Appearance: how-to fog light on your SS bumper on your base Balt
haha
ive been wanting to do this as ive noticed behind my light trim i have the wires for the fog switch and was told call cobalts fogs or not are pre wired but i couldnt find the wires for the life of me. your how-to makes me want to do this as i have a ss/sc bumper without fogs :P i think you've answered all my questions
now buy some of my parts haha
If you have any question ask me because I made the way to do that and no charge jajaj right berto laso I know all the wiring and who it is. just in case SS/SC under construction me debes una berto priceless
So how do the fogs fasten to the bumper i have em on my SS N.A. and i was hoping i could off set the fogs back some with washers or somthing so i could get some decent air flow past the passangers side one.
well they click in,, there really hard to take out,, the really secure in there,, try pushing the clips in and pull hard, and try not to brake them,,,
they came with those bulbs... I believe the are hyper white.
thanx kind sr.
thanx kind sr.
hey just double checkin. jus wanna make sure the fogs are really just a press fit into the back of the fascia. no brackets, bolting or anything else to installed. bcus i ordered some from ebay and they look just like urs-2 small screws in the back and that little aiming bolt thing at the top. thanx
o nd how much did u pay for the bumper? painted/unpainted? nd where from?
and yes the fogs were press on,, it was a press / plugh / and play
I left the stock one,, it does not line up perfect,, it is between an 1" or 2" from the lip,, I did not what to pay that much for a few inches of plastic,, Ill take a pic ,, Ill post up tomorrow
You dont need to do all that.....removing the fuse box? wtf? all i did was run 4 wires 2 on each side. i disconnected both my headlights and cut the black wire which is your groiund on both sides....then i spliced a wire on there and ran it to the fog light....then i cut the beige wire with the white stripe which is ur low beam power.....again i spliced a wire into that and ran it down to my fog light. and there u have power and a ground to both your fog lights...so now when ever ur lights are on auto.....your fog lamps will come on with ur low beam headlights.....its that easy.....none of the remove the fuse box stuff.....just thought i would let u guys know of an easier way......4 wires and 2 splices thats all it took
I dont use my highbeams,, and also,, I thought this will be good bc many people complaint of that, not been able to use highbeams plus fogs..
no prob man,, its all good,, mine is just a way to do it,, its not the onlyway ...
