATED SEAT CONTROL MODULE REPLACEMENT. TT ( NHTSA ITEM NUMBER - 10017498 )
15. EQUIPMENT:ELECTRICAL
Summary:
ADDITION OF SUPERCHARGER BOOST AIR PRESSURE INDICATOR REPLACEMENT PROCEDURE. ( NHTSA ITEM NUMBER - 10017425 )
16. STEERING
Summary:
EI05093 - CLUNK IN STEERING SYSTEM AT SLOW SPEEDS WHILE TURNING AND/OR DRIVING OVER BUMPS. *TT
17. WHEELS
Bulletin Number: 050310011
Bulletin Date: AUG 2005
Summary:
18 INCH ACCESSORY WHEELS AVAILABLE THROUGH GMSPO. *TT
18. ENGINE AND ENGINE COOLING
Bulletin Number: 050601003A
Summary:
HIGHER THAN EXPECTED OIL CONSUMPTION BLUE SMOKE ON ACCELERATION. *EH
19. STRUCTURE:BODY
Summary:
LAMINATED STEELS - GENERAL INFORMATION AND SPECIFIC REPAIR PROCEDURES FOR HINGE PILLAR BODY REPLACEMENT-FRONT INNER, RAIL REPLACEMENT FRONT COMPARTMENT-FRONT AND WHEELHOUSE REPLACEMENT-FRONT. *TT
20. WHEELS
Summary:
18 INCH ACCESSORY WHEELS AVAILABLE THROUGH GMSPO. ( NHTSA ITEM NUMBER - 10017364 )
21. ENGINE AND ENGINE COOLING
Summary:
HIGHER THAN EXPECTED OIL CONSUMPTION BLUE SMOKE ON ACCELERATION. ( NHTSA ITEM NUMBER - 10013473 )
22. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 050730015
Bulletin Date: JUN 2005
Summary:
HARD TO SHIFT OR SELECT VEHICLE GEAR, SHIFTER STICKS/BINDS/JAMS. PONTIAC PURSUIT (CANADA) 2005-2006. *TT
23. POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
TRANSMISSION CONTROL MODULE (TCM) SHORTED TO BATTERY VOLTAGE DURING DIAGNOSIS AND/OR SERVICE. *TT
24. POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
HARD TO SHIFT OR SELECT VEHICLE GEAR, SHIFTER STICKS/BINDS/JAMS. PONTIAC PURSUIT (CANADA) 2005-2006. ( NHTSA ITEM NUMBER - 10017537 )
25. ELECTRICAL SYSTEM:WIRING
Bulletin Number: 05046
Bulletin Date: MAY 2005
Summary:
A/C SYSTEM WIRING AND DUAL STAGE AIRBAG MODULE WIRING. *TT
26. ELECTRICAL SYSTEM:WIRING
Summary:
A/C SYSTEM WIRING AND DUAL STAGE AIRBAG MODULE WIRING. ( NHTSA ITEM NUMBER - 10016003 )
27. EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Bulletin Number: 050138005
Bulletin Date: MAR 2005
Summary:
AIR CONDITIONING (A/C) SYSTEM NOT COLD ENOUGH, NOISY A/C COMPRESSOR. *TT
28. VISIBILITY:WINDSHIELD WIPER/WASHER:MOTOR
Bulletin Number: 050857002
Summary:
WATER ON PASSENGER FLOOR/BLOWER MOTOR INOPERATIVE. *TT
29. WHEELS
Summary:
30. VISIBILITY:WINDSHIELD WIPER/WASHER:MOTOR
Summary:
WATER ON PASSENGER FLOOR/BLOWER MOTOR INOPERATIVE. ( NHTSA ITEM NUMBER - 10015031 )
31. EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Summary:
AIR CONDITIONING (A/C) SYSTEM NOT COLD ENOUGH, NOISY A/C COMPRESSOR. ( NHTSA ITEM NUMBER - 10014972 )
