Appearance: How-to: BPS OEM Adapter
Old Dec 11, 2013 | 02:46 AM
SPDDMN36's Avatar
Quick 'How-to' for installing BPS' new OEM shift knob adapter.
Tools needed:
Screw driver or interior panel tool x2
T25 Torx bit
Ratchet
Rubber mallet(Maybe)
Pliers or 7mm box end wrench
1. Begin by removing the cap on the OEM shift knob. Use a screw driver or panel tool to gently pry under one side and work your way around until it pops free.
2. Next remove the T25 Torx screw.
3. Remove the shift knob. Some people have no issues just pulling theirs off but mine was quite stuck. So I put a screw driver in 2 sides of it and gently pried up. If you pry too hard you can damage the reverse lock out cosmetically.
4. Install the BPS adapter.
The shifter itself is splined to keep the OEM knob from turning and BPS has been kind enough to return the favor by adding a spline to the inside of the adapter.
They include a bolt with a nut n washer for coaxing this baby on. I unfortunately didn't have the proper wrench to use it. I'll tell you how to do it the proper way and the Jeremy Clarkson way
The proper way is to thread the provided nut onto the bolt. Thread the bolt into the top of the shifter all the way. Then tighten the nut with wrench or pliers until the adapter is seated all the way down. This could take a bit of time. Remove bolt and add to can of bolts you may need again someday.
The Jeremy Clarkson way is to just smash it with the rubber mallet until its seated. It's quick and easy but too much smashy smashy could break things.
5. Thread in either provided cap screw or reuse the OEM Torx cap screw. (poor photo, sorry phone picts)
6. Thread adjustment spacer into shift knob. This is used so you can adjust the knob to align the shift pattern correctly. Unless this doesnt matter to you then you can just tighten it all the way to into the knob and slap the knob on. (Reverse lock out doesn't lift high enough if you just tighten it all the way.)
7. Thread the knob on and see how it the pattern lines up. It may take a few tries to get it where you want it. Remember how far off the pattern alignment was as that's how far you must tighten or loosen the adjustment spacer.
8. Enjoy also ignore my dirty car...
Old Dec 14, 2013 | 06:42 PM
Gmoney06's Avatar
Nice write up. Glad I saw this. Ordered a knob awhile ago ASSuming since there sts was designed for the stock knob, there knob would fit the stock shifter. It didn't. Emailed them earlier and got one on the way to me Monday. Thanks for this thread. And a huge thanks to bps for there awesome customer service. Bps rocks!!!
Old Jan 15, 2014 | 03:33 PM
Gmoney06's Avatar
Got my adaptor right before Xmas. Followed this. Took all of about 5 minutes.
Thanks for the write up.
And huge thanks to BPS for hooking it up with the adaptor.
Old Jan 15, 2014 | 03:34 PM
i'm no mod, but i approve.
clean your cupholders jesus!!
Old Jan 15, 2014 | 03:38 PM
royce777's Avatar
yeah your car is cruddy AF lol
Old Jan 15, 2014 | 03:54 PM
SPDDMN36's Avatar
It's been sitting and I haven't had the motivation to clean it.
heeter_33's Avatar
Very good!
hacadacalopolis
Oct 28, 2015 06:09 PM
2009blackSS
Sep 30, 2015 05:57 PM
Trav3480
Sep 28, 2015 02:46 PM
jas09ss
Sep 26, 2015 01:06 PM
SS_2009_TC
Sep 11, 2015 05:41 PM
