Why do people run a step colder?
Old Oct 15, 2014 | 07:00 PM
no_ss's Avatar
Why do people run a step colder spark plugs? I've always wondered.
Old Oct 15, 2014 | 07:07 PM
06cobaltncng's Avatar
because racecar
Old Oct 15, 2014 | 07:08 PM
turbocharged717's Avatar
because racecar
Old Oct 15, 2014 | 07:12 PM
Olybaltss's Avatar
Since spark plugs must remove heat and a modified engine makes more heat, the spark plug must remove more heat. A colder heat range spark plug must be selected and plug gaps should be adjusted smaller to ensure proper ignitability in this denser air/fuel mixture.
Typically, for every 75-100 hp you add, you should go one step colder on the spark plug's heat range. A hotter heat range is not usually recommended except when severe oil or fuel fouling is occurring.
hope that helps OP.
Old Oct 15, 2014 | 07:13 PM
no_ss's Avatar
Originally Posted by Olybaltss
Since spark plugs must remove heat and a modified engine makes more heat, the spark plug must remove more heat. A colder heat range spark plug must be selected and plug gaps should be adjusted smaller to ensure proper ignitability in this denser air/fuel mixture. Typically, for every 75-100 hp you add, you should go one step colder on the spark plug's heat range. A hotter heat range is not usually recommended except when severe oil or fuel fouling is occurring. hope that helps OP.
the exact answer I was looking for thanks
Old Oct 15, 2014 | 07:26 PM
show off.
Old Oct 15, 2014 | 07:42 PM
Olybaltss's Avatar
I didn't know the technical answer and have been curious myself, so i looked it up and was helpful rather than giving a useless response. Not really showing off, NGK gave me the answer.
Old Oct 15, 2014 | 07:54 PM
it was a joke lol.
Old Oct 15, 2014 | 08:37 PM
Still good to know though. Had to laugh at race car though.
Old Oct 15, 2014 | 08:40 PM
thats why I said it lol. im like super exhausted and that was the first thing that came to mind.
Old Oct 15, 2014 | 08:50 PM
Blowncavy's Avatar
Olybaltss actually took the time to search. Like others should
Old Oct 16, 2014 | 04:57 PM
Olybaltss's Avatar
it was a joke lol.
My bad, apparently I was a little PMSy yesterday.
Nice car, by the way; orange is the best.
Old Oct 16, 2014 | 10:21 PM
Spawne32's Avatar
Increased combustion pressure from increasing horsepower in turn increases cylinder temperatures. Plug's are designed to dissipate their captured heat into the surrounding material of the cylinder head. The heat range is determined by the amount of insulation of the ceramic surrounding the electrode. For a colder burning cylinder/low horsepower motor, the plug is insulated further towards the tip so that the plug reaches its operating temperature. If you increase the temperature inside the cylinder and the plug is no longer able to maintain its operating temperature, the plug can melt. Typically you can determine if your plug is cold or hot by looking at the discoloration on the threads on a new recently ran plug with some miles on it. Ideally you want the first 3 threads to be slightly discolored. If no threads are discoloring then typically the plug is cold, if the discoloration is further up the plug typically its running hot. There are other things you can also look at on a plug to determine this as well.
Old Oct 17, 2014 | 07:31 AM
Staged07SS's Avatar
Administrator
Administrator
Please see the everything you need to know about spark plugs thread....
06MetallicBalt
Jul 20, 2025 08:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