32. SERVICE BRAKES, HYDRAULIC:ANTILOCK
Bulletin Number: 702
Bulletin Date: FEB 2005
Summary:
ANTI-LOCK BRAKING SYSTEM (ABS) CODE U2108. GM TECH LINKS. *TT
33. STRUCTURE:BODYOOR:HINGE AND ATTACHMENTS
Bulletin Number: 050864005
Summary:
DOOR HANDLE STICKS WHEN AMBIENT TEMPERATURES ARE BELOW 0 DEGREES C (32 DEGREES F). *TT
34. STRUCTURE:BODY
Bulletin Number: 050849002
Summary:
FUEL GAUGE ACCURACY AND OR FUEL GAUGE FLUCTUATION FUEL GAUGE DOES NOT GO TO FULL. THIS INCLUDES 2005 PONTIAC PURSUIT. ( NHTSA ITEM NUMBER - 10013485 )
35. STRUCTURE:BODYOOR:HINGE AND ATTACHMENTS
Summary:
DOOR HANDLE STICKS WHEN AMBIENT TEMPERATURES ARE BELOW 0 DEGREES C (32 DEGREES F). ( NHTSA ITEM NUMBER - 10017454 )
36. SERVICE BRAKES, HYDRAULIC:ANTILOCK
Summary:
ANTI-LOCK BRAKING SYSTEM (ABS) CODE U2108. GM TECH LINKS. ( NHTSA ITEM NUMBER - 10016373 )
37. STRUCTURE:BODY
Bulletin Date: JAN 2005
Summary:
FUEL GAUGE ACCURACY AND OR FUEL GAUGE FLUCTUATION FUEL GAUGE DOES NOT GO TO FULL. THIS INCLUDES 2005 PONTIAC PURSUIT. *EH
38. ELECTRICAL SYSTEM
Bulletin Number: 050525001
Summary:
INFORMATION ON A FALSELY SET DTC U2108 IN ENGINE CONTROL MODULE. THIS INCLUDES 2005 PONTIAC PURSUIT. *EH
39. VISIBILITY:WINDSHIELD WIPER/WASHER
Bulletin Number: 701
Summary:
PULSE WIPER OPERATION. ( NHTSA ITEM NUMBER - 10015761 )
40. ELECTRICAL SYSTEM
Summary:
INFORMATION ON A FALSELY SET DTC U2108 IN ENGINE CONTROL MODULE. THIS INCLUDES 2005 PONTIAC PURSUIT. ( NHTSA ITEM NUMBER - 10013468 )
41. FUEL SYSTEM, OTHER
Summary:
FUEL FILTER REPLACEMENT. GM TECH LINK. ( NHTSA ITEM NUMBER - 10015762 )
42. FUEL SYSTEM, OTHER
Summary:
FUEL FILTER REPLACEMENT. GM TECH LINK. *TT
43. VISIBILITY:WINDSHIELD WIPER/WASHER
Summary:
PULSE WIPER OPERATION. *TT
44. ELECTRICAL SYSTEM
Bulletin Number: 612
Bulletin Date: DEC 2004
Summary:
SIR LAMP BEING DISPLAY AND CODES B0012 AND B0013 WITH SYMPTOM CODE 0E. GM TECH LINK. *TT
45. ELECTRICAL SYSTEM
Summary:
SIR LAMP BEING DISPLAY AND CODES B0012 AND B0013 WITH SYMPTOM CODE 0E. GM TECH LINK. ( NHTSA ITEM NUMBER - 10015779 )
46. EXTERIOR LIGHTING:HEADLIGHTS
Bulletin Number: 04100
Bulletin Date: NOV 2004
Summary:
NON COMPLIANCE RECALL #04100. THE SHIELDS INSIDE OF THE HEADLAMPS CAN LOOSEN DURING A VIBRATION TEST. TO INCLUDE 2005 PONTIAC PURSUIT. *TT PRODUCT FIELD ACTION ANNOUNCEMENT. *TT
47. OTHER
Bulletin Number: 11122004
Summary:
STOP DELIVERY ORDER OF ALL 2005 CHEVROLET COBALT MODEL VEHICLES. ( NHTSA ITEM NUMBER - 10011955 )
48. EXTERIOR LIGHTING:HEADLIGHTS
