2.0 LSJ Engine: Return-style fuel system for 2.0 LSJ
iknorite, you should see how fast teh **** downloads, wait till i get the return system on it too.
You know what, I apologize, your right. I have no idea what I am talking about. I am just the person that built Witt's, DJT81185, Mine, and Sean's motor (he flew me out to California to build his). Oh wait...
Might I add those are the only cars on the site that have done a motor build and are still running trouble free?
building someones motor doesnt give you the right to be an ******* to people trying to learn.
WSFrazier can treat me like an ******* anytime - just as long as I am learning. The best professors I have had where complete ********.
To post something on topic: I see 3 benefits with a returnless system. The first is it allows you to tune the fuel system much easier by not having to alter the IFR table to account for manifold pressure. The second is that it allows you to keep relative pressure consistant and get more out of smaller injectors at high boost levels. Third - It also allows you to run larger injectors at higher pulsewidths in low load / low rpm situations due to the pressure reference.
There are other cool things about it - but that it what appeals to me the most.
out of curiosity, i'm planning on doing injectors, tune, smaller pulley, and cooling mods spring'ish next year, and was considering doing a return fuel system as well, so i could get a safer, more aggressive tune. my question is, is this worth the money? i know i can get safe tunes with the current setup, but i'm wondering if doing this would be safer on the long run.
hey guys
i dont can t drop my fuel pressuse to -65psi ...
my question : in the fuel pump , do you need to remove a oem black valve inside the pump for the return line
my installation is complet, have also a performance check valve earl's on my return line 5/16 after my regulator
help please
help please
i just want to know what fuel filter you used for your return style system or did you just plug your return port on the fuel filter??? im going to do this setup so im looking for some tips here. thanks
Anybody knows where I can find this "how to" without the dead pictures?
I also figured that, while keeping the stock fuel system, the fuel rail damper could be remove and replaced by some fitting to be plumbed to the regulator. Doing so would make the flow exactly the same into all the injectors (instead of exiting between cylinder 1 and 2 (2002 cavalier fuel rail) staving them since the further exit from a collector gets the better flow.)
I know the thread is 6 years old sorry
Sep 28, 2015 12:51 PM
