Appearance: How To: dim light deck lid smoked aftermarket lights
i dont like the LED look with just a small point lit up so i tryed this. dont think it works to well with some aftermarket smoked taillights. it may be different with stock. give it a try if you think so too.
first you need to by some Neon wire and some epoxy. make shure you get 2 packs of the neon wire.
first step is to disconect your trunk light.
then you need to seperate the lens from the houseing.
drill a hole small enough for just the neon wire to fit through. mix a small amount of epoxy and spread the epoxy on the surface and begin to wind the wire around the housing till area is filled with neon wire.
epoxy both halfs of the light back together and reinstall.
hook it up to your parking light wire and heres what you get. (not the best i think because there smoked).
z28addiction
09-28-2015 12:03 AM
