Appearance: How to: Glowing interior trim. (long read, pics)
Old Sep 10, 2011 | 06:08 PM
Jesse's Avatar
*ALWAYS* err in the side of caution. If you finish the project and want more light to show you can always grind more of the trim away. You can't undo showing too much light without looking ghetto.
A couple people asked so why not? It's a long read but the info is important so you don't F up your trim and get mad at me. Here's how I got my glowing trim done. First, you need to buy your LEDs then pull all the dash trim off that you want to glow(just pull on it, hard). I strongly suggest sitting the light strips inside, putting the trim back on, and test-fitting them first. Also if you can, test the lights by either leaving the "Try Me" battery pack connected and routing the wires out of the trim, or you can simply push the positive wire into the red/yellow wire in the in-car fusebox(and ground the negative wire of course). All cars are different, so you need to find out where to do your delicate grinding and where to leave it alone. So, this is what we start with.
Next step is to start grinding. I used a dremel tool with the rough grit sandpaper drum. Whatever you do, be careful and ease into it. Don't press too hard. It's only plastic. I only had to grind the edges of the passenger trim very minimally, but here is the radio plate. I also shaved away a small portion of the clip support for the light strips to fit. Be careful here or you may break the clip support apart from removing it from the dash.
Another very important piece of information: You can alter how much light exits the trim without changing the outside appearance of the trim at all.I depends solely on your ability to grind. For example, this looks exactly the same as a stock piece outside but notice the new angle of the edges. It's essentially changing the edge of the trim from a square to a triangle or point.
Completed radio trim:
Completed passenger (above glovebox) trim. I cut slots into the bottoms of the trim for ventilation, drainage, and to a lesser extent to shine light through.
Next is the piece to the right of the steering column. I don't have buttons here, so it made my work a lot easier. If you have buttons there get creative! I just shaved the button support off. I literally had to do nothing to the trim with the instrument cluster dimmer except put lights in it just under the dimmer housing, so no pics of it.
Next is wiring. I wired the dimmer-switch trim strip under the steering column trim to the trim just right of the steering column. I then spliced and sealed(electrical tape) + and - wires of the dimmer-switch strip to the + and - wires of the strip to the right of the steering column. The light strip wires just right of the steering column were spliced/sealed into the nearby radio trim strip. The left radio trim light strip was spliced/sealed was wired to the right side radio LED strip. The passenger side trims were both spliced/sealed into the right side radio trim lights as well. Last thing to do was wire the only thing left to wire. The right side radio lights were the connection to a power source and ground.
I wanted my lights to come on ONLY at night when the instrument cluster lights did, so I did some prodding and found exactly the wires to use as my power source. See the light brown/tan wires circled? They get power with the instrument cluster lights only. Simply splice and seal the LED strips into one of these wires, or wire it into another spare fuse space, then connect your negative wire to any good ground and you are set!
Here's what mine look like. It took me 6 hours start to finish, including grinding. 1 hour of that was freaking out because someone honked while I was under the steering column and *insert stupid #@$%* and my EPS unit was disabled from being shorted? Not sure.
removed + reinstalled EPS fuses and no battery for a couple minutes and the unit worked again.
Lights off:
Lights on:
Old Sep 11, 2011 | 04:08 AM
Erick161's Avatar
...thats kind of weird looking? Any more pics?
Old Sep 11, 2011 | 04:16 AM
overboostedss's Avatar
Dude that's awesome
Jesse's Avatar
That a question or a statement? Lol
Linked to flickr:
Custom glowing trim | Flickr - Photo Sharing!
And a vid:
G5 glowing trim. (Cobalt) - YouTube
Old Sep 11, 2011 | 05:16 AM
EmperorJJ1's Avatar
vid looks better then the pic. but ya the pic does look weird
Old Sep 11, 2011 | 05:51 AM
Raiden8816's Avatar
+1 for being different
Old Sep 11, 2011 | 03:25 PM
C_A_D88's Avatar
Definitely one of my future mods with rgb led strips
Old Sep 11, 2011 | 04:16 PM
z062007vette's Avatar
Sub'd. Might be doing this soon.
