Drivetrain: HowTo: 2.2l transmission mount inserts.
So after scoring free Prothane inserts from Scott at CPP for sending in my stock mounts. I spent about 2 hours installing these.
Tools needed:
Ratchet
15mm socket
18mm socket
5/8 socket
Press
Flathead screwdriver(if you don't have a press)
Hammer(if you don't have a press)
Block of wood(if you don't have a press)
Couple of cut-to-size 2x4's
Jack
2 Jackstands
Setup:
Jack car up and put it on the jackstands.
Then using the jack and 2x4's support the motor/tranny. In the pic the way I had it was in the way so I moved it later.
First remove the 3 15mm bolts then the one 18mm going thru the bushing.
Once the mount is free and out it will look like this:
Using a press(or the flathead screwdriver and a hammer as a wedge to pry it out) remove the bushing.
Using a press and some lubrication press the bushing into the mount(or use the hammer/block of wood to tap it in, failing that stand on the bushing/mount and with enough lubrication it will pop in[how I did it])
Put the mount back in by reversing the steps.
The steps are nearly the same for the rear mount. These 3 bolts are 15mm.
These 3 are 5/8's
This one is 18mm
Then there is one more that is 15mm that hold the heatshield to the block. didn't get a pic of it. once again the install of the bushing is the same.
Results:
Increased cabin vibration...but no wheelhop.
Tools needed:
Ratchet
15mm socket
18mm socket
5/8 socket
Press
Jack
2 Jackstands
Setup:
These 3 are 5/8's
This one is 18mm
Results:
ThoR294
Oct 4, 2015 08:44 PM
