Interior: 3 Gauge A Pillar Install w/ Dual Interceptors
The fitment for the interceptor gauges in the top 2 holes were a little snug. But with enough finagling I was able to get both to fit and align the way I wanted. I was also able to attach the back support but I had to push on the front of the gauge to hold it in place while I attached the back support to keep it in place. Hope this helps.
Everyone puts the stock boost in the normal position, can you buy any matching aftermarket boost gauge to fill that spot or is that sized only to fit the OEM boost gauge??
they really only make the bottom one to fit the aem gauges. when they are installed they are probablly more angled twords the driver the other gauges are. the tc gauges are the cn gauges. i run 3 of these.
So is it possible to have the stock boost gauge along with AEM Wideband in this pod? From what I've gathered, the two are the same size and will only fit in the bottom hole. Will I have to do some modifications to a hole in order to fit both gauges? Any help or links would be great
#36
I just installed my Aeroforce gauges tonight and noticed the same problem. The bezels keep the gauges from sitting flush in the pod. What I did was open the holes up a little with the dremel, then cut one of legs of the metal brackets a little shorter (1 cm) than the other and bent it inward. What that does is allow the bracket to make flush contact with the rear of the pod, and pull the gauge in when you tighten the nuts. I'll try to get some pics up tomorrow. They're almost perfectly flush now.
#41
Thanks for the descriptive thread, I just got my zzperformance triple pod today. I am gonna install it here soon. I do have a question though, when installing the AEM eugo did you guys weld a bung onto your dp? Or just wire it directly into the cars o2 or obd2?
#42
get a bung welded.
#45
I wired mine into the pink wire on my boost gauge (Thats the boost gauge power wire)
#47
