Appearance: How To: Change interior to LED. *UPDATED INFO*
#178
im trying to change the leds in my steering wheel controls
Last edited by PowerzslobaltSS; 03-19-2014 at 10:04 PM. Reason: Automerged Doublepost
#179
Its not a fuse. You have burnt out the leds you put in by giving them too much power. Once you let the magic smoke out electronics never run again.
You have to either use 12 volt leds or use a resistor with a normal led . Resister values will differ depending on what colour led you are using.
#181
On the steering controls, do 0805 LED need resistors soldered in with them or is it a straight swap with the stock bulbs? I have 12V 3mm LED leftover from doing all of the other buttons if these are a better option than the SMD, but I wasnt sure if they would fit with how small the OEM bulbs are.
