2.0 LSJ Engine: How To Change Timing Chain Tensioner
Old 08-30-2014, 06:06 PM
  #126
GfSwindle06's Avatar
Picked up the new style timing chain tensioner today at a local dealer for less than $60 dollars and followed this guide to install it. T'was a breeze. Hardest part was removing the valve cover and working around the fuel line since I didn't want to remove it. Appreciate the helpful thread! Engine smooth as silk now and you can only hear the injectors ticking away.
Old 09-25-2014, 02:35 PM
  #127
reddragon72's Avatar
Been hearing odd idle noises lately and today no more than 7PSI boost and my car sounds like a diesel.
Going to limp it home and buy a tensioner.... just hope it didn't jump timing but I'm thinking it has.
Old 09-25-2014, 05:33 PM
  #128
chris88z24's Avatar
Originally Posted by reddragon72
Been hearing odd idle noises lately and today no more than 7PSI boost and my car sounds like a diesel. Going to limp it home and buy a tensioner.... just hope it didn't jump timing but I'm thinking it has.
Subaru or Diesel?
Old 09-25-2014, 07:41 PM
  #129
Powell Race Parts's Avatar
Unless the beige exhaust side guide is broken ( and it is metal backed) its unlikely the chain will jump on the sprocket teeth.
Old 10-11-2014, 11:02 PM
  #130
droponikz's Avatar
Amazon tensioner
Hello, I've been looking for a new style tensioner and I believe I found one on Amazon for pretty good price. It looks like the new stype but not sure. I asked the dealer and he said he doesnt know. Can anyone tell?
http://www.amazon.com/gp/aw/d/B0049Z8JNC/ref=mp_s_a_1_fkmr2_1?qid=1412963505&sr=8-1-fkmr2&pi=AC_SX110_SY165_QL70
Old 10-25-2014, 07:26 PM
  #131
droponikz's Avatar
Did it
Just finished replacing the old tensioner with the new one. Just followe ed this how-to n had no problems. I will say that when it was time to start it made the rattle noise for about 2 seconds, then went away. Thanks for the How-to!
Old 12-16-2015, 11:07 PM
  #132
18jivan's Avatar
Here's a helpful trick I picked up; When you install the new tensioner and whack it to get it to engage there is still slack in the chain. I personally didnt wanna start my car with this slack being present. So I put my car in 5th gear and pushed it forward maybe 6 inches and the chain snapped right into place! No more worries about whether it engaged or not!
Old 12-17-2015, 01:02 AM
  #133
izcain's Avatar
I just pulled the valve cover and tied the sprockets together and to the chain for piece of mind. Only out a few cents worth of zip ties. I needed to replace a weeping valve cover gasket anyways lol. Also pulled the plugs and rolled it over when finished and lined it the marks on the chain with the cams just for giggles took quite a few revolutions I will say that lol no biggie. Plus it put the tension back in the assy. By rolling it over. Seems to be quieter now. Piece of mind also.
Old 12-17-2015, 07:30 AM
  #134
Administrator
Administrator
Staged07SS's Avatar
You should always rotate the engine a rev or two to make sure it spins freely and everything is lined up.
Unless you totally removed the chain, rotating the engine a gazillion times to get the marks on the sprockets and chain to line up is a big waste of time, lol.
Old 12-17-2015, 10:12 AM
  #135
izcain's Avatar
I know I was doing it more for myself getting familiar with the engine a bit. If I was doing this customer car wise I would not be doing that lol
Old 04-06-2018, 04:06 PM
  #136
cobalt blue's Avatar
Just wanted to give a big thanks to NCSU Slobalt for an awesome write up on how to replace a timing chain tensioner. Mine took a **** the other day and I was able to get a new one and a valve cover gasket for under 90 buck. Took less than an hour to install. Thanks again!!
Old 01-28-2019, 06:46 PM
  #137
Miltb's Avatar
Just to clarify !!
How to change Lnf tensioner?
1- chock car. Put in neutral.
2- Remove old!
3- install new set tensioner.
4- start car ??????
Is this THE RIGHT WAY?
Just want to clarify as this thread inst entirely clear!
Old 01-30-2019, 03:12 PM
  #138
Miltb's Avatar
Bump? The above question?
Is it pretty much a 10 minute job providing you can break the old tensioner out easy?
Old 02-10-2019, 09:09 PM
  #139
cobaltssdude420's Avatar
Break it out? Just unscrew it dude. Why not just pull the valve cover to see how everything is doing under there? It's really easy lol
Old 02-11-2019, 09:47 AM
  #140
Miltb's Avatar
Cuz you gotta pull numerous pieces out of the way .... Including removing the turbo o oil feed line.
And if I was to pull the cover, would the cams stay in place with no movement?
Old 02-11-2019, 09:58 AM
  #141
The valve cover is exactly what its name is, just a cover. Its not integrated with holding the cams.
Old 02-11-2019, 10:26 AM
  #142
Miltb's Avatar
Great .... Well now that my other car is out of the way I can start fiddling with my TC.
how to take the oil feed line off? That is the question. Hmmmn.
Old 02-11-2019, 10:32 AM
  #143
Why are you taking the oil feed line off? There is a pcv line that goes from the vlave cover to the inlet side of the turbo. If thats what youre talking about its a 10mm bolt on the turbo side then twist and pull, just make sure when you reinstall you put some oil on the oring or it will likely rip.
Old 09-14-2019, 04:15 PM
  #144
Tom10122's Avatar
For anyone that checks this thread, I had the same exact problem, 7psi, loss of power, sounded horrible. My tensioner was seized when I pulled it and a new one fixed everything somehow. No timing jumped thankfully.
Miltb
02-14-2019 02:49 PM
Ardy
01-15-2016 03:04 PM
cavfiredesire
11-03-2011 07:48 PM
woowoo16
09-22-2011 10:33 PM
Hopeless Regret
11-23-2007 10:22 AM
Quick Reply: 2.0 LSJ Engine: How To Change Timing Chain Tensioner