Summary:
NON COMPLIANCE RECALL #04100. THE SHIELDS INSIDE OF THE HEADLAMPS CAN LOOSEN DURING A VIBRATION TEST. TO INCLUDE 2005 PONTIAC PURSUIT. ( NHTSA ITEM NUMBER - 10011562 )
49. OTHER
Summary:
STOP DELIVERY ORDER OF ALL 2005 CHEVROLET COBALT MODEL VEHICLES. *TT
50. EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL
Bulletin Number: 040089055
Summary:
PDI AND SERVICE GUIDE. *EH
51. EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL
Summary:
PDI AND SERVICE GUIDE. ( NHTSA ITEM NUMBER - 10012752 )
52. STRUCTURE:BODYOOR
Bulletin Number: 610
Bulletin Date: OCT 2004
Summary:
DOOR UPPER FRONT TRIM PANEL. GM TECH LINK. *TT
53. STRUCTURE:BODYOOR
Summary:
DOOR UPPER FRONT TRIM PANEL. GM TECH LINK. ( NHTSA ITEM NUMBER - 10015772 )
54. ENGINE AND ENGINE COOLING:ENGINE
Bulletin Number: 0804
Bulletin Date: AUG 2004
Summary:
OIL LIFE SYSTEM RESET PROCEDURES - CARS. *NM
55. ENGINE AND ENGINE COOLING:ENGINE
Summary:
OIL LIFE SYSTEM RESET PROCEDURES - CARS. ( NHTSA ITEM NUMBER - 10014346 )
56. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 3235
Bulletin Date: JAN 2001
Summary:
ENGINEERING INVESTIGATION ON THE NEW TRANSMISSION CONTROL MODULE. *EH
57. VISIBILITYEFROSTER/DEFOGGER SYSTEM:WINDSHIELD:BLOWER
Bulletin Number: 3316A
Summary:
WATER HAS BEEN FOUND TO BE ENTERING THE HVAC CASE THROUGH THE COWL. *TT INVENTORY UPGRADE BULLETIN 05032. *TT UPDATE. *TT
58. ENGINE AND ENGINE COOLING:ENGINE
Bulletin Number: 3269
Summary:
SERVICE ENGINE SOON (SES) LIGHT, MISFIRE AND VALVETRAIN TICK. *TT
59. ENGINE AND ENGINE COOLING
Bulletin Number: 3457
Summary:
SERVICE ENGINE SOON (SES) LIGHT ON OR VARIOUS DRIVEABILITY CONCERNS. ALSO TO INCLUDE 2005 PONTIAC PURSUIT. *TT
60. POWER TRAIN
Bulletin Number: 3441
Summary:
4T40E/4T45E HARD TO SHIFT. *TT
61. ENGINE AND ENGINE COOLING:ENGINE
Bulletin Number: 3404A
Summary:
MACHINING DEBRIS ON THE OIL FILTER ELEMENT. *SC
62. SERVICE BRAKES, HYDRAULIC:ANTILOCK
Bulletin Number: 3635
Summary:
NO COMMUNICATION WITH ANTI-LOCK BRAKING SYSTEM AFTER EBCM REPLACEMENT. TO INCLUDE 2006 CHEVROLET HHR. *TT
63. ELECTRICAL SYSTEM:FUSES AND CIRCUIT BREAKERS
Bulletin Number: 3385A
Summary:
REPEATED PARK LPS FUSE OPEN (ADDITIONAL INFORMATION). *TT
64. POWER TRAIN
Summary:
4T40E/4T45E HARD TO SHIFT. ( NHTSA ITEM NUMBER - 10017062 )
65. ENGINE AND ENGINE COOLING:ENGINE
Bulletin Number: 3433
Summary:
SERVICE ENGINE SOON (SES) LIGHT AND SEVERE ENGINE MISFIRE ON CYLINDERS 1 AND 4 OR CYLINDERS 2 AND 3. ( NHTSA ITEM NUMBER - 10017032 )
