Interior: How To Install An Auto Dim Rear–view Mirror
Old May 13, 2011 | 07:28 PM
LS6Rally's Avatar
I havent looked at my car yet, but does this look right?
Image Sheet
Old May 13, 2011 | 10:14 PM
dsh1106's Avatar
Image Sheet
Looks just like the one I bought last night, same seller as well.
Old May 13, 2011 | 10:19 PM
LS6Rally's Avatar
Im wondering if the plug is the same as the Cobalt or is it the bigger 16 pin.
Old May 13, 2011 | 11:10 PM
CordiaDOHC's Avatar
guys...
07-08 Chevrolet HHR Rear View Mirror OEM LKQ | eBay
25$
im gonna search and see if i can fin one with the same connector as ours, that would be nice, and i dont have OnStar as well.
Damn so tempting!
Old May 13, 2011 | 11:24 PM
LS6Rally's Avatar
I Know, im just wondering if pre 07's will work. i know 07+ seems to be different on our cars.
Old May 13, 2011 | 11:30 PM
CordiaDOHC's Avatar
Im usually all in for anything that makes me cobalt nicer while making it less run of the mill. Not to mention I like some subtle details that a non cobalt person would notice.
This is one of those thiings!
Old May 14, 2011 | 09:50 AM
dsh1106's Avatar
I say go fot it, this mod took less than 1/2 hour to do. Well worth the time.
Old May 14, 2011 | 09:55 AM
RooTBeeR's Avatar
so you need the mirror and the plug/wires for it?
Old May 14, 2011 | 02:31 PM
dsh1106's Avatar
If the the mirror you get has a chunk of harness with it you're good to go. Just pull one of the wires plug it into #13 slot on your car's harness. Run the wire to the sunroof switch and your done.
I didn't do the reverse wire, I have a tinted back window so it wouldn't make a difference anyway.
Old May 15, 2011 | 08:24 PM
Koenreich's Avatar
Nice write up.
Old May 15, 2011 | 10:17 PM
  #36
snoftall's Avatar
Image Sheet
Only thing I can noticed different about this one you have linked (in post #26) is it does not have the map lights. If your current mirror doesn't have map lights or you don't mind losing them then this one is fine
Old May 15, 2011 | 10:18 PM
  #37
snoftall's Avatar
The plug for the one you have linked (in post #26) is the bigger 16 pin connector. If your current mirror has OnStar, you should have the bigger 16 pin connector already. If you don't have OnStar, you will probably only have the 8-pin connector.
Old May 16, 2011 | 12:23 AM
  #38
RooTBeeR's Avatar
yeah i'd do the reverse wire, but i'd find it either off the fuse block or the reverse switch i'd think itd be more convenient than going all the way to the back up lights
I thought that mirror does have the map lights in it though?
I'll have to look i have onstar and i think your right i already have the 16 pin connector
Old May 16, 2011 | 06:00 PM
  #39
LS6Rally's Avatar
i haz no onstar
Old May 17, 2011 | 08:24 PM
  #40
FITZ07's Avatar
i haz no onstar
You don't need onstar, I bought a mirror out of a 07 hhr it has auto dim, compass, and maplights with NO onstar. Just make sure you get the plug with some wire so you can extend it to where you need. Its a 16 pin plug and has 5 wires in it. I can tell you where to run them or look for my post in the electronics section.
Old May 17, 2011 | 10:25 PM
  #41
LS6Rally's Avatar
^ Can you look at the back of the mirror and get me the Part number please?
Old May 17, 2011 | 10:32 PM
  #42
FITZ07's Avatar
Sorry, no gm part number that i see. Only thing on the back is GENTEX 025898 GNTX-511. Like I said this was out of a 07 hhr. Shouldn't be hard to find one in a junkyard or ebay. Got mine off ebay for like 35.00 shipped. Looks like 07 and up have smaller map lights but there led. 06 and older have the bigger standard map lights. There's a couple on ebay right now and I think one of them comes with the plug. here's one from an 06 on ebay http://cgi.ebay.com/ebaymotors/Chevr...Q5fAccessories and here's one out of an 07, its the one I used http://cgi.ebay.com/ebaymotors/07-08...Q5fAccessories
Old May 18, 2011 | 10:58 AM
  #43
RooTBeeR's Avatar
well i just bought this one
but if you have/want to keep your onstar, heres another
07-08 HHR Rear View Mirror With OnStar OEM LKQ | eBay
Old May 18, 2011 | 11:53 AM
  #44
dsh1106's Avatar
That looks just like the one I bought last week only yours was a lot cheaper .....
Old May 18, 2011 | 06:05 PM
  #45
LS6Rally's Avatar
Thanks for the link!
Old May 18, 2011 | 08:05 PM
  #46
FITZ07's Avatar
No problem here's the pin outs for the 16 pin connector for the Non Onstar mirror
Inside Rearview Mirror (DD8) Pin Wire Circuit Function
1 0.35 GY 157 Interior Lamp Control
2-5 -- -- Not Used
6 0.35 D-BU/WH 149 Courtesy Lamp Supply Voltage
7 -- -- Not Used
8 0.35 BK 750 Ground
9 0.35 L-GN 24 Backup Lamp Supply Voltage
10 -- -- Not Used
11 0.35 D-GN/WH 2514 Keypad Signal (UE1)-- -- Not Used (DD8)
12 0.35 L-GN/BK 2515 Keypad Supply Voltage (UE1)-- -- Not Used (DD8)
13 0.35 PK 339 Ignition 1 Voltage
14 0.35 YE/BK 2516 Keypad Green LED Signal (UE1)-- -- Not Used (DD8)
15 0.35 BN/WH 2517 Keypad Red LED Signal (UE1)-- -- Not Used (DD8)
16 -- -- Not Used
Old May 18, 2011 | 08:19 PM
  #47
LS6Rally's Avatar
^ ok, what do i do for my factory Harness, i keep forgetting to look at it, does it use the same plug, just less wires?
Old May 18, 2011 | 10:15 PM
  #48
RooTBeeR's Avatar
yeah not sure why the one i bought was ~40 and the other one i posted was ~85 for the same part...so im hoping mine doesnt have too much "wear" since its used compared to the more expensive one or something, no idea why the price is so diff.
u have that for the onstar mirror by chance?
Old May 20, 2011 | 07:00 PM
  #49
RooTBeeR's Avatar
stock w/onstar vs. auto dim/compass w/onstar
Plug comparison only difference is the red and green wires
Stock
autodim/compass
these 3 wires are the same on both mirrors
this is just showing all the colors of the wires on the auto dim/compass
Old May 20, 2011 | 07:43 PM
  #50
RooTBeeR's Avatar
here is is broken down
i did this to see what kinna bulb was in it(i like my aftermarket leds better)
i got lucky and lkq sent the harness with the mirror, so i just pulled the leads out of that connector to put into the one already in my car so i dont have to buy any new ones
