Interior: How To: Add Aux Input to pre '07 Cobalts
Old Dec 31, 2009 | 01:53 PM
  #76
jaydd73's Avatar
Custom Aux input soldered into factory radio with XM receiver. I stripped the insulation off of a small section of each wire, and soldered in there.
Custom Aux input soldered into factory radio with XM receiver. Before the Soldering.
i snipped a 3.5mm female to L and R RCA wire. soldered my own 18ga wires to the L, R, and Ground, and then covered it with heat shrink.
during the soldering. I used teflon tape as insulation because the plastic around the factory wires was melting from the heat.
The Teflon successfully insulated it and avoided the problem.
I bent the wires slightly to create a better solder bond as the wires i used were 18ga solid copper. Wayyy thicker than the factory stranded wire.
here is the final product. more pictures available upon request.
Let me know what you guys think about it?
Old Jan 11, 2010 | 11:46 PM
  #77
JHans5774's Avatar
Did this today soldered the wires like jaydd73 did and it works perfect cd quality. Thanks for the write up!
Old Jan 13, 2010 | 08:01 PM
  #78
seekNdestroy's Avatar
::::PRICES FOR THIS MOD::::
best buy $170
some ghetto shop $75
css.net $18
i just did this , 18 bux total, bc i had to get the 8 foot of female, which was all they had, and 3 feet of male- male, i didn mount the female just yet, im gonna make a hole next to my e brake coin holder thinger and put it there,
this mod is SOOO EASY AND WORTH IT!! just follow the directions exactly as explained, and it WILL work, unless you mess up, i used 3 crimps
HIGHLY RECOMENDED!!!!
Old Jan 13, 2010 | 10:10 PM
  #79
06G85's Avatar
best buy $170
css.net $18
Sounds like a good time... PICS OR BAN!
Old Jan 14, 2010 | 07:37 PM
  #80
gpro's Avatar
You did this great, I'm very impressed.
I might have to go back and re-do mine.
Originally Posted by RoelSS
No kidding. The poster, "JapEatr" sounds like a familiar name from this forum as well. This sucks for you and you dedicated time for someone else to just copy and paste without giving you the proper credit.
But I thank you for this, It is really good!
Lol, thank you, I appreciate it.
I'm not losing money so I'm not that mad, but credit would be nice, or at very least a link back to this site.
So for future reference feel free to share my work but please:
1. Post only a LINK to here
2. At least give me a credit
3. If you must copy and paste, please link back to my original post or this forum
Old Jan 14, 2010 | 08:21 PM
  #81
o i got pics,, i got pics,,, jkjk i didn even catch tht when i typed it, good eye
Old Jan 18, 2010 | 08:58 PM
  #82
RoelSS's Avatar
Proper credit FTW!
Old Jan 29, 2010 | 10:00 AM
  #83
JayBoo's Avatar
Just got my SS last night, cant wait to do this.
Old Jan 29, 2010 | 02:51 PM
  #84
jaydd73's Avatar
Congratulations!!!
Welcome to the Club!!!
What year did you get?
If you have any questions about the Aux input install, feel free to either post or PM me.
Old Feb 2, 2010 | 12:14 AM
  #85
ayellaone's Avatar
no way to do this on a 06 with one plug yet?
Old Feb 2, 2010 | 07:10 PM
  #86
jaydd73's Avatar
by one plug i assume you dont have Xm installed. However it is the same receiver unit, which means there is a slot for a 2nd plug. Therefore you need to buy the wiring harness. Maybe you can find the part on GMpartswarehouse, or do a search online for such a thing. If you do find that wiring harness you can then just follow the directions as mentioned above.
I dont see why this wouldnt work. Thought i cant guarantee it will.
Another option....call up a junk yard if you find an ss or a base model with the upgraded receiver im sure you can get the wiring harness off the radio for pennies.
Good luck
Old Feb 7, 2010 | 04:39 PM
  #87
JayBoo's Avatar
woot just did this.. thanks for the writeup.
Old Feb 10, 2010 | 01:05 PM
  #88
Boost Fr33k's Avatar
nice job... and jeans
Originally Posted by Joe Schulte
I could hug you right now I'm so damn excited about this. One of my major complaints about this car, fixed.
Not as classy as some, but I prefer function, I slightly notched the bottom the trim with a drill bit, and just ran a coiled Griffin out. I say that as I went through many other brands with the iPod in a Scion tC and the Griffin still has held up.
Sounds great, XM still works great, I love it.
so you spliced the griffin coil instead of having an aux adapter??
Last edited by Boost Fr33k; Feb 10, 2010 at 01:05 PM. Reason: Automerged Doublepost
Old Feb 23, 2010 | 12:43 AM
  #89
DC4LIFE's Avatar
Thanks worked great!!
Old Feb 23, 2010 | 01:45 AM
  #90
Winkdogydog101's Avatar
just so you know those blue clamps will hold much better then soider because you need a pair of plyers to get them off
Old Feb 23, 2010 | 09:56 AM
  #91
SSchargedSS's Avatar
the problem comes when people think they are on correctly, and they are not posing a problem for a short.. i guess a bad crimp can do the same...
Old Mar 1, 2010 | 01:59 PM
  #92
blegends's Avatar
does anyone know how to add an auxilory in jack for a cobalt ls with basic radio features, no xm, thanks in advance
Old Mar 2, 2010 | 11:57 AM
  #93
climber55's Avatar
Trying this Mod Tonight!!!
Old Mar 4, 2010 | 01:54 AM
  #94
ChevelleGrl's Avatar
i'm actually in the process of trying to solve that exact problem.. if you find anything.. let me know and i'll do the same..
Old Mar 12, 2010 | 12:53 AM
  #95
Problem finally solved!!! After doing a little research and talking with a dealership custom shop.. there is a PAC Module available that connects to the back of the non-XM radio that provides an Aux. input. To switch to the aux, you use the BAND button and it'll take you to another menu after AM. I haven't had it installed just yet.. but will give more info/pics once it's all set..
hope this helps..
Old Mar 12, 2010 | 09:04 AM
  #96
ayellaone's Avatar
Ok for chevellegirl, I found the module. click here: http://www.pac-audio.com/. Then scroll down and put ur type of car, model, and year. It will then take you too another screen. The product on the top should be it. with that you get two audio plug ins and all of the stuff you need. Its 129.99. I emailed the company and i am awaiting verifacation that this is the right one, but by the looks, im all most 100% sure it is. if i get comformation, im ordering one today.
badabing, badaboom
Old Mar 13, 2010 | 08:23 PM
  #97
chad_a_alex's Avatar
I have a stock head unit from an 09 ls with the aux input already from the factory. If anybody is interested send me a pm and we can discuss price/shipping info. Thanks and sorry to post this here...i'm just trying to help someone out without having to mod their factory harness
Old Mar 13, 2010 | 09:15 PM
  #98
jaydd73's Avatar
Hey man just giving you a heads up....the new radios wont work with the old cars....the old ones have separate buttons for the diagnostic controls (mileage, oil%, etc) next to the steering wheel...the new one however has them on the radio itself...therefore ive been told that the computer wont be able to communicate the same way.....
HOWEVER....id expect the aux input will work (but the computer might not, unless you did some re-wiring)
Old Mar 13, 2010 | 09:30 PM
  #99
ah ok...i have an aftermarket head unit so i have no use for my factory one...i was just trying to help someone out with the aux input...guess everyone can disregard my last post then
Old Mar 17, 2010 | 09:36 AM
  #100
dawgscj7's Avatar
i did this it worked great make sure you solder your wires only way to get a good connection and clear sound
