Where to put coolant
Old Jan 20, 2008 | 02:20 PM
lindstromderek's Avatar
I noticed on our cars, and before you think im an idiot, for not knowing where coolant goes, i know theres the certain reservoir, up by the left hand strut, but whats the coolant tank and tubes for that runs into the supercharger, and it has a fill cap, so do i need to put coolant in there as well? im getting ready to install the radiator and all the coolant and was just curious where all goes, and is it still 50/50 into the supercharger as well? thank you
Old Jan 20, 2008 | 02:22 PM
They call me 'E''s Avatar
You can use that little fill neck iirc, it's all one cooling system.
Old Jan 20, 2008 | 02:24 PM
o alright, so if i put all the coolant in the one by the supercharger, i should be alright, or all the one in the big reservoir
Old Jan 20, 2008 | 02:25 PM
M-Dub's Avatar
Well you have the coolant tank (looking at the engine bay) on the top right side of the engine bay. That is your engine coolant tank, there is a small tank in the front basically mounted to the core support, that is your coolant for the heat exchanger.
If that didn't answer your questions... sorry you need to be more clear on what you are doing.
and yes the 50/50 mix Dex-Cool is what you need! Or for the heat exchanger you can use a mixture of more water than antifreeze too, get some better cooling effects that way!
Old Jan 20, 2008 | 02:38 PM
Cobalt_SSTuner's Avatar
yep what he said, just make sure you dont put coolent in your blinker fluid. If that happens, your going to have issues then
Old Jan 20, 2008 | 02:41 PM
Kaisoboy's Avatar
If these are the questions you have to ask then i suggest you a) do some more research. b) get help from some one that knows what they are doing.
Are you installing a new heat exchanger or adding another one?
cheers
Old Jan 20, 2008 | 02:59 PM
YSUsteven's Avatar
This is why cars come with owners manuals.
Old Jan 20, 2008 | 03:03 PM
an0malous's Avatar
nope
they are separate.
you dont want 180* engine coolant flowing through your supercharger cooling system.
that would HEAT the air not cool it lol.
you have to monitor the level of each system separately.
Old Jan 20, 2008 | 03:08 PM
outtamymind's Avatar
what anom said. and as for adding more water then coolant to the heat exchanger res. i wouldn't suggest if you intend to drive your car in the winter months.
Old Jan 20, 2008 | 03:29 PM
Originally Posted by an0malous
nope
they are separate.
Err, oops.
My mistake.
Old Jan 20, 2008 | 03:42 PM
Kaisoboy's Avatar
OK...So what is he installing. A radiator, condenser, heat exchanger, what? What application is he doing or did I miss something.
Old Jan 20, 2008 | 03:48 PM
Sharpie's Avatar
He is changing the rad
Old Jan 20, 2008 | 03:51 PM
Kaisoboy's Avatar
Ok. Just asking cause it really does not sound like he knows what he is doing. Just trying to look out for a fellow member.
cheers
Old Jan 20, 2008 | 03:52 PM
CJ BadBlackSS's Avatar
oh my. subscribed!
Old Jan 20, 2008 | 03:54 PM
rallyracer's Avatar
idk why but Im lost
Old Jan 20, 2008 | 04:08 PM
Kaisoboy's Avatar
That's what I'm saying. in the OP he is talking about 2 separate systems but does not clearly state which one he is replacing.
hmmm...
Old Jan 21, 2008 | 10:15 AM
rnjmur's Avatar
I'd like to know too, is he actually replacing the radiator? If so why is it being replaced? Or, is he adding or replacing the H/E? As far as coolant - yes there are 2 seperate cooling systems. The coolant tank by the driver side strut tower is the engine coolant reservoir and the fill cap at the front of the car by the SC is the H/E / Intercooler coolant fill.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
Stuff
Oct 1, 2015 05:47 PM
riceburner
Sep 26, 2015 12:57 AM
