Appearance: How To: Change interior to LED. *UPDATED INFO*
Old Mar 19, 2014 | 09:40 PM
  #176
PowerzslobaltSS's Avatar
is there anything I can do or do I need whole new leds? im average when it comes to electrical lol. is there a fuse I could switch out? thanks for the help
Old Mar 19, 2014 | 09:57 PM
  #177
EmperorJJ1's Avatar
depends on what you are trying to do or swap out. everything pictured in this thread comes on the car incandescent and would require you to buy leds to solder in
Old Mar 19, 2014 | 10:04 PM
  #178
Originally Posted by Ph3lix_004
Pretty sure they are burning out, mine did the same till I added resistors. Eventually I got the correct 12v leds
is there anything I can do like change a fuse or anything? im average when it comes to electrical. thanks for the help
im trying to change the leds in my steering wheel controls
Last edited by PowerzslobaltSS; Mar 19, 2014 at 10:04 PM. Reason: Automerged Doublepost
Old Mar 20, 2014 | 07:12 AM
  #179
sLAsh's Avatar
Its not a fuse. You have burnt out the leds you put in by giving them too much power. Once you let the magic smoke out electronics never run again.
You have to either use 12 volt leds or use a resistor with a normal led . Resister values will differ depending on what colour led you are using.
Old Mar 20, 2014 | 12:51 PM
  #180
Squints's Avatar
Tcobalt it you still have my number text me. You migt have put the leds in backwords. Crave try diffused and cover the tops with pieces of black electrical tape
Old May 14, 2014 | 03:31 PM
  #181
garabo22's Avatar
On the steering controls, do 0805 LED need resistors soldered in with them or is it a straight swap with the stock bulbs? I have 12V 3mm LED leftover from doing all of the other buttons if these are a better option than the SMD, but I wasnt sure if they would fit with how small the OEM bulbs are.
Old May 17, 2014 | 05:52 PM
  #182
09xfebalt's Avatar
on the three spoke wheel there led to start with so surface led is the way to direct replacement.
bigdeertz
Nov 17, 2016 09:41 AM
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
Sep 27, 2015 08:53 PM
