Appearance: Dual projector Gen 4 headlights
Old Apr 11, 2011 | 02:53 PM
Urban Rogue's Avatar
Ok so here is my how to on this little project. I hope its descriptive enuf. if I forgot anything well I Hope I didnt. if you have issues I will help where I can.
Remove the Headlight lens - I put the headlight on a cookie sheet and set it in the oven. 200 degrees for 10-12 minutes. seemed to pull away nicely. just try to pull it away and not have the goo drop back onto the lens or the inside parts. Adds to clean up later if you dont. Spend the time once its all apart to clear the channel of all the left over seal. as You will be using new stuff.
This is what you will be left with.
you will need to pull the chrome insert out. You will see that it is held in at 3 locations. the top is just the adjuster screw. unscrew that all the way. the other 2 locations are on the bottom of the insert.
You need to pry these off but be carefull not to snap them off.
Remove the Projector from the insert and then cut out the high beam side just on the inside where it starts to go inward.
Will look like this.
Next fit your new shroud into the cut out high beam location. Should look like this.
Since the stock projector will now be the hgh beam you will need to remove its cut off shield. unscrew and remove that portion. then reatach like image below.
Attach the bezezel to the projector. since it was not made for each other I used JBWeld or 5 min epoxy to hold it together. Then place the shroud withthe projector into the cut out location and attach it there using 5 Minute epoxy. like the image below.
You now need to install your second projector. I used the Mirrimotto mini projector. however the holes do not line up to where the original projector went. I went and got some little washers to level it up again and some aluminum flat bar I used to cut up and drill holes into to make new brackets. Like the image below. Be sure to make sure you put this back in with the cut off leveled out.
Once that is done you will have a part that looks like this.
Snap the part back onto the headlight assembly and put the cover back over and you will have this.
If you put the high beam projector out as far as I did your back end should look like this. showing that the rubber covers will go back on. If you did not put them out as far as I did then you will run into the problem of the High beam projector sticking out the back to far thus not allowing the rubber cover to go back on once the bulb is inserted.
Put the lenses back on. U used Butle tape that I got from theretrofitsource.com I think it was. same idea as taking them off. put the butle tape in the channel where the lens goes. place the lens over it and push on as good as you can ensuring the tabs line up. then stick in oven at 200 degrees for 10 minutes. then push it right on and make sure the tabs connect.
install and run. I am using HID's in both projectors. please refer to HID install elsewhere
Low beam
High beams
Old Apr 12, 2011 | 09:24 PM
J-Jeezy's Avatar
Looks sick! Great job.... Now for me to do my Gen 1s. How did you get the his and lows to stay on at the same time?
Old Apr 12, 2011 | 09:38 PM
DiabeticKripple's Avatar
probably spliced a wire somewhere
Old Apr 12, 2011 | 10:03 PM
Since I used a 9007 Harness adapter that came with the new projectors I spliced the wire into the high beam wire for the driver side.
for the passenger side I used the stock 9007 harness wires to attach the turn signal and the high beam to that side.
Old Apr 12, 2011 | 10:04 PM
BPacak's Avatar
Vtec Rep
damn that was fast
Old Apr 12, 2011 | 10:13 PM
tpete763's Avatar
looks 10X better like this
Old Apr 12, 2011 | 10:14 PM
drumrush's Avatar
I've thought about doing this. Looks great man
Old Apr 12, 2011 | 10:15 PM
Black SS/SC 06's Avatar
looks good
Old Apr 12, 2011 | 10:32 PM
MastaShaKe_88's Avatar
gyaaaaaa theses are sick! I'm thinking of doin up some gen 3s like this...
Old Apr 12, 2011 | 10:36 PM
chrisjaldin's Avatar
he's right
Old Apr 13, 2011 | 09:23 AM
snoftall's Avatar
Awesome.
Old Apr 13, 2011 | 09:40 AM
RooTBeeR's Avatar
click
Old Apr 14, 2011 | 01:07 AM
tpete763's Avatar
do you have any nighttime shots with both the high and low beams on?
Old Apr 14, 2011 | 07:41 AM
Will take one tonight. still got to aim the passenger side. I can see its a tad high when driving. probably pissing ppl in front of me off
Old Apr 14, 2011 | 10:52 PM
hard to grab a pic. they are bright.
and its an iphone 4 camera.
High beams all 4 on
Low beams
will see if my Canon D60 can grab a better shot tomorrow
Last edited by Urban Rogue; Apr 14, 2011 at 10:52 PM. Reason: Automerged Doublepost
Old Apr 15, 2011 | 12:13 AM
tpete763's Avatar
they look bright as hell even with the iphone pics. can you get some of sitting in the car, I bet you can see 20x better at night now too.
Old Apr 15, 2011 | 12:23 AM
NCC-2000's Avatar
I made a set that was left chrome to better suit my car.
Old Apr 17, 2011 | 04:51 AM
Boz1285's Avatar
OP, which shroud did you use with your highs?
Old Apr 21, 2011 | 04:51 PM
SSmatters's Avatar
Those are some sexy headlights... dayum.
Old May 1, 2011 | 08:51 PM
Old May 1, 2011 | 08:54 PM
BPacak's Avatar
Vtec Rep
seems really low but looks damn good haha
Old May 1, 2011 | 09:10 PM
Omnigear's Avatar
how did u aim them?
Old May 1, 2011 | 09:57 PM
they are not aimed yet LOL im lazy.
just found a nice wall so I stopped to grab a pic
Old May 1, 2011 | 10:10 PM
BPacak's Avatar
Vtec Rep
i went like 2 weeks without aiming mine haha, due to alot of rain and laziness. drove with them pointing straight at the ground, thats how it seemed anyways haha
Old May 2, 2011 | 02:53 PM
Baron7700's Avatar
look like gatlings
