How To: Install PowerGrid Inc. adjustable swaybar endlinks from OTTP
Old Jan 25, 2010 | 06:01 PM
ls1fbody's Avatar
Haz l33t wheelz.
Start by jacking up the car and removing both front wheels.
Never support the weight of the car using just the jack, always use jackstands.
Tools Needed
19mm wrench
18mm wrench
No. 6 Allen Key
Removal of Stock Endlinks
The stock enlinks use an 18mm nut to secure them to the strut and swaybar. Remove both left and right side top nuts first. Your sway bar will slowly fall downward, this is fine. Now remove both lower nuts, and remove the stock endlinks. I didn't have any problems removing them, but there are flat spots on the back side of the ball joint where you could use a thin 16mm wrench or needle nose vice grips if you have an issue with the threaded shaft spinning.
Setting up your Powergrid Adjustable Links
The length at which you set your endlinks is not super critical on a street driven car as long as both sides are set to equal lengths. I found it easiest to just make them as short as possible. After adjustments and tightening down the jamb nuts, mine are 9.5" from the center of each ball joint. The exposed bronze colored rod is 5.5"
Installing Powergrid Endlinks
Start by installing the lower end of both left and right links first. I slipped a 19mm box end wrench over the nut, then inserted the no. 6 allen key into the threaded shaft of the ball joint to keep it from spinning. After it is tightened, it will look like this:
Make sure that the washer is between the nut and the swaybar.
Next, install the top nut of the swaybar link.
I only hand tightened each side to make sure the lengths matched and allowed the swaybar to be installed without a pre-load.
Next I tightened the top bolt using the same no. 6 allen key and 19mm box wrench.
I started on the drivers side, but it really doesn't make much of a difference.
Make a second pass over all of the nuts to ensure they are tight, and now you are done.
Replace the wheels, lower the car down off the jackstands, and enjoy your clunk-free front end
Old Feb 1, 2010 | 03:33 AM
Black SS/SC 06's Avatar
Approved
Old Feb 1, 2010 | 03:56 AM
CordiaDOHC's Avatar
did you notice any difference with these? i had been debating the bwoody ones for when i upgrade to the fe5 front sway bar.
Old Feb 1, 2010 | 04:32 AM
ikeryder13's Avatar
Nice will now u can help me install some lol
Old Feb 1, 2010 | 03:35 PM
ls1fbody's Avatar
Haz l33t wheelz.
you don't feel a difference, but these weigh nothing. those B-woody ones will add unnecessary unsprung weight equal to half the weight of the link itself.
Also, these are adjustable, so at any point down the line should you decide you want to drive on a n oval track, you can optimize the preload.
Just come over. I'm sure as **** not driving out to you
Old Feb 6, 2010 | 09:33 AM
trashline's Avatar
so there really isnt a benefit aside from adjustability and setting preload? Just trying to decide if making my own is worth it.
Old Feb 6, 2010 | 12:23 PM
thefishyisblue's Avatar
i have them and they are awesome.
will thanks mucho, though when you sent it to me, you failed to mention my bolts would be BEYOND rusted and take 3 years to CUT off.
Old Feb 6, 2010 | 12:36 PM
skiermann1's Avatar
does anyone know when ordering from ottp which endlinks to select?
I have a 2.2l ls with the fe5 sway bar and they have an option for ss or 2.2l
Old Feb 6, 2010 | 04:45 PM
Tennpenn83's Avatar
it should be noted that the stock endlinks are very easily bent, even by hand. these are made with high quality grade 8 material, i believe. no flex to them at all. very very much stronger than stock. and yes you will feel a difference, but only if you are in tune with your car.
i think it should be noted that these are different length for the redlines. a bit longer IIRC
Old Feb 6, 2010 | 04:55 PM
Gestapo007's Avatar
whats up with the nail polish bro?
Old Feb 6, 2010 | 05:26 PM
Tennpenn83's Avatar
these are my stock end links. i bent the one using nothing but my two hands
Old Feb 6, 2010 | 09:07 PM
ls1fbody's Avatar
Haz l33t wheelz.
Wow, mine are not that dinky. Redlines were only FE3 iirc though.
It's called smashing the **** out of my thumb in a car door. Not nail polish bro
Old Feb 7, 2010 | 12:04 AM
Gestapo007's Avatar
*sigh of relief*
I cant believe im the 1st to post about it. It was definitly the elephant in the room in all those pics. Just kinda lingering there and every1 pretended not to notice. Like when you have company over and your dog is laying in the middle of the room licking his *****.
Good How To though
Old Feb 7, 2010 | 12:14 AM
Edubs's Avatar
Good How To though
I agree, good How To...
Old Feb 7, 2010 | 12:17 AM
rallyracer's Avatar
Are you control arms stock?
Old Feb 7, 2010 | 02:09 AM
*sigh of relief*
Good How To though
you were the first one to notice.
i made fun of him about it.
but not in this thread.
and whats this i hear about you moving back up to LI?
Old Feb 7, 2010 | 08:17 AM
ls1fbody's Avatar
Haz l33t wheelz.
For now, i'll be ordering OTTP/Powell CAB's soon.
Old Feb 7, 2010 | 01:49 PM
Gestapo007's Avatar
Some1 needed to talk ****
And yea i should be moving back to LI in August after I graduate. 99% sure I am
Old Feb 7, 2010 | 02:01 PM
redssna's Avatar
Nice write up. I have these on my car along with their CAB's and steering rack spacers. All great products that I'm sure many on here would highly recommend.
Old Feb 7, 2010 | 02:03 PM
rico's Avatar
um might have to pick up a set of these and new rotors and brake lines
Old Feb 7, 2010 | 02:43 PM
redssna's Avatar
Do it up rico! Brake lines are definitely on my list. Just don't know when I'm going to get around to it.
Old Feb 7, 2010 | 02:44 PM
ikeryder13's Avatar
gb on these maybe??
Old Feb 7, 2010 | 02:57 PM
northvibe's Avatar
lsjfbody - all you do is troll with your goodies :P
Old Feb 7, 2010 | 08:43 PM
i can't wait. MAYBE JUST MAYBE you might keep us together once winter starts back up.
summer is find, fall is eh, once winter hits, man its like the man on the moon mission to get us al together again.
Old Jul 10, 2010 | 03:12 PM
Brags's Avatar
Nice write up Will, made install a snap. Just put these pedders and Fe5 struts and shocks. Only driven to get alignment waiting to get finished before I go rip it up haha
