2.0 LSJ Engine: Return-style fuel system for 2.0 LSJ
Old Dec 9, 2007 | 07:58 PM
jgarciarivera's Avatar
Parts needed
1. Walbro GSS342 - longer than stock fuel pump
2. Aeromotive A1000-6 Part# 13109 regulates from 30-70psi
3. Fuel lines (20 -25ft)
4. fittings
5. fuel filter (1 input, 1 output)
6. Aeromotive one-way check valve or Earl Performance check valve
7. 2 Straight hose-end 6AN fitting
8. male adapter connector to female end on check-valve
Step 1
Take out the tank. Several bolts need to be unscrewed. Try to have an almost empty tank. It'll weight less.
Step 2
Take out the module inside the tank. Be careful to take out the cap where the fuel pump is located. It has like 4 clips. Use a philips screw driver.
Step 3
Take the stock fuel pump out. Take out the in-tank regulator.
Step 4
Insert Walbro GSS342. Warning, this fuel pump does not fit in the location where to stock pump is located. Put back the cap and tied firmly with 3 straps.
Step 5
Replace one of the fuel lines that goes into the tank with a fuel line. This one goes from the tank to the bottom of the regulator. You gotta be extremely careful here, try not to break the plastic fuel input of the module inside the tank.
This is the replaced line:
These are the fuel lines i used:
Step 6
Installed regulator.
Step 7
Here you got two choices. Either buy a 2002 Ecotec fuel rail, which is already tapped, or tapped the stock fuel rail, that's what I did. Connect a fuel line from the side of the regulator to where the fuel rail is tapped. You'll know where to tapped because the fuel rail the LSJ uses is the same as the cavalier except the LSJ's is blocked. Drill and connect fitting.
Step 8 Verify for leaks and connect vacuum hose. You have to get a T, cut one of the vacuum lines and install. Replace the fuel filter. It needs a 1 input, 1 output type and be aware of the flow directions.
Step 9 Test for leaks. Switch to Run until the pump fills the fuel line. You'll here a small whine and when the fuel pump stops. Remember, you have to do this everytime you start the car. The regulator does not hold fuels in the lines like the intank regulator.
Step 10 Use a wideband to setup the fuel pressure. Set the pressure. Try to set it for 40-41 psi. At vacuum should be 50-51psi.
After the installation, I went to a dyno and set AFR to 10.8. Dyno results after return style and fujita CAI. The KR I got before the return-style, gone.
Old Dec 10, 2007 | 03:14 AM
ericss's Avatar
nice!
Old Dec 10, 2007 | 03:25 AM
JRelly's Avatar
subscribed for later use
Old Dec 10, 2007 | 03:28 AM
c0ld29's Avatar
awesomeness
Old Dec 10, 2007 | 03:29 AM
ItalianJoe1's Avatar
About step 9 - you could probably add an in-line check valve to stop the complete drain of fuel. I know we've use a couple aeromotive ones at work that hold 3psi, and they work great to eliminate drain-back.
Old Dec 10, 2007 | 03:32 AM
SlowBalt_06's Avatar
would that kinda starve the #3 and 4 cylinder
Old Dec 10, 2007 | 03:36 AM
c0ld29's Avatar
no it would actually stop the starvation of the 4th cylinder. This way fuel flows THROUGH the fuel rail instead of just into. Any left over fuel is recycled also. Correct me if I'm wrong
Old Dec 10, 2007 | 03:38 AM
but where its taped intoo the rail its closer to 1-2 no 3-4 or in the middle
Old Dec 10, 2007 | 03:39 AM
JRelly's Avatar
so you made 250whp just with this and a CAI?
Old Dec 10, 2007 | 04:04 AM
rick1217's Avatar
wow, i like it.....subscribed!
Old Dec 10, 2007 | 08:56 AM
Hey Joe, that's the basic problem, that fuel drains back to the tank and actually I was looking for a solution to that problem. Could you point me a link or internet address on those in-line check valves? Sometimes I have to wait for prime, but if its off for a couple of minutes it starts immediately.
