2.0 LSJ Engine: Return-style fuel system for 2.0 LSJ
Old Jul 5, 2008 | 03:15 PM
  #326
OneCOLDBIZL272's Avatar
Originally Posted by jgarciarivera
Parts needed
1. Walbro GSS342 - longer than stock fuel pump
2. Aeromotive A1000-6 Part# 13109 regulates from 30-70psi
3. Fuel lines (20 -25ft)
4. fittings
5. fuel filter (1 input, 1 output)
6. Aeromotive one-way check valve or Earl Performance check valve
7. 2 Straight hose-end 6AN fitting
8. male adapter connector to female end on check-valve
Step 1
Take out the tank. Several bolts need to be unscrewed. Try to have an almost empty tank. It'll weight less.
Step 2
Take out the module inside the tank. Be careful to take out the cap where the fuel pump is located. It has like 4 clips. Use a philips screw driver.
Step 3
Take the stock fuel pump out. Take out the in-tank regulator.
Step 4
Insert Walbro GSS342. Warning, this fuel pump does not fit in the location where to stock pump is located. Put back the cap and tied firmly with 3 straps.
Step 5
Replace one of the fuel lines that goes into the tank with a fuel line. This one goes from the tank to the bottom of the regulator. You gotta be extremely careful here, try not to break the plastic fuel input of the module inside the tank.
This is the replaced line:
These are the fuel lines i used:
Step 6
Installed regulator.
Step 7
Here you got two choices. Either buy a 2002 Ecotec fuel rail, which is already tapped, or tapped the stock fuel rail, that's what I did. Connect a fuel line from the side of the regulator to where the fuel rail is tapped. You'll know where to tapped because the fuel rail the LSJ uses is the same as the cavalier except the LSJ's is blocked. Drill and connect fitting.
Step 8 Verify for leaks and connect vacuum hose. You have to get a T, cut one of the vacuum lines and install. Replace the fuel filter. It needs a 1 input, 1 output type and be aware of the flow directions.
Step 9 Test for leaks. Switch to Run until the pump fills the fuel line. You'll here a small whine and when the fuel pump stops. Remember, you have to do this everytime you start the car. The regulator does not hold fuels in the lines like the intank regulator.
Step 10 Use a wideband to setup the fuel pressure. Set the pressure. Try to set it for 40-41 psi. At vacuum should be 50-51psi.
After the installation, I went to a dyno and set AFR to 10.8. Dyno results after return style and fujita CAI. The KR I got before the return-style, gone.
nice
Old Jul 5, 2008 | 03:39 PM
  #327
WickedSS2005's Avatar
^^^ LOL, why quote the WHOLE walkthrough for a one word reply? But this is a mod I want to do in the future to get even more outta my Harrop
Old Jul 5, 2008 | 03:45 PM
  #328
an0malous's Avatar
i still havent seen anyone really prove that its necessary, or beneficial unless your doing stupid amounts of power.
Old Jul 5, 2008 | 04:41 PM
  #329
Raven SS's Avatar
how about gas mileage..or a raising pressure of fuel with ur boost so u dont gotta run injectors that are for 800hp cars...those are just 2...luckily my honda comes stock with a return style
Old Jul 5, 2008 | 04:55 PM
  #330
spike's Avatar
most k-swap hondas switch their fuel setup 2 this as well.....
Old Jul 5, 2008 | 08:20 PM
  #331
an0malous's Avatar
if you notice, i didnt say there ISNT any reason....i said i havent seen any yet
Id love to see some documentation, or information showing how it is beneficial
Old Jul 5, 2008 | 08:48 PM
  #332
SJSchafer's Avatar
I don't have any documentation, per say, but I will say that from a tuning aspect, return style is def FTW.
Old Jul 5, 2008 | 10:21 PM
  #333
an0malous's Avatar
see, (dont take this the wrong way) but thats all ive heard so far about returnless....opinions
I just want to know exactly why it is beneficial for a 250-350hp cobalt.
again, im not saying its junk and pointless,
im just saying id love to see some hard proof, some convincing articles....just something concrete to
convince me that this might be worth me investing in.
Old Jul 5, 2008 | 10:23 PM
  #334
WSFrazier's Avatar
Have you never modded a car before?
Old Jul 6, 2008 | 12:57 AM
  #335
lsjwannabe's Avatar
My car needed a return style with the tvs at 25 psi, the 60's could not make the cut.
Old Jul 6, 2008 | 01:51 AM
  #336
an0malous's Avatar
genius.
thanks for the positive input.
do you have anything to backup your smartass comment?
or are you gonna ride everyones coat tails, and pretend you know the answers?
if so, like i said, id love to hear them, im here to learn.
if not? go **** yourself.
k i can understand the 60s not doin the job....
but why returnless, instead of a larger injector?
is it not possible to run larger without returnless?
does returnless allow far greater performance out of 60s?
