Wideband A/F Gauge or Aeroforce scan ?
Old May 24, 2006 | 01:37 PM
memphisr24's Avatar
So if you bought a WB O2 sensor, installed it, would you be able to hook it up to the aeroforce gauge?
Old May 24, 2006 | 01:58 PM
Rusty's Avatar
I am like 90% sure that you can do that. There was a post about a month or so back about using a wideband with the aeroforce gauge. Search for it.
Old May 24, 2006 | 04:03 PM
06black's Avatar
ughhhh.....
YES YES YES if you but a intercepter and a WB02 you can hook them togather.
heres where i got a little unsure about things....i dont know if you connect the sensor directly to the gauge or if some for of a control module has to be used to interpit the sensor and transform that signal in to the 0-5volt signal the intercepter gauge reads.
CobaltBurst----the 02sensor has to be heated because they dont work worth a DAM untill there HOT HOT HOT!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
no_ss
Oct 18, 2015 11:58 PM
n20saturn
Sep 30, 2015 12:26 AM