Check dyno sheet above and sig mods
Last edited by jgarciarivera; Dec 10, 2007 at 08:56 AM. Reason: Automerged Doublepost
Old Dec 10, 2007 | 09:03 AM
jimbos'ss's Avatar
subscribed
Old Dec 10, 2007 | 09:31 AM
How To Set Up Your Fuel System Correctly I
A fuel system is just that - a system! All the pieces must work together. The current trend is to run a pump that is much bigger than should be required to compensate for deficiencies within the system. Simply buying and installing the biggest pump you can find will not be enough if the rest of the system is poorly thought out. The same can be true buying a pump based upon price or what you think is enough fuel pump. Either deficiency can also easily drain the wallet if you run out of fuel and start damaging engine parts ... not to mention losing races!
This article will focus on electric fuel pumps. Mechanical fuel pumps are not worth the effort unless you are mandated by the rules of your class (as in most circle track applications). You can use the same basic knowledge with your mechanical fuel pump in regards to requirements and fuel regulator choices.
Fuel pumps are generally rated in gallons per hour (or GPH). Mallory offers pumps rated at 70, 110, 140, 250 and 500 GPH. All of the Mallory pumps are of gerotor type which makes them quieter and more efficient than rotary vane style pumps. However, it is mandatory that a fuel filter be installed between the fuel cell (or tank) and the pump. The higher efficiency of the gerotor pump also is less tolerant of garbage getting into it ... always run a filter before the pump! You should also have a filter just before your carburetor or injector rail as well.
A typical engine uses 0.5 pounds of fuel (gasoline) per hour to make each horsepower. Gasoline weighs in at approximately 6 pounds per gallon. To calculate fuel consumption let me show you by example. Lets say we have a 400 HP engine (or nitrous system) and we will use the following formula:
400 HP X 0.5__ X 1 gal = 33 GPH
HP per hour 6 lb.
If you installed a pump rated at 33 GPH on a 400 HP Nitrous system the engine would experience severe fuel starvation and your wallet would cringe in "empty" pain! WHY?
There are several reasons ... However, the main reason is the way that pumps are rated. Fuel pumps are rated at "zero" pressure (also known as "free flow"). Rating a pump at zero pressure is useless because the pump will never be at zero pressure when it is operating in the vehicle. As fuel pressure increases, the fuel pump slows down and fuel output is reduced. If you use a standard "dead-head" type regulator, the pump may be forced to produce as much as 25 PSI. At 25 PSI, the actual output GPH of the pump is much less than at "free flow".
All of this makes choosing a pump size difficult. You may use the following as a fuel pump "rule of thumb". Additionally, it is a good idea to give your system a bit of safety cushion. I always run a pump one size larger than I need just for insurance.
For Dead-Head type regulators:
Multiply maximum horsepower by .23 to calculate minimum pump size in "free flow" GPH.
Example: 400 HP x .23 = 91 GPH "free flow"
For Return-Style regulators:
Multiply maximum horsepower by .17 to calculate minimum pump size in "free flow" GPH.
Example: 400 HP x .17 = 68 GPH "free flow"
These minimum pump sizes assume that the fuel system is equipped with fuel lines of adequate size. If the fuel lines are too small (or if there are a lot of restrictive fittings in the system) a larger pump may be required to satisfy the fuel demand of the engine. The minimum fuel line size (from the pump to the regulator) is dependent on the horsepower output of the engine (and/or Nitrous system) regardless of the size of the pump.
Use these figures as a fuel line sizing standard:
* Up to 250HP = 5/16" or -04 AN
* Up to 375HP = 3/8" or -06 AN
* Up to 550HP = 1/2" or -08 AN
* Up to 800HP = 5/8" or -10 AN
* Up to 1200HP = 3/4" or -12 AN
If you use a return-style regulator, you will also need a return line from the regulator back to the tank. The size of the return line is dependent on the size of the pump you are using, regardless of the engine's horsepower output. The return line must have limited or NO pressure in it. In most cases, the minimum return line size will match that of the supply line, but a larger return line is sometimes preferred.
Use these ratings to decide your return line sizing based upon fuel pump output:
* Up to 45GPH = 5/16" or -04 AN
* Up to 90GPH = 3/8" or -06 AN
* Up to 180GPH = 1/2" or -08 AN
* Up to 360GPH = 5/8" or -10 AN
* up to 720GPH = 3/4"or -12 AN
Mounting the fuel pump takes thought as well. You MUST mount the fuel pump as low as possible and as close to the fuel cell (or tank) as possible as well. DO NOT mount the pump above the fuel tank.
