2.0 LSJ Engine: How to: CX Racing Heat Exchanger
Old Apr 22, 2008 | 12:51 AM
stryder's Avatar
Looks good cole nice job
Rodimus_Prime's Avatar
where is the air bleed from your surge tank hooked up then the 1/4 inch hose that is
Old Apr 22, 2008 | 12:52 AM
ssmokin's Avatar
the top of the stock heat exchanger....
Old Apr 22, 2008 | 12:55 AM
ColeJJones's Avatar
Bannned
yep. it runs to the top left of the stock h/e as your looking at in my pic
here you go dude. i forgot to put this pic in my how to. its updated though
Last edited by ColeJJones; Apr 22, 2008 at 12:55 AM. Reason: Automerged Doublepost
Old Apr 22, 2008 | 01:05 AM
sunburstbalt's Avatar
Has anyone ever just used the aftermarket heat exchanger, i mean the stock h/e sits way back there is it really make much of a difference, its blocked? Just a question i could be wrong correct me if i am. Your using the dual bypass which cools down intake temps correct?
Old Apr 22, 2008 | 01:28 AM
hedlesshorsmenss's Avatar
you should take a pic from the top, so that we can see how much clearance there is with the front facia on.
Old Apr 22, 2008 | 09:40 AM
ah thats what i needed to see
Old Apr 23, 2008 | 04:09 PM
Pickles's Avatar
Originally Posted by ColeJJones
i have the sheet metal if anyone wants some. i have the bolts too. just let know
You wanna sell me a set of brackets/bolts?
Old Apr 23, 2008 | 04:17 PM
invisible's Avatar
Hey Cole, were you're stock heat exchanger hoses a bitch to get off like mine where?
Old Apr 23, 2008 | 04:21 PM
ColeJJones's Avatar
Bannned
sure 15 bucks shipped
**** yea. those things are bitches to get off. you gotta use channel locks and then you have to man up and take them off. i used liquid grease to put the rest of my **** on so when it comes time to take them off its alot easier. i used bolt clamps on all my hoses. i think i ended up using around 20. just guessing
Last edited by ColeJJones; Apr 23, 2008 at 04:21 PM. Reason: Automerged Doublepost
Old Apr 23, 2008 | 04:23 PM
  #36
invisible's Avatar
Hell yea. I was ready to **** punt the g/f for the hell of it after taking those damn things off!
Old Apr 29, 2008 | 12:30 AM
  #37
RageTechnologies's Avatar
where does one pick up this heat exchanger?
Old Apr 29, 2008 | 02:31 AM
  #38
stryder's Avatar
ebay is the only place to find it
Old Apr 29, 2008 | 03:38 PM
  #39
Thanks
Old May 21, 2008 | 04:09 PM
  #40
valentino0214's Avatar
yo how do the hoses go???
Old May 21, 2008 | 05:26 PM
  #41
ColeJJones's Avatar
Bannned
what do you mean, how do those hose hoses go..?
**** yea they were
Last edited by ColeJJones; May 21, 2008 at 05:26 PM. Reason: Automerged Doublepost
Old May 21, 2008 | 06:12 PM
  #42
dremel ftw
Old May 21, 2008 | 06:13 PM
  #43
ColeJJones's Avatar
Bannned
dremel for what??
use channel locks to get them bitches off
Old May 21, 2008 | 06:26 PM
  #44
how does the h/e hoses connected on the by pass and the raditor
Old May 21, 2008 | 06:31 PM
  #45
ColeJJones's Avatar
Bannned
if your looking at the car from the pics. the hose on the left came from the right side of the stock h/e. and the hose from the right goes into the dual pass. i just went out and looked. its connected to the middle nipple on the dual pass end plate
found on page 1... read
Old May 21, 2008 | 07:17 PM
  #46
ight thanx kid
Old May 29, 2008 | 02:09 AM
  #47
jefferyss's Avatar
hey cole, quick question for you... i just mounted my cx tonight.dont have cahs for coolant and hoses at the mometn but my bumper is off getting painted. perfect time to fab up and mount the cooler. i dont havwe the dual pass or option b. i was wondering a couple of things, in your picture showing the stock h/e , tht line comming out of the top left of it...what is it for? does it have to do with the dual pass at all? and the other question is do i just disconnect the hose from the stock h/e in from the pump and connect it to the in on the cx and the out on the cx back to where the pump in was on the stock .or do i have that entirly backwards lol .
any help would be appreciated
Old May 29, 2008 | 02:24 AM
  #48
ColeJJones's Avatar
Bannned
yea the hose on left as your looking at the stock h/e will hook up to the right of the cx and the hose off the left of the cx will go to where stock hose was on the left side the stock h/e.. make sense.
and yes you have to run an entirely different type of plumbing with the option b and dual pass. so it is different
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
