Interior: How to: Aftermarket Pedals
Old Oct 17, 2006 | 07:34 PM
Pieeater's Avatar
Here is a quick write up on my installation of my sparco pedal set. This may not work for all pedal sets because of different sizes and styles, but this is how I did mine. Others may have better ideas for mounting the gas pedal, but this one worked for me.
1. Remove the gas pedal arm. This is done by removing the three bolts and the wire harness shown here.
2. Once you have the arm removed from the vehicle, remove the plastic gas pedal. The pedal is held on by two threaded rivets. I was able to push them out using a big ass pair of pliers, and a even bigger hammer and punch. This takes a little force, and beware, if you care to save the oem pedal be gentle, cause the plastic will crack easily if you are not carefull.
3. Once the pedal is removed, attach a 90 degree, 4 hole bracket to mount the aftermarket pedals onto it. For my setup, re-drilling one hole in the bracket and one hole in the pedal arm was needed to make it fit with my smaller gas pedal. The picture shows the two new holes that I drilled and the attachment plate.
This picture shows the side view of the 90 degree bracket attached to the arm. The silver plate on top was also drilled out in order for the attachment plate to fit securely.
Picture showing the sparco pedal installed on the attachment plate.
4. Re-attach pedal arm, bolts, and wire harness.
5. Remove rubber pedal covers from cluth and brake. Use the attachment plates as a guide as to where you need to drill. The brake pedal is a bitch because of the welds. I had to drill two new holes into the attachment plate and into the brake pedal to get these to work correctly. Repeat steps for the clutch pedal. The cluth is plastic and drilling is easy.
It takes a little bit of time, but it is worth it. I love the smaller gas pedal compared the large hunk of plastic that came stock. The gas pedal sits about 2 inches to the rear compared to the brake and clutch, but I find it easier to get my foot moved from the brake to the gas then before, and have much response feel in my toes then before.
Old Oct 17, 2006 | 07:40 PM
Belto's Avatar
look good man nice how-to
Old Oct 18, 2006 | 12:44 PM
FraGmE's Avatar
good work dude
Old Nov 4, 2006 | 08:38 PM
Red06LS's Avatar
I like those, im sure they would/do look good wiht a vic red balt.
Old Nov 13, 2006 | 02:58 PM
The_Blur's Avatar
nice how-to; looks a hellua lot better than stock
Old Apr 5, 2007 | 06:04 PM
Bob T's Avatar
Another helpful "how-to"
Thanks for the ideas.Good Job.
Old Jul 24, 2008 | 11:11 PM
joey90's Avatar
whats the easiest way to get those rivets out of the gas pedal without breaking the pedal
Old Jul 24, 2008 | 11:25 PM
KillerBee's Avatar
Good job they look awsome
Old Jul 26, 2008 | 09:35 AM
ta2ooedmike's Avatar
very nice...i have the same ones only silver...i used smaller brackets though....ebrake change is next....
Old May 28, 2012 | 01:11 AM
fullmetal289's Avatar
Can anyone help me with this? Im sorry for gravedigging but I found no other topic like this on the site.
For the three bolts you have to remove, what size are they? also, doesnt this only remove the gas pedal? What about the brake?
I wish the OP was more detailed as I am kinda lost in how to do this, I have to drill holes in each pedal, so removing them is required. Thanks!
Old May 29, 2012 | 08:06 AM
chrisjaldin's Avatar
I'm looking forward to upgrade my pedals and my e-brake handle, where did you get yours?
Old May 29, 2012 | 03:28 PM
Well when you do it, care to let me know if those three bolts are all you need to removing the pedal assembly? Does it allow you to remove all the pedals with just those 3 bolts? Any further explanation would be greatly appreciated.
Old Jun 20, 2012 | 10:51 PM
papidulce's Avatar
Nice i like those pedal! Did you only remove the gas to drill the pedal on? like did you take of the clutch and the brake pedals to do the same process?
Also has anyone changed their e brakes, i just bought a momo pit lane handle and i dont know which adaptor to install with it....
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Sep 27, 2015 08:53 PM
metroplex
Sep 27, 2015 07:48 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