NOTE: At many times I'm asked about the actual angle of mounting the pump. I'm asked if the pump must be mounted upright. Take it this way, if the seals in the pump happen to fail, would you want fuel leaking into an electric motor or simply onto the ground? Well if you like fires ...
Mount the fuel pressure regulator as close to the engine as possible. DO NOT use restrictive fittings, especially sharp 90º or "T" fittings. If you must use a 90º or "T" fitting, use the tube style fittings from Earl's, Russell, Goodridge, Bonaco and others. See Below...
The GOOD and the BADbad example of a fuel fitting
Good example of a Racing Designed 90* fuel fitting Of course the first shown below is what you want. The restriction of the fittings (second fitting) can be hazardous to your race engine and the consistent ability to Win Races..
Regulators and the Benefits of Return-Style Systems:
One of the biggest restrictions in most fuel systems is the "dead-head' regulator. Dead-head regulators are popular because you do not need to install a return line. However, they are not only more restrictive but also create several other problems that can be eliminated with a return-style regulator. Dead-head regulators also have a higher failure rate than return-style regulators.
Mallory offers both dead-head and return-style regulators. Both types are available in large and also small versions though you should never run the small regulators on pumps rated higher than 180GPH.
Dead-head regulators regulate pressure by starting and stopping flow. Return regulators regulate pressure by sending excess fuel back to the tank in a continuous cycle.
Because a dead-head regulator starts and stops flow, fuel pressure between the pump at regulator is higher than the pressure between the regulator and the carb (or injectors). However, if the pressure gets too high, it can and will damage the fuel pump. Therefore, the pressure coming out of the pump is limited by a device built into the pump called a bypass. Low pressure pumps are limited to less than 9PSI and should not be used with dead-head regulators. High pressure pumps are limited to a pressure of between 10 and 25PSI.
Not only can the fuel pumps being used with dead head regulators fail because of pressure issues, but pumps with dead head regulators also run hotter do not last as long as when connected to to a return-style system because it is the fuel that cools the pump. Pounding the fuel because it can not move creates more heat.
The Mallory 70 and 110 pumps are low pressure pumps that can be used without a regulator for the street or with a return-style regulator for racing. Mallory 140, 250 and 500 series pumps are high pressure/high volume and must be used with a regulator (dead-head or return-style).
The bypass in the pump can malfunction. This can cause the pressure to drop or increase so much that the pump motor fails. Even if the bypass in the pump is working correctly, it is still possible to have a pressure drop with a dead-head regulator, even when using a large pump. See the image below:
At idle, gauge #1 will read 10PSI where gauge #2 will read 8 PSI. At full throttle, the increase in fuel flow will create a pressure drop between the pump and the regulator. The amount of pressure drop depends on the restriction in the fuel line ... a 4 PSI drop is not uncommon. Gauge #1 will now read 6PSI and because a dead-head regulator cannot raise the pressure, gauge #2 will also now read at 6PSI. The result is a 2 PSI pressure drop at the carb or Nitrous even though a very large pump may be in use.
NOTE: When using a dead-head regulator, a second gauge should be installed just before the regulator. This will allow you to check that the pressure before the regulator stays higher than the set pressure.
Most race pumps have the bypass set very high (14-25 PSI) to avoid this problem. However, this creates another problem. The higher bypass pressure makes the pump work harder and draw more amperage. In fact, the pump works just as hard at idle as it does at full throttle down the track! This is one of the main causes of early pump failure. To counteract this problem of high amperage draw, many companies manufacture voltage reducers for street cars to slow the pump down and increase the life of the pump.
A few "WHYS" to return-style regulators:
This is a profound point to be made when I (or your engine builder, carb builder or fuel pump manufacturer) tell you to run ONLY a return-style system on your vehicles.
* You can avoid these headaches (especially when the pump dies just before a final-round elimination and you do not have enough time on your hot-lap, or for that matter a spare pump, to fix it in time to race ... Loss By Default!) by running a return-style (or bypass) regulator.
* The bypass in the pump is plugged or disabled when you run a return-style regulator so there is no chance of it failing.
