Wideband A/F Gauge or Aeroforce scan ?
Can you just get one? or do they both do completely opposite things? If getting just one which one? 500-600 gauges is alot
, so trying not to get both. Thanks~!
thanks, makes sense to me
! and the interceptor just plugs in to your cpu/code reading port right?
would this be fine?
http://cgi.ebay.com/ebaymotors/INNOV...spagenameZWDVW
or is there a certain type i should look for?
also it looks like you have to have a harness to plug into it, will the interceptor come with the right one?
would this be fine?
would this be fine?
would this be fine?
thats a great wideband sensor(its a bosh they make dam good stuff)
the only part i could see possibly being a problum os finding what wires from the sensor plug into the intercepter so the gauge will read.
I'm sure somebody on here has it done or will know what wire to use but the sensor will work
yea thats my concern.... is how we are going to plug it in..
Same here. I get my gauge either today and tomorrow and it would be really helpful if we could hook up a wideband 02 sensor to the gauge. Someone should email aeroforce and ask them if it's possible. Right now I'm in school so I can't.
where do you plug in the interceptor?? same spot you check for codes?
Well get a meter and go under the car. I have yet to look at the O2 sensor yet so I dont know how many wire it is but if its a 4 wire then you have 2 grounds and a heater wire and then a signal wire. If its a 3 wire you have 1 ground instead.
this all depends on why you are getting these gauges. unless you are using the wideband o2 sensor to tune your car, don't bother spending the money, just get the interceptor gauge. if, however, you have a moderately modded car (i.e. 2.8" or smaller pulley w/ 42.5lb/hr injectors) i would recommend getting a wideband o2 sensor and plug it into the interceptor gauge. the aeroforce interceptor gauge comes equpped to read your a/f from you stock narrowband o2 sensor which is not accurate at all.