66. SERVICE BRAKES, HYDRAULIC:ANTILOCK:ABS WARNING LIGHT
Bulletin Number: 3412
Summary:
BRAKE SYSTEM WARNING LIGHT ILLUMINATES AT TIMES. ( NHTSA ITEM NUMBER - 10017240 )
67. ENGINE AND ENGINE COOLING:ENGINE
Bulletin Number: 3410
Summary:
CHECK ENGINE LIGHT (MIL) ON. THE ENGINE MAY NOT CRANK OVER. DIAGNOSTIC TROUBLE CODES P0443, P0102, P0036, P0030, P0135, P0101 MAY BE SET. ( NHTSA ITEM NUMBER - 10017236 )
68. ENGINE AND ENGINE COOLING:ENGINE
Summary:
MACHINING DEBRIS ON THE OIL FILTER ELEMENT. ( NHTSA ITEM NUMBER - 10016822 )
69. ENGINE AND ENGINE COOLING
Bulletin Number: 3323
Summary:
HIGHER THAN EXPECTED OIL CONSUMPTION BLUE SMOKE ON ACCELERATION. TO INCLUDE 2005 OLDSMOBILE ALERO. ( NHTSA ITEM NUMBER - 10017198 )
70. ENGINE AND ENGINE COOLING:ENGINE
Bulletin Number: 3310D
Summary:
SERVICE ENGINE SOON (SES) LIGHT DUE TO A P0171 - INSPECT AIR INTAKE AND OIL DIPSTICK. ( NHTSA ITEM NUMBER - 10017261 )
71. FUEL SYSTEM, OTHER:STORAGE:FUEL GAUGE SYSTEM
Bulletin Number: 3274
Summary:
INACCURATE AND/OR ERRATIC FUEL GAUGE OPERATION. ( NHTSA ITEM NUMBER - 10017206 )
72. ENGINE AND ENGINE COOLING:ENGINE
Bulletin Number: 3269B
Summary:
TICK NOISE AND MISFIRE DUE TO BROKEN VALVE SPRINGS. ( NHTSA ITEM NUMBER - 10017219 )
73. ELECTRICAL SYSTEM
Bulletin Number: 3506A
Summary:
INCORRECT MILEAGE DISPLAYED AFTER PROGRAMMING A NEW BCM. VARIOUS MODELS INCLUDING 2005 - 2006 PONTIAC PURSUIT (CANADA ONLY). ( NHTSA ITEM NUMBER - 10018530 )
74. ELECTRICAL SYSTEM
Bulletin Number: 3492
Summary:
SERVICE ENGINE SOON (SES) LIGHT AT HIGHWAY SPEEDS DUE TO A P0171 DIAGNOSTIC TROUBLE CODE (DTC). ( NHTSA ITEM NUMBER - 10017021 )
75. ELECTRICAL SYSTEM
Bulletin Number: 3421B
Summary:
ENGINE STALLS, LOSS OF ELECTRICAL SYSTEMS, AND NO DIAGNOSTIC TROUBLE CODE (DTC). INCLUDING 2005-06 PONTIAC PURSUIT. ( NHTSA ITEM NUMBER - 10014807 )
76. EXTERIOR LIGHTING
Bulletin Number: 3393A
Summary:
BACKLIGHTING IS INOP DURING DAYLIGHT CONDITIONS (HEADLIGHT SWITCH TURNED ON MANUALLY) ( NHTSA ITEM NUMBER - 10017006 )
77. EXTERIOR LIGHTING
Summary:
BACKLIGHTING IS INOPERATIVE DURING DAYLIGHT CONDITIONS (HEADLIGHT SWITCH TURNED ON MANUALLY). ( NHTSA ITEM NUMBER - 10017222 )
78. ELECTRICAL SYSTEM:FUSES AND CIRCUIT BREAKERS
Summary:
REPEATED PARK LPS FUSE OPEN (ADDITIONAL INFORMATION). ( NHTSA ITEM NUMBER - 10016549 )
79. AIR BAGS
Bulletin Number: 3356
Summary:
SIR LIGHT ON WITH CODES B0012 AND B0013. INCLUDING THE 2005 PONTIAC PURSUIT. ( NHTSA ITEM NUMBER - 10013542 )
80. EXTERIOR LIGHTING:BRAKE LIGHTS
Bulletin Number: 3347