* The pressure just before and after the pump is always the same so there is no need for two gauges.
* The return regulator has complete control over the pump pressure and will automatically compensate for pressure drop in the fuel line.
If there is s 2 PSI pressure drop between the pump and the regulator, the return-style regulator will force the pump to produce 10 PSI. If there is s 4 PSI drop, the pump will be forced to produce 12 PSI. In either case, the pressure at the regulator will remain at 8 PSI (or whatever you set it at). The pump will also live longer since it is only producing 10-12 PSI instead of 14-25 PSI. This means that a voltage reducer is not needed, even on a street car.
Fuel pressure regulators suffer from something called "recovery time". Recovery time is explained as the amount of time it takes the regulator to react to changes such as a sudden increase in fuel demand (as when you jump on the throttle or hit the Nitrous button). Return regulators react much quicker for several reasons. Return regulators allow the fuel to flow straight through without making a 90° turn. With a return regulator the fuel doesn't have to make it's way around the plunger like it does in a dead-head regulator. Just before you jump on the throttle (or hit the nitrous button), the fuel in a dead head system is barely moving. In a return system, the fuel is constantly moving from the rear of the car to the front and back again. This means that the fuel already has momentum, which reduces recovery time. This movement of the fuel also keeps the pump cooler and reduces vapor lock.
"We never race any hot tracks in the heat of summer, do we?"
Dead-head regulators can also cause "creep" which means the fuel pressure tends to slowly increase. Return regulators cannot creep.
Nitrous systems are very sensitive to fuel pressure fluctuations. It is highly recommended that you run two independent fuel systems when using Nitrous (preferably with return-style regulators). Two small systems with small pumps, fuel lines and regulators are usually cheaper than one large system anyway. If you must use one large system, use two dead-head regulators installed in parallel, not in series. NEVER use two regulators in a system with a return-style regulator! Any fuel system with a return regulator must have only one regulator.
Fuel System Designs For Engines With Nitrous:
Last edited by jgarciarivera; Dec 10, 2007 at 08:59 PM. Reason: Automerged Doublepost
Old Dec 10, 2007 | 10:32 AM
rob561's Avatar
^longest post ever^
Old Dec 10, 2007 | 10:37 AM
Raven SS's Avatar
subscribed to fully read when get home from work
Old Dec 10, 2007 | 10:40 AM
an0malous's Avatar
very interesting stuff.
would have been far more beneficial if we had a dyno before the mod, as well as after.
Old Dec 10, 2007 | 01:27 PM
http://aeromotive.carshopinc.com/pro..._id/3279/15106
Thats the one we used. Awesome piece, holds 3psi residual pressure, you would have to place it in the return line after the regulator.
Check Summit, I think they were a little cheaper, that is just the first one that popped up when I googled it.
Last edited by ItalianJoe1; Dec 10, 2007 at 01:27 PM. Reason: Automerged Doublepost
Old Dec 10, 2007 | 03:23 PM
Thanks Joe
Old Dec 11, 2007 | 11:41 AM
celicacobalt's Avatar
i love the return fuel system, im running the hahn return system right now. you guys could just buy the system from hahn probably if you wanted.
Old Dec 29, 2007 | 05:17 PM
OniMirage's Avatar
subscribed
Old Dec 29, 2007 | 05:22 PM
silentd's Avatar
how does the ecu handle this?, i thought our computer was designed to feed just enough fuel, so wouldnt there be no advantage considering the ecu is only sending a certain amount of fuel
Old Dec 29, 2007 | 05:56 PM
Ok guys, just to let you know that I ordered the -6AN IN-LINE FULL FLOW CHECK VALVE. Yesterday, I missed the UPS truck so on monday I'll have this:
One Way Check Valves
High flow one-way check valves designed to prevent back-flow with minimal pressure drop. Ideal for use where it is desirable to prevent drain back after the fuel pump is turned off, or when dual pumps are employed and both pumps will not always be running together.
Old Dec 29, 2007 | 06:35 PM
Avrj123's Avatar
Subscribed for later, good post
Old Dec 29, 2007 | 07:54 PM
WickedSS2005's Avatar
Subscribed!!! This looks like a great read
Old Dec 29, 2007 | 08:29 PM
skoshi130's Avatar
Very interested and subscribed