Old Jul 6, 2008 | 01:53 AM
  #337
Raven SS's Avatar
most hondas come stock to return style..no need to switch
genius.
i just dont understand running an injector that is for a 900hp car (79lbers) and spending 300-500 bucks on them when u can run 42's on a return style and be fine when my return style only cost me 300 bucks..and tuning them is so much easier
Old Jul 6, 2008 | 02:12 AM
  #338
lsjwannabe's Avatar
genius.
a return style does allow for better performance out of the 60's no doubt. My idc's went from 130% at 6200 rpms running a 12.4 afr to 83% at 7200 with a 12.0 afr.
Old Jul 6, 2008 | 02:57 AM
  #339
an0malous's Avatar
thank you for the info...
question though....is the efficiency increased because of return?
or is it because of the higher pressure walbro pump?
as ive seen the pump thing is a pretty popular upgrade for the srt4 guys
holy smokes, thats a vast difference.
any negative effects on the injector to run it this way?
Old Jul 6, 2008 | 03:12 AM
  #340
SJSchafer's Avatar
Okay, so here is the thing. This is not merely opinion, but has been backed up with data, and is the basis for my "FTW" comment.
I started with stage 2 and 42s. I decided to run a smaller pulley and found that I run out of injector up top. I install 60s. This is all familiar, and what everyone does, right? Well, here is the problem with that. The first problem is that our PCM limits the IFR table so that we have to make up for it with either using a modifier (far from impecable) or by other means that are even less ideal. We also know that as we increase injector size, we lose the ability to flow them accurately at the low PWs our cars require. This makes them not want to behave during idle and light cruise. The bigger the injector, the worse the low PW performance - unless, of course you are going with disc injectors, but then you still have to deal with the whole 63.5 thing.
I switch to a return style system and here is what I get out of it: First of all, I set my base pressure so that my IFR is at exactly 63.5 across the board. I now KNOW 100% that my IFR table is correct. Also, before, when my pressure was a semi static 58psi, my 60s idled at about .980-1.000ms and light cruise had me at .875-.950ms, which is well under the linear range with those injectors. Now I idle at about 1.2-1.3ms which the injectors like fine. My idle is butter smooth at 850 rpms at all times. Also, dead head returnless systems get "creap". This is when you are supplying 58psi to a dead head rail for a length of time and the rpessure will begin to grow higher and higher untill you open up the injectors and dump a quantity of fuel to releave some pressure. This cannot happen with a pass through system.
There are also benefits that I believe I have gained, but they are speculative, so I will leave them out of this discussion. I will say that i do not spend my money lightly, nor my time, but for me, the accuracy of the tuning alone is well worth this mod. Never mind that the car "feels" way better.
Old Jul 6, 2008 | 03:16 AM
  #341
an0malous's Avatar
appreciate you takin the time to write that up.
thats exactly the kind of real world experiences i was lookin for
Like yourself, I dont spend my money lightly either,
just doing my due diligence on a possible purchase
Old Jul 6, 2008 | 03:19 AM
  #342
SJSchafer's Avatar
BTW, I am not convinced that the Walbro is a signifigantly better pump. I ran my system with the stock pump for a while, and the only difference I could see was that the walbro is louder. I am not the most heavily modded either, though, so...
No worries. Sorry for the spelling. late + whiskey = liuawoehgjhpregcae
Old Jul 6, 2008 | 05:08 AM
  #343
InfinityzeN's Avatar
Didn't they not change the stock pump in the build book till the 700~800 HP range?
Old Jul 6, 2008 | 11:31 AM
  #344
lsjwannabe's Avatar
dual walbro's are
Old Jul 6, 2008 | 01:12 PM
  #345
spike's Avatar
yeah but the k it's self doesnt...... and guy that do the builds switch them.....
Old Jul 6, 2008 | 01:19 PM
  #346
WSFrazier's Avatar
genius.
I think its funny that you love to harass people who ask legitimate questions and then dump all over this site and go off constantly in a fit of rage the second someone doesnt agree with you. You give advice like you are a know it all tuner and yet beg and plead for info that is easily searched on this forum and almost any other automotive forum.
Old Jul 6, 2008 | 02:05 PM
  #347
an0malous's Avatar
Im sorry you dont like me frazier, but frankly, i dont give a ****.
i notice you waited till everyone else gave information before you replied.
and your reply contains no information at all.
gee what a shock.
so for someone accusing me of being a know it all,
you sure prooved that you dont know **** either, and just wanted to take a shot at me.
At least im not to proud to know that I DONT know it all, and was quite willing to ask for help.
that doesnt sound like the actions of someone who pretends to "know it all" now does it?
or is this maybe your sour grapes over the last thread you attacked me in?
Old Jul 6, 2008 | 02:14 PM
  #348
WSFrazier's Avatar
gee what a shock.
umad?
Old Jul 6, 2008 | 02:19 PM
  #349
an0malous's Avatar
awww is that the best you can do?
QQ and little quips because you dont have the intelligence to truely come up with a reply?
lol.
your a waste of perfectly good bandwidth.
lets get back to the intelligent conversation with all the other people in this thread who have a clue shall we?
maybe youll learn something too.
Old Jul 6, 2008 | 02:22 PM
  #350
WSFrazier's Avatar
lol.
According to this then, I am a waste of lots of bandwidth.
