All Engines: another way to reset your oil life %
Old Jul 20, 2007 | 02:31 AM
creepySS's Avatar
I figured out another way to reset the oil life % here are the steps:
1.put the ignition "on" position but don't start the car.
2.press the accelerator pedal more than 2 times in a row.
3.your oil life will be @ 100%
Note:When you do this procedure the info display does not need to be in the oil life % can be any where!
Let me if this works on others cars hope this was useful!
Old Jul 26, 2007 | 02:24 PM
Halfcent's Avatar
I'm old school
Approved, but I would like somebody to try this.
Old Jul 26, 2007 | 02:26 PM
SKDR112888's Avatar
It works I did this on a cobalt when I used to work at Merchants
Old Jul 26, 2007 | 06:45 PM
outtamymind's Avatar
just so you all know that works with alot of cars, pretty much every gm car that has an OLM you can use the accelerator to reset it, the only difference is some cars take 5 steps on the gas and others take 3. i work at a gm dealership in the shop so i should know lol.
Old Jul 26, 2007 | 09:31 PM
Black07LS's Avatar
That's how I reset mine.
Old Jul 26, 2007 | 09:37 PM
HackAbuse's Avatar
oh **** really? I dick around with the throttle like that on mine all the time, dammit
now I have no idea when i need to change my oil. Greattttttt
Old Jul 26, 2007 | 09:38 PM
REIGN SS's Avatar
Original Hayden Fanatic
...that might explain why mine randomly reset to 100% once, hmmm.
Old Jul 26, 2007 | 09:39 PM
red2006SS's Avatar
have done this every time i change the oil. i think you have to pedal it like five times or something. i forget but does work
Old Jul 26, 2007 | 11:38 PM
invisible's Avatar
i thought that was the only way to do it.
Old Jul 26, 2007 | 11:58 PM
siracing's Avatar
I know it works because mine reset when I was installing the pedal covers and replacing the throttle pedal.
Old Jul 27, 2007 | 02:03 AM
Omega_5's Avatar
That's how I do it...
Then again, I'm used to the work trucks... this is easier to with them...
Old Jul 27, 2007 | 02:15 AM
KlutchSS's Avatar
meh....so i assume i shouldent go by the reading on there since i just bought my car...time for a oil change.
Old Jul 27, 2007 | 05:21 AM
ecotecon18s's Avatar
The other way is to turn the key to run but dont start the car and push and hold the 2 DIC buttons at the same time for a few seconds and release. Then you can fiddle with the OLM, if the horn honks/lights flash with the keyless, and other things. Check it out sometime...
Old Jul 27, 2007 | 05:25 AM
REIGN SS's Avatar
^^That is how it is explained in the manual....
Old Jul 27, 2007 | 06:04 AM
xspyder85x's Avatar
thanks for this, the dealer didnt reset it when they changed my oil
Old Jul 27, 2007 | 08:46 AM
RedEcotecSS's Avatar
ya, i discovered this the other day. pretty cool little feature. you gotta press it like 3 times and it resets.
Old Jul 28, 2007 | 08:18 AM
the sad thing is that ive had my oil changed at the dealer countless times (under service contract) and so many times they forgot to reset the OLM. Hell, that could have been done when they got in the car to bring it back to the front... lazy asses... lol
Old Jul 28, 2007 | 01:14 PM
Bandit2941's Avatar
Mike, cool to see you made it here.
Are you up for taking your SS to Lebanon Valley one Weds for street night? I've been going on occasion.
Jamie D
Old Jul 28, 2007 | 01:16 PM
chevysalesman614's Avatar
dude, it says how to do it in the manual.. why didnt you read it?
Old Jul 29, 2007 | 12:25 AM
siracing's Avatar
Jamie D
Hey Jamie...
I didn't even go out there for the open.. haha. Epping's only an hour away and a much better track (and quicker) so I'll take it up there in the fall when the air gets good and see if it'll touch the 13's.
Later!
............ Mike
Old Jul 29, 2007 | 11:48 AM
Bandit2941's Avatar
Hey Jamie...
Later!
............ Mike
Forgot you were so close to Epping! What's the valley for you, like 2 and a half? I didn't make it up there for the open this weekend either.
You should have the power for 13s with your stage 2 and good air, but getting it to 60' will be the hard part. Tough to find the sweet spot between wheel hop, bogging it, and slipping the clutch too much in these Cobalts.
Old Jul 29, 2007 | 06:51 PM
Mr_Slobalt's Avatar
yep, hit the pedal 3 x's
Old Jul 29, 2007 | 06:55 PM
Coblt ss super's Avatar
would this work on my honda accord, with the maitnence required light? if so imma go try it
Old Jul 29, 2007 | 06:58 PM
Mr_Slobalt's Avatar
^ nope, hold the trip button in then start the car or turn to RUN (I believe) and wait until it flashes, let off
if that didn't work, repeat the process and after you release it once it starts flashing, press it again for 5 seconds and let off
Old Jul 29, 2007 | 07:01 PM
Originally Posted by Mr_Slobalt
^ no, I'm not 100% sure if it's like Toyota...I was thinking it was.....hold the trip button in then start the car and wait until it goes out
if not in your owner's manual, you may have to go to Honda
you might be right on that, not sure tho, so u hold the trip button down when u start the car?
