Appearance: How To : Chevy Skyline Tail Lights
Old 01-23-2008, 10:32 AM
  #51
Kibosh3's Avatar
Originally Posted by jefferyss
cool but those look like ass ! sorry but my opinion
agreed...and good work, come spring time, im going to get this project going
Old 01-23-2008, 12:37 PM
  #52
jefferyss's Avatar
thanks for the compliments everyone, good luck with the projects if any are going to be doing it.just follow the how to and you should be good
Old 01-26-2008, 02:38 AM
  #53
DoubleLP's Avatar
Nice work!
Here is a good place to find those LED strips:
http://www.superbrightleds.com/led_prods.htm
My project is coming soon.
Old 02-18-2008, 03:12 AM
  #54
MixMasterMike's Avatar
That reverse light housing is separated for the white and red, is the outside housing separate too? for the bulb then the red around it. do you happen to know?
Old 02-18-2008, 08:39 AM
  #55
smartmts123's Avatar
outside housing like the inside of the reverse lights? No.
BUT there is a inner wall that works really well to secure the lights.
And the red and white will stay together if you're careful.
outside housing like the brake lights? No.
On a different note,
I did this last month, and my recommendation is that you get the 19" LED strips from oznium.com, and cut them to size. i have no gap between LEDs, and it looks much better in my opionion.
I also did a little wiring with diodes and resistors to make the LEDS work like dual-filament bulbs, so they're dimmer for running lights and full brightness for turn signals and brake lights. I'm really happy with the results. if anyone wants more details, i'll be happy to do a write-up in a couple of days. it only took about $10 of stuff from radio shack and ripping the trunk apart, which was already done anyway.\
So in summary, thanks for the writeup, it was great and definitely helped me get started on the project.
And the housings seperate into the reflector/inside the car part and the colored lens/outside the car part.
Old 02-18-2008, 11:52 AM
  #56
https://www.cobaltss.net/gallery/fil...1/DSC00722.JPG
Is the original brake/turn signal housing separate like that? or is it just one giant area?
Old 02-18-2008, 12:53 PM
  #57
one giant area.
Old 02-19-2008, 01:00 PM
  #58
jefferyss's Avatar
has a dividing ring seperating the reverse light from the othe area. i just glued the light to the inner edge of the outside ring and ran the wiring back through the little slot next to the reverse light
Old 02-22-2008, 07:09 PM
  #59
MBMCustoms's Avatar
Is there a taillight set up that you can buy that already has this option for you to wire in???
Old 02-22-2008, 08:48 PM
  #60
yellowltcoupe22's Avatar
yeah you could get the ipcw led tails that already have the area around the back up light filled with leds but they cost like 300 and imo dont look good enough to pay that much for..
Old 02-23-2008, 01:23 AM
  #61
jefferyss's Avatar
^_^
agreed lol
Old 02-23-2008, 01:28 AM
  #62
how much of a gap did you have in between your leds where it was to short? i ordered some 12" strips to do mine with and figured i could just cut off what i didnt need..
Old 02-23-2008, 01:32 AM
  #63
jefferyss's Avatar
i had about an inch,it doesnt bother me at all cause its at the bottom of the light
Old 03-25-2008, 09:12 AM
  #64
nuttzzy's Avatar
Originally Posted by SS/SCking
Sweet!!! Where can I get those LED strips...?
http://www.oznium.com/led-flex-strips
you can get strips in whatever length, im putting mine in today
Old 04-18-2008, 04:06 AM
  #65
warrenb213's Avatar
so what's the consensus on the color led's to buy? the red or white ones from oznium?
Old 06-12-2008, 09:49 AM
  #66
NCC-2000's Avatar
I might as well add this here. I highly recommend this mod as it's like super easy to do. The hardest part is taking the stupid lights apart. Other than that, it's cake, and looks sweet especially at night. I completed my mod but I went one step further and made the lights running and brake lights using a resistor and a few diodes. Daytime video here: http://www.youtube.com/watch?v=lZeVf8ZOJ9I
Old 07-26-2008, 03:06 PM
  #67
BULLETSSMOKE's Avatar
anyone done the vette style blinkers yet? nice job NCC
Old 08-01-2008, 11:44 AM
  #68
Shugo0323's Avatar
I did this and it didn't work...i guess faulty LEDS?
Old 08-01-2008, 11:51 AM
  #69
07MONTECARLO_SS's Avatar
the volksbalten mod is better
http://s116.photobucket.com/albums/o...t=100_1524.flv
http://s116.photobucket.com/albums/o...t=100_1536.flv
Old 08-05-2008, 04:43 AM
  #70
Projekt's Avatar
i now have the orgional set (thanks again jeff)
from what jeff told me , to make them vette style all it would take is wiring them up to the resistor
Old 10-28-2008, 06:25 AM
  #71
FrankTheTank's Avatar
this looks sweeet. bump for later
Old 10-29-2008, 05:35 AM
  #72
is it possible to bake the tail lens to loosen the sealant.
Old 10-29-2008, 07:50 AM
  #73
mcphatty's Avatar
yes you can bake them
Old 10-29-2008, 09:26 PM
  #74
tru2nrtt777's Avatar
+rep.
Old 10-30-2008, 12:01 AM
  #75
ok. thank's McPhatty. i was thinking 200*F for 10 minutes. does that sound right.?
Quick Reply: Appearance: How To : Chevy Skyline Tail Lights