Summary:
BRAKE LIGHTS INOPERATIVE WITH KEY IN THE OFF POSITION. ( NHTSA ITEM NUMBER - 10017199 )
81. VISIBILITYEFROSTER/DEFOGGER SYSTEM:WINDSHIELD:BLOWER
Summary:
WATER HAS BEEN FOUND TO BE ENTERING THE HVAC CASE THROUGH THE COWL. ( NHTSA ITEM NUMBER - 10013375 )
82. VISIBILITY:SUN ROOF ASSEMBLY
Bulletin Number: 3688
Summary:
SUNROOF SWITCH BEZEL FALLS FROM THE HEADLINER. ( NHTSA ITEM NUMBER - 10017263 )
83. ELECTRICAL SYSTEM
Bulletin Number: 3512
Summary:
SERVICE ENGINE SOON (SES) LIGHT DUE TO A P1182 DIAGNOSTIC TROUBLE CODE - POTENTIAL CAUSES AND ISSUES. TO INCLUDE 2006 SATURN ION. ( NHTSA ITEM NUMBER - 10016533 )
84. VEHICLE SPEED CONTROL
Bulletin Number: 3510
Summary:
SUPPLEMENT TO 05-06-01-003A - WRONG THROTTLE GASKET PART NUMBER. ( NHTSA ITEM NUMBER - 10016520 )
85. STRUCTURE
Summary:
WATER LEAK ON FRONT FLOORBOARD AND OR BLOWER MOTOR INOPERATIVE. ( NHTSA ITEM NUMBER - 10017168 )
86. ELECTRICAL SYSTEM
Summary:
DIAGNOSTIC TROUBLE CODE P0420 MAY SET ON LOW MILEAGE VEHICLES, OR SHORTLY AFTER CATALYTIC CONVERTER REPLACEMENT. ( NHTSA ITEM NUMBER - 10017210 )
87. EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Bulletin Number: 3315A
Summary:
POOR AIR CONDITIONER PERFORMANCE. TO INCLUDE 2005 PONTIAC PURSUIT. ( NHTSA ITEM NUMBER - 10013507 )
88. ELECTRICAL SYSTEM
Bulletin Number: 3261B
Summary:
(RETAINED ACCESSORY POWER) RAP DEACTIVATES FROM DRIVERS DOOR ONLY. ( NHTSA ITEM NUMBER - 10018551 )
89. ENGINE AND ENGINE COOLING
Bulletin Number: 3786
Summary:
NO START AFTER ENGINE HARNESS REPLACEMENT (NON-ABS). ( NHTSA ITEM NUMBER - 10018600 )
90. SUSPENSION
Bulletin Number: 3687
Summary:
BULLETIN-SIT-BULLETIN-1703838: CLUNK NOISE FROM FRONT OF VEHICLE DURING TURNING MANEUVER. ( NHTSA ITEM NUMBER - 10016948 )
91. ENGINE AND ENGINE COOLING:EXHAUST SYSTEM
Bulletin Number: 3644
Summary:
MOMENTARY SAG ON LIGHT TO MODERATE ACCEL WHEN COLD - VALVE DEPOSITS. ( NHTSA ITEM NUMBER - 10018532 )
92. SUSPENSION:REAR
Bulletin Number: 3641A
Summary:
REAR SUSPENSION SQUAWK/SQUEAK OVER BUMPS. ( NHTSA ITEM NUMBER - 10018563 )
93. SERVICE BRAKES, HYDRAULIC:ANTILOCK
Summary:
NO COMMUNICATION WITH ANTI-LOCK BRAKING SYSTEM AFTER EBCM REPLACEMENT. TO INCLUDE 2006 CHEVROLET HHR. ( NHTSA ITEM NUMBER - 10016534 )
94. FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY:FILLER PIPE AND CAP
Bulletin Number: 3627
Summary:
FUEL TANK IS SLOW TO FILL AND/OR DTC P0446 - INSPECT EVAP VENT PIPE. THE SES LAMP MAY BE ILLUMINATED DUE TO A P0466 DTC. ( NHTSA ITEM NUMBER - 10018624 )
95. FUEL SYSTEM, OTHER
