Wideband A/F Gauge or Aeroforce scan ?
Originally Posted by memphisr24
So if you bought a WB O2 sensor, installed it, would you be able to hook it up to the aeroforce gauge?
ughhhh.....
YES YES YES if you but a intercepter and a WB02 you can hook them togather.
heres where i got a little unsure about things....i dont know if you connect the sensor directly to the gauge or if some for of a control module has to be used to interpit the sensor and transform that signal in to the 0-5volt signal the intercepter gauge reads.
CobaltBurst----the 02sensor has to be heated because they dont work worth a DAM untill there HOT HOT HOT!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
n20saturn
Sep 30, 2015 12:26 AM
