Interior: How To: Add Aux Input to pre '07 Cobalts
Old Jan 18, 2012 | 06:37 PM
  #251
Edubs's Avatar
can someone who has xm post a video of how it sounds and works while on xm stations. wouldn't mind doing this but i do have xm and i'd rather not hear music in the background from xm while trying to listen to music from my phone
I've done this on my wife's TBSS and we hated it at first till we remembered that Channel 0 has no music...
Old Jan 18, 2012 | 06:43 PM
  #252
SS_NH's Avatar
This^ I was soo pissed that the commercial channel always playing in the background.. Then I figured it out haha.
Old Jan 31, 2012 | 10:00 AM
  #253
Beastly Cobalt's Avatar
IF anyone can help, i have started doing this to my 06, and my aux cable only had 3 really small fuzzy wires. The wires were so small i cant imagine that it will work will i need a new auxillary cable? the one i used was pretty old. Also there is a bigger black tube with a red cable inside of it that was also wired to the tan, green and brown, does anyone know what this is and were it goes?
Old Jan 31, 2012 | 10:09 AM
  #254
umm i'd recommend just going and buying a new cable. like a monster cable or something good, the more wire strands you have to work with the better. as for the other wires you speak of idk havent seen them in a while just follow the instructions, went easy for me
Old Mar 25, 2012 | 04:24 PM
  #255
06cobaltvt's Avatar
I would like to do this mod to my cobalt, I don't have a problem ripping the dash apart. I guess my problem is not knowing 100% which wires to splice, how to splice them and the little details like what kind of AUX input you used, where you got it and if any will work. any help?
Old Mar 27, 2012 | 01:47 PM
  #256
Elauder's Avatar
^^^I just bought a aux jack from radioshack. Had to file the back of plastic peice to make it thin enough to screw on tight but still works great after five months of use.
Did this mod before going to college. Awesome improvement and if done right looks totally stock. My XM radio even started working for some reason after doing it but shuts off like after a couple days and then turns back on. Weird but cool ha Thanks for this it was a big help and only took about 2 hours total and thats just cause i did it slow to make sure it was right.
Old Jun 5, 2012 | 09:16 AM
  #257
Ameribrazigirl's Avatar
Is there anyone in the MA area that could assist me in doing this mod to my 06?!? i would greatly appreciate it!!
Old Jun 30, 2012 | 12:02 PM
  #258
Project_Sparta's Avatar
Thank you very much, took me a whole 30mins to do this! Solved my aux problem
Old Jul 27, 2012 | 09:10 PM
  #259
ucdatss's Avatar
Soo I need help guys... I have an 2007 cobalt ss my radio had aux but it's not there anymore Idk why but the person I got the car from cut it out. But I tried to do this mod since my radio does have XM got the music to play but it wasn't clear at a high level. Any suggestions? I really don't want to have to buy a radio but I will if I have to
Old Jul 27, 2012 | 10:01 PM
  #260
Gelladuga69's Avatar
Just buy a stock 07+ radio on here for like $50.
Maybe get one with aux and usb to make it worth your while.
Old Jul 28, 2012 | 12:38 AM
  #261
ucdatss's Avatar
Didn't even think about that. Imma look into that
Old Jul 21, 2013 | 07:05 PM
  #262
Tsbbzm's Avatar
Jedi Master
Did this and it works GREAT.
Old Sep 1, 2013 | 06:33 PM
  #263
Pinky Demon's Avatar
So I'm trying to do mine now with a Pipeline AUX cable I got from Radioshack. Problem is, I see the three copper strands of wire but they are all shielded and it also has an extra silver wire for conductivity I suppose. I'm trying to ascertain which one is the ground by just holding it to the tan/white ground wire and then touching the others to see if I get some feedback but nothing so far. after I figure this out, I am going to solder them directly together.
Any tips would be appreciated. Oh, and I discovered the last four letters of my XM ID was ****, which I guess explains why this car is screwing me.
EDIT: So upon further investigation, I found that I have 4 wires. One unshielded stranded wire. One white insulated, one black insulated, and one red insulated, which all have solid copper wires inside per Pipeline's design. I tried messing around with all of them, just holding the wires together and no luck.
Old Feb 18, 2014 | 09:48 AM
  #264
06stockss's Avatar
Has anyone tryed to use the USB cord that came with iPods or iPhones
Old Mar 19, 2014 | 09:05 AM
  #265
Oakley422's Avatar
Went to radio shack and bout a 6' aux extension and cut the male end off to find that it only had two cables. Anyone have any advice on how to find one with three wires before I buy it?
Old Aug 12, 2014 | 11:01 PM
  #266
willmrush's Avatar
Dang I just found this. Guess i just wasted $150 on the Tranzlt Blu kit.
Great write up tho!
Old Aug 5, 2015 | 04:33 PM
  #267
leann_d's Avatar
Low volume
So I have just finished the aux tap but it's really reeeeeally quiet!! Is it because of the cord itself?? Bah so frustrating lol help please.
Old Aug 5, 2015 | 04:41 PM
  #268
Olybaltss's Avatar
Is the volume on your audio device/phone turned up? you normally have to adjust volume on radio and phone when you're connected through AUX cord
Old Aug 5, 2015 | 07:14 PM
  #269
rains_crusader's Avatar
Just buy a replacement radio and swap faces. You won't have to get it reprogrammed if you do it that way.
Old Aug 5, 2015 | 08:24 PM
  #270
leann_d's Avatar
Yeah got everything up all the way, I'm going to try a thicker wire. I bought a $3 wire trying to be cheap lol I do have an aftermarket unit I could put in but trying to make the stock unit work
Old Aug 6, 2015 | 12:09 PM
  #271
JapEatr's Avatar
South Central *********
I tried three dif cables and couldn't get it to work
Old Aug 7, 2015 | 11:30 PM
  #272
leann_d's Avatar
Finally got it working �� it was the cheap wire
Old Aug 10, 2015 | 12:55 PM
  #273
ChevyRockstar's Avatar
I had bought a cheap wire from walgreens and it work just fine. Some aux cables dont work cause i did cut some that had a fiber and not copper which is annoying. But the walgreens genric brand i got had the copper wires and works great
Meadowvalien
Aug 17, 2017 06:32 PM
satisfied
Oct 19, 2015 12:35 AM
jmelton327
Sep 25, 2015 09:44 AM