Bulletin Number: 3531
Summary:
HIGH FUEL PRESSURE - POSSIBLE FUEL FILTER CONCERN. ( NHTSA ITEM NUMBER - 10017248 )
96. FUEL SYSTEM, OTHER
Bulletin Number: 3509
Summary:
EVAP FILLER NECK ADAPTER GE41415-50 MAY NOT FIT - USE J41415-40 IF NECESSARY. ( NHTSA ITEM NUMBER - 10016519 )
97. ENGINE AND ENGINE COOLING
Bulletin Number: 3482
Summary:
CHECK ENGINE LIGHT, P0532, P0533, P2138, P1681, OR A/C INOPERATIVE (UPDATE). ( NHTSA ITEM NUMBER - 10017396 )
98. ENGINE AND ENGINE COOLING
Summary:
SERVICE ENGINE SOON (SES) LIGHT ON OR VARIOUS DRIVEABILITY CONCERNS. ALSO TO INCLUDE 2005 PONTIAC PURSUIT. ( NHTSA ITEM NUMBER - 10014892 )
99. ENGINE AND ENGINE COOLING:ENGINE
Bulletin Number: 3448
Summary:
DIAGNOSTIC TROUBLE CODE P2138 - INFORMATION SUPPLEMENT FOR BULLETIN 05-01-38-006. ( NHTSA ITEM NUMBER - 10017087 )
100. POWER TRAIN
Bulletin Number: 3447
Summary:
4T40E OR 4T45E WILL NOT SHIFT NO DIAGNOSTIC TROUBLE CODES. ( NHTSA ITEM NUMBER - 10017086 )
101. ENGINE AND ENGINE COOLING:ENGINE
Summary:
SERVICE ENGINE SOON (SES) LIGHT, MISFIRE AND VALVETRAIN TICK. ( NHTSA ITEM NUMBER - 10013526 )
102. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 3253A
Summary:
VEHICLE WILL NOT MOVE IN EITHER DIRECTION. TRANSMISSION MAY SHOW OVER FULL. P90 4T40E 4T45E NO MOVEMENT DRIVE OR REVERSE. CONVERTER MAY BE EMPTY OF FLUID. ( NHTSA ITEM NUMBER - 10017096 )
103. POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
ENGINEERING INVESTIGATION ON THE NEW TRANSMISSION CONTROL MODULE. ( NHTSA ITEM NUMBER - 10011720 )
104. ENGINE AND ENGINE COOLING:ENGINE
Summary:
SERVICE ENGINE SOON (SES) LIGHT DUE TO A P0171 - INSPECT AIR INTAKE AND OIL DIPSTICK. *TT
105. VISIBILITY:SUN ROOF ASSEMBLY
Summary:
SUNROOF SWITCH BEZEL FALLS FROM THE HEADLINER. *TT
106. FUEL SYSTEM, OTHER
Summary:
HIGH FUEL PRESSURE - POSSIBLE FUEL FILTER CONCERN. *TT
107. ENGINE AND ENGINE COOLING
Summary:
CHECK ENGINE LIGHT, P0532, P0533, P2138, P1681, OR A/C INOPERATIVE (UPDATE). *TT
108. ENGINE AND ENGINE COOLING:ENGINE
Summary:
DIAGNOSTIC TROUBLE CODE P2138 - INFORMATION SUPPLEMENT FOR BULLETIN 05-01-38-006. *TT
109. POWER TRAIN
Summary:
4T40E OR 4T45E WILL NOT SHIFT NO DIAGNOSTIC TROUBLE CODES. *TT
110. ENGINE AND ENGINE COOLING:ENGINE
Summary:
SERVICE ENGINE SOON (SES) LIGHT AND SEVERE ENGINE MISFIRE ON CYLINDERS 1 AND 4 OR CYLINDERS 2 AND 3. *TT
111. SERVICE BRAKES, HYDRAULIC:ANTILOCK:ABS WARNING LIGHT
Summary:
BRAKE SYSTEM WARNING LIGHT ILLUMINATES AT TIMES. *TT
112. ENGINE AND ENGINE COOLING:ENGINE
