Interior: Hinow41 led button mod
Here is my How too
This video will show you how to change the steering wheel controls lights
How to change stock switch lights - YouTube
Lol yeah theres to much **** in it. Allot of it is from when my dad pasted away. I have no idea what to do with it.
I was board today and just shot it. I only did one take. lol
I don't have a link i did the mod like over a year ago. People have been asking left and right so I threw something together. The leds are 3mm 12v Google it you will find a company that has them. For soldering.its only the ones on the dash and window controls. The steering wheel you just wrap the wire around the brown piece just like the stock ones are. Its a pain in the ass but it works.
Does the dimmer switch light up stock? Mine isn't on, and I took it to the dealer to replace the bulb and they said that it never lights up. I've had the car 2 months and I can't think if it was lit or not.
I should come up there one day and have you install blue ones for me
You did a great job!
Thanks.
The dimmer switch does not light up. You could make it but its not really worth it. You would have to dill a hole in it and then put a Led in and then tap a fuse to get it to turn on when the others do.
I most likely will be down in OC, MD for the meet on June 6th. You gonna be there?
ok so i tried doing the mod and ending up burning 2 of the 3 leds up lol. so what i want to know is what size led you use? i used 3mm low intensity size t-1 3volt 15mA, and can i put them in any way or is there a pos and neg?
Yeha i did those too. The bulbs should be conected to something very similar. Just have to twist it out and then connect the new bulbs. I did this mod a long time ago and I don't have my car right now so I can't look. I will try and get you a 100% answer soon.
ah nvm I fig it out. See on the bottom. That little plastic holding the bulb take that out and then just work the nexbulb in.
. Did red? Glad you like
