2.0 LSJ Engine: How To Install Oil Pressure Gauge Into 2.0L LSJ
Old 12-16-2008, 04:54 PM
OverbooSSt's Avatar
will the 1.5 adapter work or do i need the 1.75? glowshift has the 1/8 1.5 but not the 1.75 sorry for opening an old thread
Old 12-29-2008, 11:21 PM
redlineblueline's Avatar
i still want to know that part number for the gage and if its mechanical/electrical/etc
Old 12-30-2008, 12:43 AM
yellowltcoupe22's Avatar
no the adapters that come with the gauges will not work. you need autometer metric adapter 2278.
as for your question that is autometer phantom series gauge p/n 5727. its a short sweep electric gauge.
Old 12-24-2009, 01:24 AM
domin8_gt's Avatar
Subscribed.
Sorry for bringing back a dead thread.
I'll find out about the T as I'm about to install an electric gauge in my car.
Old 01-03-2010, 01:01 AM
utibalt's Avatar
any suggestions on installing a mechanical gauge with an oil line going straight to the gauge itself? i was just going to hook up the line to one of the galley plugs on the block...
Old 01-03-2010, 10:25 AM
insylem's Avatar
Talking
Originally Posted by secondstringsoldier
a 24mm open ended box wrench
Open Ended Box Wrench? Thank about that for a minute.....
I Think you mean Combo wrench
Old 01-03-2010, 10:31 AM
TurboTechRacing's Avatar
FYI we carry the autometer fitting 2278 at www.TurboTechRacing.com and keep them in stock.
Old 03-04-2010, 07:27 AM
Axelthered05's Avatar
what size is the male end of the factory adapter?
Old 03-04-2010, 03:46 PM
TiggeR's Avatar
has anyone installed thier oil psi sender on the side of thier block? i know i saw someone do it but i dont remember who....I have been trying to get that oil gally thing open but its some different kind of allen key its a star i believe and its hard as hell to open i cant get it..any advice???
Old 03-15-2010, 09:26 AM
coopercharge's Avatar
One thing I would like to add is that you dont have to use the Oil Pressure Sensor port you can just pull off one of the gallie plugs on the head and use that as well it has the same bolt pattern and everything as the oil pressure sensor you just dont have to pull it off. I believe that the gallie plug is a t10 Star you can get the socket from any local auto parts store or Sears. Craftsman is my tool of choice.
Mechanical gauges are ok but you dont want to take a chance on that line coming loose in your car, and oil getting everywhere. Electric is the way to go.
Last edited by coopercharge; 03-15-2010 at 09:27 AM. Reason: Automerged Doublepost
Old 03-15-2010, 12:39 PM
  #36
SS/SCking's Avatar
sub'd.....
Old 04-08-2010, 11:56 AM
  #37
buellfooll's Avatar
Great write up. I'd like to add an oil pressure gauge to my LNF also but before I replace the stock sending unit I'd like to know if that signal goes to the ECU and if it does what, EXACTLY, is it used for? I'm more inclined to use a different location. Just throwing that out there.
Old 03-23-2011, 03:44 PM
  #38
ben_gary's Avatar
Ok, so I did this same setup on my 2006 ss/sc, also have an interceptor installed, haven't seen any codes. Goin on a week now. Removed stock.
Old 11-13-2011, 03:42 PM
  #39
insylem's Avatar
I just did my dual pass and pheonalic spacer. Since I had the intake off, it was easy access to the oil gally ports so I didnt have to disconnect anything. I used the ZZP Oil feed to -4 AN fitting, then a #4 an Elbow and a oil line from Sumit to run to my aeroforce sensor that i mounted ontop of my supercharger shareing the same bolt with that sensor.
Old 11-13-2011, 03:50 PM
  #40
insylem's Avatar
Galley Port is inverted Hex. I got a VERY good view of them when takeing off my intake to do the Dual Pass endplate / pheonalic spacer.
Metric, I think H6,
Same as the SUpercharger I belive
Old 06-02-2012, 02:02 PM
  #41
Fen52690's Avatar
i bought a gauge it didnt come with wires r u supposed to use the wires from ur boost gauge?
Old 07-04-2013, 10:32 PM
  #42
blueLNFftw's Avatar
Thread digger.
cant you just use one of the galley plugs on the back of the block to pop in the sending unit?
Old 07-04-2013, 10:51 PM
  #43
tazmanian devil's Avatar
xcellent write up was just about to install my gauge , thanks!!
Old 07-04-2013, 11:11 PM
  #44
c130aviator's Avatar
I have a writeup over here as well, little different but great for turbo cars.
https://www.cobaltss.net/forums/appe...onight-294335/
Old 07-05-2013, 12:00 AM
  #45
insylem's Avatar
Mine is in one of the oil galley plugs under the intake manifold. I did it while I had the manifold off for my dual pass and ZZP Spacer mod
Old 07-05-2013, 12:11 AM
  #46
Cobalt_SSTuner's Avatar
Good writeup
Old 07-13-2013, 03:54 PM
  #47
blueLNFftw's Avatar
So I am thinking this to retain the stock sender as well as an aftermarket.
Thoughts?
1/8" NPT Street Tee T Fitting for Brass Pipe Dual Female/Single Male: Amazon.com: Industrial & Scientific 1/8" NPT Street Tee T Fitting for Brass Pipe Dual Female/Single Male: Amazon.com: Industrial & Scientific
OR ==============================
Fitting, Y, Brass, 1/8" NPT, 2 F, 1 M (am-2186)
Old 07-20-2013, 07:21 PM
  #48
blueLNFftw's Avatar
So the autometer and equivalent brass fittings are weak as hell. My Autometer 2278 adapter snapped after hand tight and 1/4 turn while wiggling the wrench off. Look into these to use as your adapter instead. Stainless steel and only a couple buck more than the autometer unit.
Speedhut Metric Adapter, 1/8 inch NPT Female to M12X1.75 Male (Stainless Steel) : Amazon.com : Automotive Speedhut Metric Adapter, 1/8 inch NPT Female to M12X1.75 Male (Stainless Steel) : Amazon.com : Automotive
Old 07-20-2013, 08:56 PM
  #49
Josh171's Avatar
so is there enough room under the intake manifold for the sender if its put in the oil galley plug? just doesn't seem like there would be a lot of room. And well will they take heat? I'm sure it gets pretty warm there on a SC car.
Old 07-20-2013, 09:06 PM
  #50
blueLNFftw's Avatar
It look like it depends on the size of the sender if it is electric.
However, from what I have looked at, the only way your getting it in is if the IM is already off.
I am going to put my senders in the back of the block and slide something like this over them to protect them and the wiring from exhaust heat
Blue Heat Protector Spark Plug Wire Boots 2 Cyl Dei Protect A Boot Equivalent | eBay
Quick Reply: 2.0 LSJ Engine: How To Install Oil Pressure Gauge Into 2.0L LSJ