Summary:
CHECK ENGINE LIGHT (MIL) ON. THE ENGINE MAY NOT CRANK OVER. DIAGNOSTIC TROUBLE CODES P0443, P0102, P0036, P0030, P0135, P0101 MAY BE SET. *TT
113. EXTERIOR LIGHTING
Summary:
BACKLIGHTING IS INOP DURING DAYLIGHT CONDITIONS (HEADLIGHT SWITCH TURNED ON MANUALLY) *SC
114. EXTERIOR LIGHTING:BRAKE LIGHTS
Summary:
BRAKE LIGHTS INOPERATIVE WITH KEY IN THE OFF POSITION. *TT
115. ENGINE AND ENGINE COOLING
Summary:
HIGHER THAN EXPECTED OIL CONSUMPTION BLUE SMOKE ON ACCELERATION. TO INCLUDE 2005 OLDSMOBILE ALERO. *TT
116. STRUCTURE
Summary:
WATER LEAK ON FRONT FLOORBOARD AND OR BLOWER MOTOR INOPERATIVE. *SC
117. EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Summary:
POOR AIR CONDITIONER PERFORMANCE. TO INCLUDE 2005 PONTIAC PURSUIT. *TT
118. FUEL SYSTEM, OTHER:STORAGE:FUEL GAUGE SYSTEM
Summary:
INACCURATE AND/OR ERRATIC FUEL GAUGE OPERATION. *TT
119. ENGINE AND ENGINE COOLING:ENGINE
Summary:
TICK NOISE AND MISFIRE DUE TO BROKEN VALVE SPRINGS. *TT
120. POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
VEHICLE WILL NOT MOVE IN EITHER DIRECTION. TRANSMISSION MAY SHOW OVER FULL. P90 4T40E 4T45E NO MOVEMENT DRIVE OR REVERSE. CONVERTER MAY BE EMPTY OF FLUID. *TT
121. ELECTRICAL SYSTEM
Summary:
DIAGNOSTIC TROUBLE CODE P0420 MAY SET ON LOW MILEAGE VEHICLES, OR SHORTLY AFTER CATALYTIC CONVERTER REPLACEMENT. *TT
122. SUSPENSION
Summary:
BULLETIN-SIT-BULLETIN-1703838: CLUNK NOISE FROM FRONT OF VEHICLE DURING TURNING MANEUVER. *SC
123. EXTERIOR LIGHTING
Summary:
124. FUEL SYSTEM, OTHER
Summary:
EVAP FILLER NECK ADAPTER GE41415-50 MAY NOT FIT - USE J41415-40 IF NECESSARY. *TT
125. VEHICLE SPEED CONTROL
Summary:
SUPPLEMENT TO 05-06-01-003A - WRONG THROTTLE GASKET PART NUMBER. *TT
126. ELECTRICAL SYSTEM
Summary:
SERVICE ENGINE SOON (SES) LIGHT DUE TO A P1182 DIAGNOSTIC TROUBLE CODE - POTENTIAL CAUSES AND ISSUES. TO INCLUDE 2006 SATURN ION. *TT
127. ELECTRICAL SYSTEM
Bulletin Number: 3421A
Summary:
ENGINE STALLS, LOSS OF ELECTRICAL SYSTEMS, AND NO DIAGNOSTIC TROUBLE CODE (DTC). INCLUDING 2005 PONTIAC PURSUIT. *TT *SC
128. ELECTRICAL SYSTEM
Summary:
SERVICE ENGINE SOON (SES) LIGHT AT HIGHWAY SPEEDS DUE TO A P0171 DIAGNOSTIC TROUBLE CODE (DTC). *TT
129. ELECTRICAL SYSTEM
Summary:
130. AIR BAGS
Summary:
SIR LIGHT ON WITH CODES B0012 AND B0013. INCLUDING THE 2005 PONTIAC PURSUIT. *TT
131. EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Summary:
satisfied
Oct 19, 2015 12:35 AM
Adam144
Sep 3, 2015 07:48 PM
revready
Aug 30, 2015 11:04 PM
jbounce
Aug 29, 2007 09:27 PM