Old Sep 11, 2011 | 05:55 PM
Jesse's Avatar
I imagine I could do the same thing with the silver steering wheel trim, but I am too chicken to try removing the airbag to get them off.
Old Sep 11, 2011 | 08:39 PM
gumby3558's Avatar
there is nothing hard about pulling the airbag just don't lose the little center positioning clips for the connectors or you will get a code.
Old Sep 11, 2011 | 08:40 PM
09sscalicobalt's Avatar
haha yall have waaaaaaaaaay too much time on yours hands
Old Sep 11, 2011 | 08:42 PM
padlock's Avatar
wouldnt it be easier to stick the LEDs to the dash itself n not the trim?? or no??
Old Sep 11, 2011 | 08:45 PM
chris88z24's Avatar
I'd ******* love to be a passenger in your car while tripping on mushrooms.
Old Sep 11, 2011 | 08:49 PM
royce777's Avatar
looks good. but def a fire waiting to happen
Old Sep 11, 2011 | 08:51 PM
N1ckateen's Avatar
looks like too much work and money for such little results.. i like the idea though. definately headed in the right direction. if we were fords this would have already been done in multiple colors lol
Old Sep 11, 2011 | 09:34 PM
rcarr0327's Avatar
is it just letting the light escape from the side by grinding it down or is the light shining through thinned out plastic?
Old Sep 11, 2011 | 09:52 PM
Miko's Avatar
Wht not just glue some thin strips of clear plastic to the "square" portion of the trim that you ground away to get the gap? I think that would give a nice consisitent glowing edge.
Old Sep 12, 2011 | 01:08 AM
Jesse's Avatar
Didn't take that long. 6 hours to R+D, fix my EPS unit, grind everything, and install. I could do another set in 2 hours flat.
It may be but the lights would have pointed away from the gaps. Plus there isn't a flush mounting surface on the dash, it is indented, etc... pull your trim off an you'll see what I mean.
How so?
Light is escaping from gaps in the plastic between the dash and the trim.
Originally Posted by Miko
Wht not just glue some thin strips of clear plastic to the "square" portion of the trim that you ground away to get the gap? I think that would give a nice consistent glowing edge.
This is probably one of the first times anyone has done this on a cobalt/G5. That definitely sounds like a good idea. I want to wrap my cheap looking trim in carbon fiber or something so I may go through and improve it a bit. Thanks for the idea!
Old Sep 12, 2011 | 11:05 AM
Dave1515's Avatar
Looks sweet man
Old Sep 12, 2011 | 11:36 AM
RHZ's Avatar
RHZ
Where did you get- and what kind of LED strips are those?
Old Sep 12, 2011 | 11:54 AM
MastaShaKe_88's Avatar
look like the autozone ones, an it looks pretty cool in that video.. itd be real cool if it pulse when the bass hits
Old Sep 12, 2011 | 11:58 AM
cobalt2010's Avatar
i may be able to make that happen. but to the op nice job.
Old Sep 12, 2011 | 12:19 PM
Jesse's Avatar
^^This. A lot more expensive than Ebay but I had cash in my pocket, Autozone had red ones, and I didn't want to wait so I bought them. Ebay is about 1/3rd the cost, so if you can wait you would save big money.
How does someone go about doing that? Wire it to the sub?
Old Sep 12, 2011 | 12:34 PM
sick_tight's Avatar
so the LED's in your gauge cluster and that light up your buttons and whatnot are all a fire waiting to happen...
Old Sep 12, 2011 | 12:50 PM
fire waiting to happen my ass as long as u did it right which im sure you did!
looks pretty sweet man, and definately a step up from just slapping leds under ur glovebox and stuff, this is really pretty cool looking!
